Water for camping
Submitted: Tuesday, Mar 13, 2007 at 16:35
rest needed
Hi all,
Im a bit of a novice when it comes to
camping and would like to ask a question about
water quanities.
How much is a safe amount of
water to carry for two days
camping with two adults and two children, there will be no
drinking water available where we are going.
Reply By: Robin - Tuesday, Mar 13, 2007 at 16:46
Hi Rest Needed
Varies massively with circumstances like if you breakdown would there be passing traffic ?
In remote areas we generally reccomend 3lt / person per day however we design things for mimimun
water usage - e.g. never need to wash dishes just wipe with paper towel etc and hence our typical usage is 1.5lt / person per day plus two or three soft drinks / juice etc
Robin Miller
227157
Follow Up By: rest needed - Tuesday, Mar 13, 2007 at 17:00
Thanks mate that gives me a general idea
487976
Reply By: Member - Doug T (W.A) - Tuesday, Mar 13, 2007 at 16:49
We don't know where your going or how far your going , and how long your going to be in a remote area, I could say take 80 lts when you might only need 40lts . The kids will love this bit.....don't waste your
water by washing them or your selves , best advice would be have a look at this web site and have a look at some
water tanks . and click on "truck
water tanks "
" target="EOF" class="lbg">www.dynaplas.com.au/ I use one and have it in my Troopy flat side down
227158
Follow Up By: Member - Doug T (W.A) - Tuesday, Mar 13, 2007 at 16:51
TRY THIS LINK
" target="EOF" class="lbg">www.dynaplas.com.au/%3C/a%3E
487972
Follow Up By: rest needed - Tuesday, Mar 13, 2007 at 17:01
Ok will take a look
THANX
487977
Follow Up By: Member - Doug T (W.A) - Tuesday, Mar 13, 2007 at 17:07
I can't get that link to work here but it does from my 4x4 webpage so if your haveing trouble too go here and click on the
tank
members.westnet.com.au/dtilley/4X4.htm
487981
Follow Up By: SA_Patrol - Wednesday, Mar 14, 2007 at 00:50
www.bmackay.com.au/dp/
tank.html
488112
Reply By: Brew69(SA) - Tuesday, Mar 13, 2007 at 16:52
Once you work it out then double it like suggested above.
227160
Reply By: Kumunara (NT) - Tuesday, Mar 13, 2007 at 17:03
Rest needed
I am probably just going to repeat what has already been said but
water is essential for survival.
You need at least 2 litres per person per day for drinking only. That increase if you do some walking or in warmer conditions. Then you have to look at all your other usage in cooking, dishes and personal hygiene.
The suggestion that you work out what you need and double it is spot on.
Tjilpi
227165
Reply By: robak (QLD) - Tuesday, Mar 13, 2007 at 17:04
Rest needed
It depends on where you are going and how far to the nearest place to get
water. Are you out in
the desert where
water is at least a days drive or on
Moreton Island where
water is a 1 hour drive away.
From the sounds of it you are not going anywehere too remote so I'd take 2 litres per person per day. For your 2 days 1 night - take 20 litres. Preferably in two 10 litre containers.
R
227166
Reply By: Bware (Tweed Valley) - Tuesday, Mar 13, 2007 at 17:05
If not
camping remote, take 2 x 20 litre containers and you will have enough for washing up/cooking/drinking/sponging yourselves down and not run out. No need to live like ferals if you don't have to ;-)))))
227167
Reply By: Alan H (Narangba QLD) - Tuesday, Mar 13, 2007 at 17:10
What ever you carry do so in multiple containers.
You never notice the leak until its too late!
227170
Reply By: MEMBER - Darian (SA) - Tuesday, Mar 13, 2007 at 20:08
Ditto re safety, safety, safety first ! Enough to survive in those conditions without do anything physical, a lot more for the hard work you could all need to do, then more 'just in case'- and multiple containers is a must -
water safety is a very good habit to develop, even if this trip is not a big deal.
227233
Reply By: Member - Phil G (SA) - Tuesday, Mar 13, 2007 at 20:19
2x20litre jerries.
227241
Reply By: pt_nomad - Wednesday, Mar 14, 2007 at 05:59
Hi rest needed,
Due to space issues ( family of 5 in a disco) I only ever carry max. 30 litres. This is carried in 4 containers, 2*10 and 2*5. For an over night
camp I would not take more thant 20 litres. I take all
water on longer trips. Our inablity to carry large amounts of
water prevents us from doing outback dessert trips at the moment, however we ofthen spend longer periods in the bush 2-14 days. With so many containers you start to manage
water. It is most unusual that you do not come across any
water. We suusally use the first 5l and then that becomes the local river
water container. This river
water is usually used for all things except consumption e.g. tubbing and dish washing. I find that this two items are very significant users of
water.
I guess the other thing is that when ever we travel remotly - eg high country we are always with other people. This menas that we should not be stranded for many days on our own in remote and dry areas.
Paul.
227307
Reply By: bockstar1 - Wednesday, Mar 14, 2007 at 12:35
Like I think the others have said/questioned. Depends on where you're going and what you're doing. Sitting around chatting or bushwalking for hours??
Definately carry
water in separate containers. If one is damaged during the course of the trip, you won't lose all your
water.
227373
Reply By: Longreach - Wednesday, Mar 14, 2007 at 15:51
Agree with above and multiple containers is a very good idea. Not only incase a container leaks but it makes them lighter to carry. Also, if you leave home with quality
water and down the track you have the opportunity to top up with lesser quality
water, you don't need to contaminate your whole
water supply, but can keep your good
water for drinking and use the other for other purposes or as a backup if your best
water runs out.
227411
