coden 7727TB
Submitted: Saturday, Mar 10, 2007 at 20:40
ThreadID: 43110 Views:2357 Replies:6 FollowUps:1
Hi all I have just got hold a 7727TB and was wondering if any body can tell me what length of wire (i.e . long wire) I can use on channel 8020 or 5110 just to see if it works as I haven't got an antenna and I want to see(hear) if works before I go any further with it.
I tried the coden forum site but they said that I was wasteing my time and should sell it.If its no good why would I sell it to somebody else but maybe thats the way they work on that site I hope somebody here can help,it seems a shame to just throw it away just because it hasn't got all the bells and whistles.
thanks Greg
Reply By: Im.away - Saturday, Mar 10, 2007 at 21:05
The formula to calculate wavelength is:
wavelength = speed of light/frequency
ie wavelength = 299,792,458 meters per second / 5110000 Hz
= 58.6678 metres
You would get by with a 5/8 wave antenna for a simple test so you need
AnswerID: 226635
Follow Up By: Im.away - Saturday, Mar 10, 2007 at 21:06
oops, pusshed the wrong button
you need 36.7 metres.
You could also use a 1/4 wave for a test too.
FollowupID: 487454
Reply By: joc45 - Saturday, Mar 10, 2007 at 21:06
Hi gunabat,
the good-enough formula for wavelength is
300/f where f is in megahertz
you will need a 1/4 wavelength so:
for 8020 you need 9.35 metres,
for 5110, you will need 14.68 metres
you should also connect the body of the radio to a good earth, or run a length of wire along the ground (a counterpoise). The length should be at least as long as the ones above. It doesn't need to make electrical contact with the ground - just be laying along it.
The 7727 was a good radio in its day. Just an expensive hassle if you have to fit out channels in it. If you got it at a good price and it has the VKS channels fitted, then that's all you need.
Gerry
AnswerID: 226636
Reply By: Topcat (WA) - Saturday, Mar 10, 2007 at 23:22
The formula for calculating 1/4 wavelength horizontal HF longwire aerials is:
Length in meters = 71.49 divided by the frequency in Megahertz.
AnswerID: 226665
Reply By: Member - John and Val W (ACT) - Sunday, Mar 11, 2007 at 08:35
Gunabat - Others have given you the facts on length. It's worth mentioning that the end of the aerial wire remote from the transmitter must be well insulated and people kept clear of it. There can be high voltages there when transmitting and these can cause a nasty burn.
HTH
J and V
- Albert Einstein
AnswerID: 226700
Reply By: MEMBER - Darian (SA) - Sunday, Mar 11, 2007 at 09:17
A lot of the above rings true to my observations - just a couple of points - a guru pointed out to me awhile back that a realistic calculation for long wires is a little different to pure high school physics re the speed of light - I was given 71.25 / frequency in MHz = a quarter wave wire for the frequency in question. Also, its best to elevate the far end of the wire if possible (in a tree etc ?) and broadside to the direction you want to send. If you can't elevate the wire, it can trail along the ground (strange but true) pointing to the direction you want to send. IF you had an extendable rod to support it, straight up is good too. As mentioned, don't touch the wire when TX'ing because energy levels can be high.
AnswerID: 226708
Reply By: gunabat - Sunday, Mar 11, 2007 at 12:16
Thanks to all that replied. That is what I wanted to know I should have asked on the number one site in the first place. I'll know better next time thanks again.
AnswerID: 226720
