timing on diesel motors
Submitted: Tuesday, Mar 13, 2007 at 19:17
Goldsahara
Hi there all,
I was wondering if anyone would be kind enough to let me know what kind of timing device is used to check the timing of a diesel motor?
Thanks.
Reply By: Member - Doug T (W.A) - Tuesday, Mar 13, 2007 at 19:25
Because there is no spark and coils etc it's done by markings on the non Electronic vehicles , for Electronic check the link
Site Link
227215
Reply By: Member - Nick (TAS) - Tuesday, Mar 13, 2007 at 19:31
There is an adaptor that clamps over an injector line and adapts to a normal timing light.Havent had much luck with this type.
Also you can put a dial gauge and adaptor on the back of Toyota pumps to time.(1HZ)
227219
Follow Up By: fishaholic - Tuesday, Mar 13, 2007 at 19:45
Nick,
didnt know about the dial guage, cheers for that, can the timing have much to do with my 100 series turbo auto getting hot?
488029
Follow Up By: Exploder - Tuesday, Mar 13, 2007 at 20:18
That can be done with a few injection Pumps, however you need to know exactly what you are doing otherwise it will mean absolutely nothing LOL.
the Caterpillar Injection pumps are about the easiest to time that’s cause it’s a CAT> Cheep Arse Tractor, built buy farmer Joe for farmer Joe. LOL, but
hay nothing wrong with that it works and
488039
Reply By: arewelost - Tuesday, Mar 13, 2007 at 23:37
hi Goldsahara
i don't know about the timing on diesel engines that run a computer management system. But those without the only way to set them up properly is via a mechanical device for DPA type pumps [these look like a distributor in a petrol motor ] most are usually set up with a dial gauge and an adaptor that fits in the rear of the pump between the injector pipes. If you have an INLINE type that is where all the injector pipes are in a line usually on top of the pump this is usually done by spill timing. Now having got rid of the useless information, to buy a dial gauge and adaptor is fairly hefty outlay for something you probably will only do once, the spill timing is basically very simple and only requires a few spanners. Contact your dealer and get photocopies from there workshop manual on how to set up injection timing applicable to your model
cheers steve
227294
Follow Up By: Goldsahara - Wednesday, Mar 14, 2007 at 18:58
Thanks steve yes its an inline on a 12ht and i will look it up.
488217
