electric brake magnets
Submitted: Thursday, Mar 15, 2007 at 09:13
ThreadID: 43280 Views:14555 Replies:5 FollowUps:3
I don't know if this has been covered before, but how do you tell if the magnets need changing ? How far can they be worn down ?? How do you know how far they have been worn without checking against a new one ( which I don't have )
Got told by a trailer place that 1mm was the go ?? and if replacing magnets, may as well replace the brake shoes, and cost wise would be just as cheap to replace the whole backing plate with all that stuff on it !!! ( approx $100 a side )
Any thoughts ???
Reply By: Member - Doug T (W.A) - Thursday, Mar 15, 2007 at 09:30
I think your close about being not expensive, you should find all the info you need in the link
Site Link
AnswerID: 227609
Follow Up By: Member - bushfix - Thursday, Mar 15, 2007 at 13:59
G'day Doug,
that's a great site, conincidentally I had been wandering about it for a good part of this morning. Good bloke too Steve is.
FollowupID: 488386
Reply By: Ray Bates - Thursday, Mar 15, 2007 at 13:34
Hi. Some of the more modern brake controlers such as the Prodogy have readouts.
My son has a prodogy and his showed "Short" when his magnet required replacing but that is the exception due to bad maintenance.
I have electric brakes on my caravan and I check the magnets when I check the wheel bearings.
I have found that two sets of magnets will outlast one set of brake shoes. As per my son's work trailer. He is a self employed carpenter and the trailer is used every day
AnswerID: 227642
Follow Up By: Gronk - Thursday, Mar 15, 2007 at 13:47
When you say you check the magnets, what do you check ?? Or , what do they look like when you replace them ?? And is that right when you said you go thru 2 sets of magnets to every set of brake shoes ?? How do you know the magnets are due for replacing ?? Cause I'd like to know ???? Thanks......
FollowupID: 488384
Reply By: Gerhardp1 - Thursday, Mar 15, 2007 at 15:38
The magnets have wear holes in them. When you can no longer see the wear holes, they need replacing.
Can vary between 10,000k and 50,000k depending on how you use the trailer brakes, how heavy it is, flat country, hilly country, etc, etc.
AnswerID: 227664
Reply By: MEMBER - Darian (SA) - Thursday, Mar 15, 2007 at 16:17
I have Alko electric brakes on my campomatic - uses the heavy duty offroad magnets (rectangular shape with rounded ends) - just bought a pair to carry as spares for remote area travel - will change when required if I'm stuck - otherwise I can supply to a brake service centre when travelling. They are around $110 each magnet ! The metal face of the magnet has four small holes about 3mm deep - when they have gone the magnet should be replaced, but as said above, the controller might indicate magnet shorting just before that. Should be an easy field job - just cut the old magnet's supply wire and solder in the new unit.
Shoes are best bought as change-overs I'm told - about $100 for the set of 4 change over shoes I think - the only thing is that the brake drum MAY need to be machined a little, so a brake specialist might be best.
I carry bearings, seals and magnets, but not shoes.
AnswerID: 227672
Reply By: Max - Sydney - Thursday, Mar 15, 2007 at 19:46
Hi Gronk
I found a foolproof way to know - one of my magnets turned over and locked the wheel at 80 km/h on the highway between Kununurra & Turkey Creek. The smoke told me I needed to fix something!!
Before I left home, the magnets had rounded by I guess a mm or so from the centre and I foolishly said "That will do one more trip." Wrong.
1 mm sounds a good rule of thumb, but probably better to replace the lot (both sides) especially if you have been off road a lot. If the drum has grooves developing then you can't machine them as there is not enough meat so may as well replace them too. There is an off road magnet available now to prevent it roiling over and locking up - that would be worth it.
As others have said, the cost is not all that great.
Max
AnswerID: 227705
Follow Up By: Gronk - Thursday, Mar 15, 2007 at 23:48
Thanks for the info........the trailer place I was talking to quoted $106 a side for a new backing plate with all the gear on it ( magnet, shoes etc )
Sounds too easy, just undo 4 bolts and replace the whole lot !!
FollowupID: 488502
