new front page
Submitted: Monday, Mar 12, 2007 at 18:21
Gob & Denny
evening all
how do others find the new front page for exploroz i dont mind the layout but the pictures flashing at a 1000 frames a sec while trying to read the lists are a pain
steve
Reply By: nowimnumberone - Monday, Mar 12, 2007 at 18:29
not sure iv ever seen it .web automatically comes to
forum lol
226988
Follow Up By: Truckster (Vic) - Tuesday, Mar 13, 2007 at 08:33
Im the same lol! didnt know there were other pages apart from
Forum and Trader...
hows fingerys?
487898
Reply By: Member - Doug T (W.A) - Monday, Mar 12, 2007 at 18:43
Top left side of the panel HOME/FORUM/TRADER/SHOP/ etc just clik on HOME
226995
Follow Up By: Gob & Denny - Monday, Mar 12, 2007 at 18:59
goodday doug
thats when it carries on doug when that bloke drives the 4b thru the
water it keepss reloading and flashing on /over the writing on the left side
steve
487813
Reply By: Member - Doug T (W.A) - Monday, Mar 12, 2007 at 19:18
If your talking about the 4x4 driving through the
water over a bridge then thats only an add, When your in a website and you see HOME and you click it that takes you to the No 1 page , called index in the building of a homepage or website,
226999
Reply By: Willem - Monday, Mar 12, 2007 at 19:32
Doesn't worry me and I am older than you....lol
227005
Reply By: ExplorOz Team - David - Monday, Mar 12, 2007 at 20:27
Steve,
Can you tell me more what you mean. What pictures flashing while reading the list. Is the layout OK as per the little sample below or does it display funny?
If you can give me more info it would be great.
227023
Follow Up By: ExplorOz Team - David - Monday, Mar 12, 2007 at 20:29
Maybe you mean the
shop and trader images - anyway just let me know, I am still working on the layouts so any constructive feedback welcome. BTW: If you look at the Topics area as
well you will see the WIP for these pages also.
487834
Follow Up By: Member - John (Vic) - Tuesday, Mar 13, 2007 at 11:53
David one small point that I thought was only occurring on my screen but I can see it on your little sample pic above also.
The EO roundel in the left top corner area is very dull in its colors and appearance compared to what it used to appear like, Have you done this on purpose or is there a display problem?
487913
Follow Up By: ExplorOz Team - David - Tuesday, Mar 13, 2007 at 12:12
John,
It is and is not on purpose - I have forgotten to load the right logo - I used this as a temp measure and intended to load the right one shortly - Guess I should do this now. Thanks for pointing it out, I will attend to this now.
487915
Follow Up By: Member - John (Vic) - Tuesday, Mar 13, 2007 at 12:31
Thanks David, thats much better. :-)
487918
Follow Up By: ExplorOz Team - David - Tuesday, Mar 13, 2007 at 12:40
Do a refresh again - I uploaded several versions so hit Refrsh to ensure you have the last one which for now is it. Thanks again John - have a nice day.
487919
Follow Up By: Member - John (Vic) - Tuesday, Mar 13, 2007 at 12:42
Sorry David whilst I'm having a whinge :-) the menu bar on the
forum page...
The Search button goes to far to the right and is under the advertisement that appears there, it appears the menu bar is to long???
487921
Follow Up By: ExplorOz Team - David - Tuesday, Mar 13, 2007 at 12:45
John,
What browser are you using and which ad is the search going under?
487923
Follow Up By: Member - John (Vic) - Tuesday, Mar 13, 2007 at 12:50
IE7 and its the Waeco, engine coolant adds they change around?? on the
forum page.
Also the roundel is now dull in appearance again.
I have controlled refresh several times.
487925
Follow Up By: ExplorOz Team - David - Tuesday, Mar 13, 2007 at 12:54
HUm - IE7 have not done much testing with that one - must install it and have a look. As for the logo - that is sort of what I am trying to acheive - it has a slight 3d effect maybe not 100% yet but close - will see what the creative controller says (Michelle). Thanks for the feedback will see what happens with IE7.
487928
Follow Up By: Member - John (Vic) - Tuesday, Mar 13, 2007 at 13:11
OK I can see the 3D effect your trying to achieve but it looks better being bolder in its colors.
That menu length issue occurs on the home page also (Under the Nissan ad) and the little map of Aus you put in place for the weather detail (Good concept) is now underneath the 4wd crossing the causeway video.
Must be a screaming Ba$tard to get it all correct with so many browsers and versions of browsers in use. (Would drive me nuts)
I'm not complaining as I realise you are revamping the site and it takes time to get it right. I like what you are doing its certainly a modern image that you are reflecting and overall looks great.
Good Luck.
487934
Follow Up By: ExplorOz Team - David - Tuesday, Mar 13, 2007 at 15:07
John,
Darkened a little more. Just installed IE 7 on my machine (bugger forgot the switch to leave IE 6 running, lucky I have 6 machines here). Anyway I cannot for the life of me see an error with the flash file sitting in the wrong spot. Can you send me a screen capture.
And yes browser differences are a pain in the you know what and consume the most time in any development. What a waste of time it is.
Thanks also for the positive feedback.
487951
Follow Up By: Member - John (Vic) - Tuesday, Mar 13, 2007 at 15:53
"Can you send me a screen capture"
Ummmm!!! yep sure... no worries
Can you tell me how I capture it so I can send it please :-)
I'm only computer literate sometimes.
487962
Follow Up By: Member - John (Vic) - Tuesday, Mar 13, 2007 at 16:09
Cancel that last request,
young bloke came home from school and said this is how you do it, easy as.
I knew I sent him to school for a reason :-)
(I will shut up now)
487964
Reply By: Member - Michael J (SA) - Monday, Mar 12, 2007 at 20:29
I agree Steve, they are a pain.
All about getting the message across I s'pose.
Michael
227024
Reply By: Truckster (Vic) - Tuesday, Mar 13, 2007 at 08:42
I dunno, i like it when ya click on HOME and get
Server Error
Please return to the Home Page or navigate using the menu
If you expected a page or used the menu system then please send us Feedback for urgent attention
Try to go to the page again /Default.aspx
227081
Follow Up By: ExplorOz Team - David - Tuesday, Mar 13, 2007 at 11:26
Yeah yeah ok - I was working on it till 2:30am and left a little bug in it - sorted now.
Just installed a mod to the weather system that allows you to mouse over the little map and get the weather for each state capital - this will soon link to the new weather pages - which will include temp graphs by month for areas all over the country - so people will be able to get ideas of average temps by month easily.
487912
Reply By: Dave Thomson - Tuesday, Mar 13, 2007 at 14:44
Hi David,
without sounding like a whinger have to say I cant get the home page up , it just keeps loading over and over again, all I can do is hit the
forum tab and hope for the best,
regards,
227133
Reply By: CLC50 - Tuesday, Mar 13, 2007 at 15:04
Its Great
So I have had my say,wish I could do what he has done ,but its a bit late for me LOL
227139
Reply By: Gob & Denny - Tuesday, Mar 13, 2007 at 19:46
goodday david
sent reply thru feedback but have just watched again and will try to explain
in HOME i now find every time the capital city weather changes cities the 4b on the causeway superimpose over the "exploroz by" when in destinations over the map or if in topics over the lists (which is where i 1st found this as i was trying to read the lists) or if moving the mouse across the little pictures of exploroz by it flickers really bad
steve
227226
