Clothes Airer & Towel Rail Mounting on Fibreglass C/van
Submitted: Wednesday, Mar 14, 2007 at 08:47
ThreadID: 43233 Views:3858 Replies:3 FollowUps:1
I am looking at fitting a towel rail and Flinbex pull out clothes/drying rack to a Fibreglass caravan. Is this possible and what advice or precautions do I need to do when fixing these items to fibreglass.
Reply By: Wizard1 - Wednesday, Mar 14, 2007 at 10:13
We fitted the slide in brackets for the clothes airer, which I assume is the one you mean, to the side of our van using pop rivets as the thin aluminium doesn't stand up too well to screws. Fibreglass tends to be a little stronger to screw into so you could just use some self tappers, stainless steel of course and a dab of silicon in the hole. Just don't drill in too far and use screws that are just long enough are the only recautions I used.
We have one pair on the outer side (driver's side) and another pair on the near side so when it rains and we can hang stuff under the awning. You can get the brackets seperately from Camec.
The other method could be to use Sikaflex adhesive/sealant to glue them on. It is a polyurathene sealant that they use in the construction industry. Its available from Bunnings. I wish I coild remove all the old putty used to seal stuff on the outside and replace it with Sika.
AnswerID: 227357
Reply By: Member - Kiwi Kia - Wednesday, Mar 14, 2007 at 14:39
If you can access the area on the inside I would make a sandwich by putting a strip of aluminium on the inside and bolting through (a) the towel rail, (b) the fibreglass & (c) the thin metal strip on the inside. This will spread the load along the length of the metal and prevent to bolts pulling through the fibreglass. Consider the aluminium strip to be a very long washer.
AnswerID: 227397
Follow Up By: Wizard1 - Thursday, Mar 15, 2007 at 09:08
That wouldn't really be possible without cutting a hole in the the internal panels which would be a little unsightly.
FollowupID: 488342
Reply By: richard cee - Thursday, Mar 15, 2007 at 23:42
Thanks guys, very helpful. Probably agree with Wizard 1 as access is limited or non existant. The clothes airer is the removable one with separate brackets.
AnswerID: 227770
