hayman reece weight distributing for pajero exceed
Submitted: Monday, Mar 12, 2007 at 18:30
ThreadID: 43171 Views:2490 Replies:5 FollowUps:1
Hi all, looking for some advice just bought a hayman reece weight distributing kit ,went to fit it to the pajero exceed which comes with the tow pack trouble is its a smidge too big just needs the edges sheared off to make it fit should we do this ? you think it would work and will it effect our warranty cheers sue
Reply By: Member - Kimberly Kruiser - Monday, Mar 12, 2007 at 18:41
Hi Suepajero
Yes my HR was a smidge too big as well.
Attacked it with a smidge remover, just past a beesdick and not quite a tad and walah, in it went.
Unless mating HR hitch to HR towbar, a common problem and remedy I believe.
AnswerID: 226994
Follow Up By: suepajero - Wednesday, Mar 14, 2007 at 21:28
Thanks guys took a smidge off the edges and it fits great thanks to all for your good advice once again cheers sue ps love the way you guys express yourselves i havent actually seen a bees" thingo" but i have an idea now
FollowupID: 488249
Reply By: Member - John R (NSW) - Monday, Mar 12, 2007 at 18:58
I've heard the same as KK. I have the genuine Toyota bar on my 4wd and it was supposed to have the same problems. I just bought the HR and it went straight in. No KY needed!
The advantage of the HR is that the bar is solid, unlike the standard HR gooseneck.
I was told a poofteenth as opposed to a smidge ;-)
AnswerID: 226997
Reply By: Member - MUZBRY (VIC) - Tuesday, Mar 13, 2007 at 12:57
Gday
I removed a bees dick from the side of the gooses neck on my spare bar and all is fine..
AnswerID: 227116
Reply By: disco1942 - Tuesday, Mar 13, 2007 at 15:36
The moral of all this is not to purchase a "genuine" product but insist on a HR bar - particularly if the vehicle is a Disco 3 or Pathfinder
AnswerID: 227146
Reply By: Wizard1 - Wednesday, Mar 14, 2007 at 12:56
Had the same problem when fitting to a standard Toyota bar. The fitter trimmed the corners and it fitted perfectly. Had it for the last 5 years without a problem.
AnswerID: 227379
