stiff gear shift
Submitted: Thursday, Mar 08, 2007 at 14:22
ThreadID: 43029 Views:2886 Replies:5 FollowUps:4
Hi all.
Can anyone offer suggestions to remedy a stiff gear shift in my GQ Patrol?
Each gear change takes a moment or two before the stick 'slides' in to the selected gear.
What could be the cause of this and how can it be fixed???
Neilo
Reply By: Member - Tour Boy- Thursday, Mar 08, 2007 at 14:54
Hi mate,
I'd say more than likely the wrong grade of oil, especially if it is worse when cold.
Tour Boy
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 226077
Follow Up By: Neilo - Thursday, Mar 08, 2007 at 15:52
Hmm, thanks. Ive been told that.
Do you reckon a simple oil change will do the job???
FollowupID: 486970
Follow Up By: Member - Tour Boy- Thursday, Mar 08, 2007 at 19:44
Yeah mate has worked for me with my cruisers and in anycase it's the cheapest and easiest thing to try.
Tour Boy
2015 Fortuner
FollowupID: 487019
Reply By: Member -Signman - Thursday, Mar 08, 2007 at 15:34
Synforce AT80
AnswerID: 226082
Follow Up By: Neilo - Thursday, Mar 08, 2007 at 16:00
Thanks. I looked this stuff up and it sounds good.
What do should I expect to pay for Synforce AT80?
FollowupID: 486973
Reply By: Rock Crawler - Thursday, Mar 08, 2007 at 17:47
defenently a oil problem
AnswerID: 226112
Reply By: Member - Brian (Gold Coast) - Thursday, Mar 08, 2007 at 18:48
Along the same lines as your gear shift dilemma is a drama I had with my Hi-Lo range shift.... under the car on the transfer case is a rubber boot over a knuckle joint.... the joint on mine got considerably gunked up from being wet and made the shift hard to move..... I now keep in lubed!
Brian
AnswerID: 226127
Follow Up By: Neilo - Thursday, Mar 08, 2007 at 22:43
Hmmm, a mechanic recently told me that my clutch is on its way out, based on a worn out boot. Im going to get oil changed next week, hopefuly it will save me a grand or so for a new clutch!!
FollowupID: 487075
Reply By: Andrew from Vivid Adventures - Thursday, Mar 08, 2007 at 19:46
could be dirt that has got in through the protective boots which might have perished.
AnswerID: 226141
