oziexplorerCE
Submitted: Thursday, Mar 08, 2007 at 22:43
ThreadID: 43053 Views:2301 Replies:7 FollowUps:8
can oziexplorer CE be run on a laptop connected to a GPS mouse. I currently have ozi explorer installed but the CE version seems to have more features.
Reply By: Andrew from Vivid Adventures - Thursday, Mar 08, 2007 at 22:50
You might be able to find a CE Emulator that runs on XP, but I think for practical purposes, the answer is no.
AnswerID: 226211
Reply By: Member - Toolman (VIC) - Thursday, Mar 08, 2007 at 22:51
David,
OzieExplorerCE from my understanding is solely for use on a PDA. I am not aware of any features in the OzieExplorerCE version that would not be available on OziExplorer. Having used both packages I reckon OzieExplorerCE version has less features than the full blown OzExplorer.
Toolman
AnswerID: 226213
Reply By: Richard Kovac - Thursday, Mar 08, 2007 at 22:51
David
The answer will be NO, two differant operating systems.
OziEplorer PC has more features then ce Me things and I run all three
Richard
AnswerID: 226214
Follow Up By: Bonz (Vic) - Friday, Mar 09, 2007 at 13:28
CE has the screen are covered for different actions like setting WP's etc as well as more/less detailed maps etc, other than that Ozi on the PC has more things it can do
FollowupID: 487174
Follow Up By: Member - 'Lucy' - Friday, Mar 09, 2007 at 23:49
Dear Z-nob (Bonz -backwards)
Could you please read your reply, have a think and then clarify it. No wonder I couldn't get my PDA to work with CE after your 'in depth' training sessions.
FollowupID: 487316
Follow Up By: Gramps (NSW) - Saturday, Mar 10, 2007 at 07:13
Hahahahahaha Sir Bonz strikes again :))))
FollowupID: 487332
Follow Up By: Bonz (Vic) - Saturday, Mar 10, 2007 at 08:31
It was a long week in Melbourne Lucy, what I meant to say is that the only benefit I can see for using CE over the PC version is the product linkage thru the generic host interfaceis far superior to that in non-screen enabled applications such as OziPC and for that reason I would use PC or CE for the majority of WP intensive route estimation.
Al you shoosh up! Don't forget ..I KNOW WHERE U LIVE...its in my PDA
And Lucy I finally cracked the Nortons for Vista code after an annoying week, and all fish are happily cavorting on the new tablet PC
FollowupID: 487344
Reply By: David (Mt Barker SA) - Thursday, Mar 08, 2007 at 22:57
I know I am still learning to use it but can all the toolbars available on CE be found on oziexplorer on the laptop. This is what makes me think there is more available on CE. eg can the bar scale be brought up on the map & CE had a little arrow thingy to show which direction to go when trying to navigate back to a particular co ordinate.
AnswerID: 226217
Follow Up By: bgreeni - Thursday, Mar 08, 2007 at 23:14
Certainly many of the menu bars on OziExp can be either docked or floating. Because OziExp is designed for a bigger screen some things are done a little differently but generally OziExp has more functionality than OziCe (and i have been using both for several years)
Bruce
FollowupID: 487090
Reply By: Kumunara (NT) - Friday, Mar 09, 2007 at 00:41
David
OziExplorer is designed to run on a PC or Laptop.
OziExplorer CE is a version designed to run on a PDA. The CE version is smaller and has less features.
A GPS mouse should run with OziExplorer on your laptop. NMEA only.
Tjilpi
AnswerID: 226239
Follow Up By: Des Lexic - Friday, Mar 09, 2007 at 09:49
Tjilpi,
Are you trying to blend in with your surrounds.
I think you will have difficulty there.
Strip off and look in the mirror and you will see what I mean. Especially the area with the biggest girth LOL
FollowupID: 487142
Follow Up By: Kumunara (NT) - Friday, Mar 09, 2007 at 16:49
Des
Thats a bit harsh. I would not normally strip off and look in the mirror as it is a sight I would prefer not seeing.
FollowupID: 487229
Follow Up By: Des Lexic - Friday, Mar 09, 2007 at 20:47
Kumunara,
That is a sight that I definitely don't want to see either.
FollowupID: 487256
Reply By: Member -Signman - Friday, Mar 09, 2007 at 09:03
Nope...
AnswerID: 226282
Reply By: Outnabout David (SA) - Friday, Mar 09, 2007 at 22:56
David,
I run Ozie o the PC and CE for my Palm.
If you want to see it working on a palm then MM me as I live only 5K from Mt BArker.
AnswerID: 226489
