BF Goodies ATR or Cooper ST
Submitted: Thursday, Mar 08, 2007 at 07:36
ThreadID: 43019 Views:3718 Replies:13 FollowUps:5
Hi, we can't decide on which tyres to get for our Patrol. Can anyone offer some advice on the above two brands? At the moment we have BF Goodies. We don't do alot of offroad travel, mainly just weekend trips up to the Alpine National Park. We are about to do a trip from Victoria up to the Kimberley and back and need new tyres before we go.
Thanks Fiona & Aaron
Reply By: Member - Ian H (NSW) - Thursday, Mar 08, 2007 at 07:42
If you have been happy with the BFG's then stick with them. I have had 3 sets and would not risk changing to any other as they could not be better for me. We have had one sidewall stake in 8 years on a cut sapling and my mate has had similar performance. I sure others have had good results from other tyres too.
AnswerID: 225993
Reply By: Holly2 - Thursday, Mar 08, 2007 at 07:52
I have Cooper ST fitted to my LR and have had an excellent run with them.
Have been up through the centre (mainly off the tar) down the Gibb River road ECT.
Have been running heavy and towing an off road camper . Not one flat as yet. Road noise is not too bad .35,000kls on them now and still 40-50% left !
AnswerID: 225998
Reply By: PhilZD30Patrol - Thursday, Mar 08, 2007 at 08:07
I had the same problem a few months ago and eventually chose the Coopers Sure Trac for no real scientific reason. I am very happy with my choice.
But, make sure you get Light Truck tyres in the BFGs or Coopers because they are stronger and hopefully more puncture resistant, especially if you carry loads and travel rough stony tracks.
AnswerID: 226003
Reply By: MEMBER - Darian (SA) - Thursday, Mar 08, 2007 at 08:17
I've been on BFG's for 7 years since buying a new Jackaroo - have done quite a few trips now to central Oz and one to the Kimberley - plenty of 'rough and tumble' travel involved. I use them on the Campomatic trailer too, because they seem very robust, when used with due care. Yet to have a flat with a BFG. I do add that I'm conservative in my driving habits so they get a good life from me - we always adjust pressures in the bush where indicated. I don't have a good reason to try anything else it seems ! No tyre is perfect but - they do lose small chips from the lugs when used on stony ground - this takes a toll if you cover a lot of this surfcae type - anecdotes here suggest Michelin may have toughened the compound since I bought mine. Some other makes don't chip like these apparently. 80k from my first set - 65k from the current ones probably (more bush travel on this latest set).
AnswerID: 226007
Reply By: Andrew from Vivid Adventures - Thursday, Mar 08, 2007 at 08:25
I'm on Cooper STTs and despite hard work in gibber country, the high country, the otways, Nullabor limestone and the Anne Beadell to name a few, they are in pretty good nick and with 43Ks under them, are looking like they'll be good for 80+Ks from 6 of them.
I've had one side-wall stake repaired, and there are some chinks (rather than chunks), and they made a nice wine (sic) as I drive along, but only a little worse than the ATs I had prior.
Let's compare notes in the Kimberley - will be there most of May.
AnswerID: 226011
Reply By: P.G. (Tas) - Thursday, Mar 08, 2007 at 08:47
Hi Fiona,
We have just finished a 6,000k trip into the Territory and I can't speak highly enough about the Cooper S/T's on our Patrol. They are 265/75R16LT's.
We did some serious heavy 4WDing on the Adventure Trail to the east of Arltunga, to the Plenty Highway (over 5 hours to do a 100km) over deep soft sand, mud, water crossings, rock and everything in between. I should have deflated the tyres over many sections but given the 40degree+ temperatures I took my life into my hands and soldiered on without deflating them.
The truck weighed in at 2.98tonnes. I was running 45psi (F) and 49psi (R) cold pressures.
So, at the end of the trip we had scratches down both sides of the body, dents and scratches in and under the back bumper and 2 small chips out of the tyres. Puntures Zero, Bogged Zero. Smiles on our faces from ear to ear. :-) All in all, very impressive.
Tyre noise seems to be an issue for some people, but we find it is not intrusive and is not an issue once the wheels leave the black top. I would recommend these tyres to any Patrol owners, with the only proviso being they are rotated every 5,000k's or there about.
I have a 60mm spring lift (Kings/Koni) and as yet haven't done anything about the camber. I experience minor scalloping on the edge of the front tyres if they aren't rotated regularly, but this doesn't seem to effect steering or handling. Overall they are far better in the wet than I ever thought possible.
Ours have travelled 40,000+k's and still have better than 50% tread left front and rear. I'll definately be replacing them with the same when the time comes.
Enjoy your trip ;-)
AnswerID: 226017
Reply By: steve&anja - Thursday, Mar 08, 2007 at 08:58
Hi Fiona
Go to bridgestone and get a set of Ozi made A/T duellers, trust me you get the same milage as the others, and in 6 years I've never had a problem taking them across the top end EG Arnhemland, Kakadu and ocasionly to the Kimborley.
I have 3 Landcruisers that do tours to these areas daily fom May- Dec, there about $100 cheaper as well.
Cheers Steve Top End Explorer Tours
AnswerID: 226020
Follow Up By: P.G. (Tas) - Thursday, Mar 08, 2007 at 09:06
Not sure if my originals were Ozi A/T's or not, but the original Bridgestones A/T's needed replacing at 28,000k's and didn't gain any respect from me whatsoever!
It is also an interesting side note, Bridgestone have their maximum load rating @36psi. I know many people who won't be told this and exceed this by a dangerous margin!
Cheers!
FollowupID: 486906
Follow Up By: steve&anja - Thursday, Mar 08, 2007 at 09:32
If you only got 28,000ks out of them they weren't Ozi made thats for sure, my tyres go hard for up to 65,000 ks each a year.
My Bridgestone dealer puts my tyres on my trucks at 40 psi front 42 psi rear and I keep them at that and have done so over 9 sets of tyres.
Cheers Steve
FollowupID: 486913
Follow Up By: P.G. (Tas) - Thursday, Mar 08, 2007 at 09:44
Your Bridgestone dealer doesn't surprise me. I took the time to send off an email to Bridgestone from their website, asking the question "is 28,000 k's normal wear?".
Obviously their reply was "no" and this is where I got it from the horses mouth, from their tyre guru technician "DO NOT exceed 36psi under ANY circumstances!". The technician went on to say that Patrols have such a good LSD that the tyres must be rotoated every 5,000k or I would suffer the same fate in the future. It is a common occurance in Patrols apparently.
The Bridgestone A/T is a passenger car construction and 36psi IS the maximum pressure for them. Bridgestone obviously have LT rated tyres that allow higher pressures and more load carrying capacity than the A/T.
Just as a side note, my Cooper S/T's are rated at their maximum load @ 80psi, and you will see that at near the maximum GVM I am only running 45psi(f) and 49psi (r). Plenty of room for heat build up expansion before they blow out!
Cheers!
FollowupID: 486915
Follow Up By: steve&anja - Thursday, Mar 08, 2007 at 10:41
The way I see it.
9 sets of 265/75/16 average 60,000 km per set =540,000 km, 1/2 of which was corrugated dirt road.
Each tyre was $100 cheaper than coopers =savings of $3600.
1 puncher no blow outs and every tyre that came off the car still had legal tread and were used as spares or went on my camper trailers.
Im buying another 100 series in 3 weeks and before I take it home Ill take it straight to Bridgestone for my 10th set of Ozi made A/T duellers, and as my accountant says you don't spend much on tyres.
FollowupID: 486927
Follow Up By: steve&anja - Thursday, Mar 08, 2007 at 10:43
PS the profits stay in Australia and not the USA.
FollowupID: 486928
Reply By: pprass - Thursday, Mar 08, 2007 at 13:44
FionaD,
I have a Patrol and I have tried both the BFG A/T's and the Cooper ST's and quite honestly they perform just about the same in my opinion. Never had a puncture in either sets and both have been through the Simpson, Flinders Ranges, Fraser Isl. Victorian High Country and countless other tracks. Both sets developed chipped edges, however the Coopers chipped worse with the blocks starting to rip off.
I am now on Cooper STT's and for the first time ever I can appreciate the difference that a tyre makes. These are fantastic tyres - they grip so well on gravel roads and of coarse going through mud (a rarity nowadays) they don't clog up as easily as the ST's or A/T's. Highly recommended.
AnswerID: 226065
Reply By: Member - Norm C (QLD) - Thursday, Mar 08, 2007 at 13:55
I'm very happy with my Cooper STs, but they do produce a bit more road noise on bitumen than some less aggressive tyres. I ran Cooper ATRs before that. The ATRs are an excellent on road tyre with little road noise, but the STs are much better off road.
Have done GRR, Kalumburu Road, Mitchell Plateau, Cape Leveque, Bungle Bungles and lots of other notable 'bad roads'. No punctures and good handling. We run as high as 46 PSI in the back when fully loaded (38 front). Reduce about 10 PSI for corrugated roads and more for slower off roading and sand.
Most people I know with BFG (mostly AT, not ATRs) are also happy.
AnswerID: 226069
Reply By: Member - Dunworkin (WA) - Thursday, Mar 08, 2007 at 15:49
Hi Fiona, we put BFG A/T on our GU, they have done over 110000kls and still going, we did the CSR with ours and had no punctures until we hit the bitumen near Halls Creek. We are looking at doing the Central Road, Tanami and Gibb River Rd later in the year so will put a new set of them on then.
Deanna
Simba, our much missed baby.
AnswerID: 226085
Reply By: Member - Vincent A M (NSW) - Friday, Mar 09, 2007 at 08:12
Had both, prefer the bfg remember coopers klms warranty is only for road use once you take them off road No warranty also Google Coopers recall (i had i set good & 1 set crap) good luck
AnswerID: 226268
Reply By: South - Friday, Mar 09, 2007 at 13:31
My vote is for Cooper ST. They were fitted specifically for a trip to the Kimberley region, along and around the GRR. Came home with just under 10,000km's on them and looked brand new, no cuts, not chipping, no chunks, perfecto.
BFG's are for the old school boys, who used to run them donkey's years ago when the compound and manufacturer were different. They still perform but are not like they once were.
Never buy a tyre for its warranty, if one is offered then thats nice, dont rely on it. Do you kick up a fuss when your other consumables dont come up trumps. example, printer cartridge should print XYZ pages, however it falls short by ABC pages, do you go back crying demanding you get a new cartridge for free...
P.S. the ST will make your truck look sexier than the AT
AnswerID: 226345
Reply By: dawesy - Friday, Mar 09, 2007 at 15:11
I have no experience with the BFGs but I susppect if your happy with your current tyre you may as well stay with it. I didn't get them becasue there was some doubt about the quality at the time i bought, but as best I can tell that has been fixed or was unfounded. Like I said, never had any.
Having said that, I am currently on STs and love them. Went on about 35 000ks ago and had no faults at all so far. Haven't ever rotated them and wear has been pretty even. Only issue I've had is recently was my fault, belted a gutter and knocked the front left out of alignment and ended up toasting the tire, wearing of the outside, because I didn't realise and failed to look at the tire for some time. Just put on a new one and moved the still new spare opposite it. Had a chance to compare them to the 35k old back ones and they are at about 50% wear I'd say. The edges are a but soft on the lugs but no cuts scrapes etc.
I have done heaps of bitumen touring and a fair bit of off roading on dirt/gravel/rock. Grip has been phenominal in all conditions. Was particularly impressed with on road grip for such an agressive tyre.
The truck came with Duelers on it and they were terrible. When I got the Coopers on I was sunned at how well the truck handles. Used to live in fear every time it rains, now it corners and pulls up like a champ.
AnswerID: 226366
