oil for 92 hilux
Submitted: Thursday, Mar 08, 2007 at 19:50
ThreadID: 43043 Views:4306 Replies:6 FollowUps:11
hi, i'm new to the world of 4x4 and just bought a 92 hilux with 237000 on the clock, what i want to know is would a 15-40 oil be thick enough. i just put rimula super 15-40 in but seems pretty thin. so with your experience do you think this would be thick enough?
ps the book says put a 20-40 in but i can't find a diesel oil that's 20-40 only 15-40, 15-50 penrite and 20-60 penrite.
Reply By: oldpop - Thursday, Mar 08, 2007 at 20:01
hello Luke B
Have owned a couple of diesel hilux's stick to 15w40 grade make sure you change it every 5000k as per toyotas specs i used to change my oil and filter every time at 5000k oil is cheaper than hard internal metal parts these japanese diesels make a lot of soot which causes oil thickening and if left in to long can turn to jelly and really totals the motor take a tip from and old mechanic seen many fail fromlack of care
AnswerID: 226150
Follow Up By: luke.b - Thursday, Mar 08, 2007 at 20:41
sweet thanks mate, yeah just wasn't too sure especially with that many k's.
FollowupID: 487028
Follow Up By: Member - Doug T (W.A) - Thursday, Mar 08, 2007 at 21:34
oldpop
Nah I just use the stuff coz I reackon it;s good oil.Aussie Company means a lot too
FollowupID: 487041
Follow Up By: Member - Doug T (W.A) - Thursday, Mar 08, 2007 at 21:44
oldpop
Oh I forgot to add that I'm also Rep for Garmin,Toyota's,BF Goodridge,Waeco,Pal Meaty Bites, Smacko's, Rossi Boots, and Black and Gold schit paper.So what do you want ,
FollowupID: 487043
Follow Up By: oldpop - Thursday, Mar 08, 2007 at 21:47
Doug T
sounds like your a very busy man how do you get time to play on the forum
FollowupID: 487045
Follow Up By: Member - Doug T (W.A) - Thursday, Mar 08, 2007 at 21:49
I;m the Boss, ....lol all work is carried out by the Forman
!MPG:33!
FollowupID: 487048
Follow Up By: oldpop - Thursday, Mar 08, 2007 at 21:58
Looks like a hard task master
own 100 series
like most of your products
not sure about the dog food and schitt paper
FollowupID: 487054
Follow Up By: Member - Doug T (W.A) - Thursday, Mar 08, 2007 at 22:20
oldpop
Geez we have some silly fun here at times ,OK where are you situated, I'm just S/E of Perth by 17klm, Been another stinker in Carnarvon today at 44deg and it's still 31 deg in Perth
Doug
FollowupID: 487065
Follow Up By: oldpop - Thursday, Mar 08, 2007 at 22:30
Doug T
Live at narre Warren about 35 K SE of Melbourne
Just Recently joined forum better viewing than tv
not game to reply to some of the threads but most are fun to read
only 28 deg today currently 18.5
all the best
oldpop
FollowupID: 487070
Reply By: luke.b - Thursday, Mar 08, 2007 at 20:42
AnswerID: 226167
Reply By: Member - Doug T (W.A) - Thursday, Mar 08, 2007 at 21:05
luke.b
Check out this web site and on the left side you will see WHICH OIL DO I USE
www.fuchs.com.au/html/localnonflash.html
AnswerID: 226174
Follow Up By: oldpop - Thursday, Mar 08, 2007 at 21:17
Doug T
Are you the local Fuchs rep
FollowupID: 487036
Reply By: Member - Doug T (W.A) - Thursday, Mar 08, 2007 at 21:08
Just done it for you
Crankcase
TITAN UNIVERSAL HD 15W40 or TITAN PERFORMANCE PLUS 1540
Service Refill Capacity: 4.3, 5.3* Litres (See Note 398)
Manual Transmission
TITAN GEAR 75W90
Service Refill Capacity: 3.9 Litres
Differential
TITAN GEAR LS 90
Service Refill Capacity: 2.2 Litres (See Note 15)
Power Steering
TITAN ATF 3000
4WD Transfer
TITAN GEAR 75W90
Service Refill Capacity: 1.6 Litres
4WD Differential
TITAN GEAR LS 90
Service Refill Capacity: 2.3 Litres
AnswerID: 226176
Follow Up By: Chris & Debbie - Friday, Mar 09, 2007 at 00:33
I work as a mechanic and the company i work for exclusively used Fuchs lubricants at one stage but ended up having nothing but trouble with thier products. Excessive wear in gear type drives was of major concern. Oil samples are regually sent to CAT for testing from each piece of equipment and the results nearly always came back with warnings usually to the effect that the oil did not meet correct viscosity specs, even when sending new oil from sealed drums. We have now changed to a different brand of oil and because of this I would not recomend Fuchs oil to anyone.
Chris
FollowupID: 487098
Reply By: Wayne (NSW) - Thursday, Mar 08, 2007 at 21:14
Luke,
There is nothing wrong with Shell Rimula 15-40.
I use it all the time. The other good thing about it, it is available just about ever where you go. Mixing oil of different brands is not always good.
The problem with a question like the one you posted is that you will get 10 different answers from 10 different people. Don't worry and enjoy the Hilux.
Wayne
AnswerID: 226179
Follow Up By: Member - Robert A (QLD) - Friday, Mar 09, 2007 at 04:38
Another vote for shell rimula. I run this on most of the boats I have worked on and all my diesel cars, I have owned, even one rebuilt petrol engine.
As a motor gets older just have to service more regularly. Oils cheap diesels are not.
Rob
FollowupID: 487108
Reply By: madfisher - Thursday, Mar 08, 2007 at 21:21
If you live in a high atitude area I would change the oil and filter every 4000ks, in a 3l . Last forever if you do that. The main problem areas were arround Cooma, Orange And Armidale
Cheers Pete
AnswerID: 226183
