sale of 1HZ with aftermarket turbo
Submitted: Tuesday, Mar 13, 2007 at 21:54
ThreadID: 43223 Views:5571 Replies:3 FollowUps:7
If I was to go down the path of a V8 diesel conversion, does anyone know how much I could hope to get for my 1HZ turbo diesel engine with 180000kms on the clock?
Reply By: Member - Doug T (W.A) - Tuesday, Mar 13, 2007 at 21:59
fishaholic
Hmmmmm that would be handy , mine has 678000 on it now.and going like a dream
AnswerID: 227274
Follow Up By: MichaelR - Tuesday, Mar 13, 2007 at 22:30
Doug T,
As a matter of interest have you done a compression test on you aged 1HZ?
Mine has done 300k and is running well but I have been wondering how much more life is likely to be in it. By the sounds of yours, quite a bit!
FollowupID: 488080
Follow Up By: Member - Doug T (W.A) - Tuesday, Mar 13, 2007 at 22:35
MichaelR
No mate , no compression test done yet, I change oil every 10.000klm , Sometimes add half to 1 full ltr in that distance, when it begins to visually blow oil smoke then I guess I will know it's time is near, If it aint broke , don't fix it
FollowupID: 488082
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Mar 14, 2007 at 09:43
Doug,
Don't diesels burn oil anyway (light oil), a bit more won't hurt too much. :o)
FollowupID: 488136
Follow Up By: Member - Doug T (W.A) - Wednesday, Mar 14, 2007 at 09:47
Oldplodder
Like me you more than likely had a bloke say to you...Mine don't use oil. my usual answer to him is ,,well if it don't use oil it won't last long
FollowupID: 488137
Follow Up By: madfisher - Wednesday, Mar 21, 2007 at 21:56
Michael I seem to recall that when the 1hz was released it was desighed to do one million ks
Cheers Pete
FollowupID: 489665
Follow Up By: MichaelR - Wednesday, Mar 21, 2007 at 22:13
Thanks Pete/madfisher. Great news. I won't have to buy a new car for the next 20 years! Hopefully the rest of it will last as long.
FollowupID: 489671
Reply By: ross - Tuesday, Mar 13, 2007 at 22:02
The price of used 1HZ has been high but they are starting to fall.
They go from $2000 up to $5000 depending on which parts such as AC pump,starter motor and alternator are sold with it.
The turbo could turn some buyers away and attract others.
A compression test in writing from a qualified diesel mechanic will go a long way to getting the price you want.
It will be also easier to sell if they can hear it running before you pull it out.
If your selling the whole engine with all the bolt on peripherals I would ask for about $4k .If you dont want to haggle make it clear in your advert.
AnswerID: 227275
Follow Up By: fishaholic - Tuesday, Mar 13, 2007 at 23:18
cheers for all that, i'm just still having problems with it getting hot and have always wanted a V8 diesel so I thought I would start to get an idea how much it will cost and what are the pros and cons.
FollowupID: 488099
Reply By: Andrew from Vivid Adventures - Wednesday, Mar 14, 2007 at 12:16
$8,000 new at CMI in Adelaide (without after-market turbo of course)
AnswerID: 227371
