Where to mount an inverter in 80 series?
Submitted: Tuesday, Mar 13, 2007 at 19:55
ThreadID: 43218 Views:3010 Replies:5 FollowUps:1
I have a 300w sine wave inverter to mount in an 80 series STD wagon. Only using it to run laptop on our trips.
Given that the output is 230 volts ac, and that a water crossing 'may' go wrong and flood the car to seat base level, and that the inverter needs a reasonable air flow to stay cool, where is the best spot to mount the inverter? I really don't want it bouncing around on the floor and mounting it on the cargo barrier would then need an extension lead. Placing it on the 3/4 passenger bench would expose the passenger to risk of elecution should the 3 pin plug come loose on corrugations. I didn't think of mounting spots before I purchased it. Note that an 80 STD does not have a centre console.
Any suggestions?
Tony
Reply By: Wayne (NSW) - Tuesday, Mar 13, 2007 at 20:08
Tony,
The cargo barrier is the place that I have my inverter. Up high out of the way and it has plenty of air flow around it. The extension lead that I have is only 1.5 m and is really not a problem.
Wayne
AnswerID: 227234
Reply By: On Patrol (Aust.) - Tuesday, Mar 13, 2007 at 21:10
I have to agree with Wayne.
An added benifit of this is it's up high & away from possible water ingress. Thats very important if you have it on while travelling, the results can be "shocking". Pun intended.
Colin.
AnswerID: 227254
Reply By: Member - Peter R (QLD) - Tuesday, Mar 13, 2007 at 21:36
I had a battery fitted on top of wheel arch after I had taken out the rear seat , and the thingo that seat swung off.
A bracket made up fitted over bolt holes and was very secure and out of the way.
Pedro
AnswerID: 227268
Reply By: Member - Doug T (W.A) - Tuesday, Mar 13, 2007 at 21:47
Tony
As like Wayne I have my 800w mounted on the Cargo Barrier and it is hot wired direct to a heavey duty cable from Battery No 2
AnswerID: 227271
Reply By: Member - Tony J (NSW) - Wednesday, Mar 14, 2007 at 10:24
OK Thanks fellas. It looks like the cargo barrier is the way to go.
AnswerID: 227360
Follow Up By: Member -Signman - Wednesday, Mar 14, 2007 at 11:31
Yup- 2 or 3 longish cable ties- it ain't going nowhere, it's accessible but out of the way.
FollowupID: 488151
