Caravan Water Tanks
Submitted: Thursday, Mar 15, 2007 at 19:33
disco driver
Hi All,
I've recently bought an older caravan (Viscount Grand Tourer Poptop), used it a few times and found the
water tastes yuck even though I drained and flushed the
tank before use . I have drained and flushed the
tank a few times since but still get an "off" taste in the
water. (Hasn't made anyone ill but would like to play safe)
Is there a product or products out there that will ensure clean safe
water. I have considered flushing with a bleach (like White King) but am unsure of what ratio to use for this purpose.
Any advice before I buy a new
tank?
Disco
Reply By: Gob & Denny - Thursday, Mar 15, 2007 at 19:38
you can buy a lemon tasting ? cleaner for flushing the
water tanks with dunno where you are but in melb carac in dande or some of the caravan
places stock it but yes products are around
steve
227701
Reply By: Grandpa joe - Thursday, Mar 15, 2007 at 19:57
You can buy
tank clean from CAMEC or most caravan parts
places, I believe the main ingredient may be bicarb soda ?
Oh yeah .. Bias boating and whitworths stock it too I think.
227710
Reply By: aceman - Thursday, Mar 15, 2007 at 20:17
Hi Disco Driver
I would try some liquid sodium hypochlorite (chlorine). I am unsure of ratio but guesstimate maybe a quarter of a cup added to bucket of
water. Pour it into
tank then fill rest of
tank to the with fresh
water. Drain the
tank and let it stand empty for day or two allowing the chlorine smell to clear. Top it with fresh
water and see how it goes. If there is only a slight taste of chlorine to the
water, it should be ok.
(certainly better than an "off" smell) If taste/smell too strong then maybe
tank would need to flushed out a couple of times.
227716
Reply By: japmel - Thursday, Mar 15, 2007 at 20:42
You could try filling the
Tank with
water and adding a litre of Vinegar.
Tow the Van around the block a couple of time then flush the
Tank out.
It worked for me.
japmel
227724
Reply By: Member - Doug T (W.A) - Thursday, Mar 15, 2007 at 21:02
disco driver
If your using a near new garden hose to fill it you will get an ant type taste in the
water , I have a small
water filter fitted inline between the tap and the Van, [ i am stationary but can be removed in same time it takes to roll up hose ] It is
bore water where I am and not too bad for drinking but this filter just makes it taste a little better, I got it from Bunnings H/W and the inner filter is for taste only,If the issue was dirth
water then all one does is change the inner filter,
On the other habd if the
Tank is old and full of ancient mud, dead ants,and fungus then I would consider fitting a new one, most Caravan sales points will guide you in the right direction
227726
Reply By: Member - Doug T (W.A) - Thursday, Mar 15, 2007 at 21:04
Just found this site for you
Caravan Maintenance
Site Link
227728
Reply By: Member - DAZA (QLD) - Thursday, Mar 15, 2007 at 21:40
Hi Disco Driver
As G P JOE said, try Bicarb Soda, works all the time, even in plastic jerry cans.
that havent been used for a while.
Daza
227739
Reply By: live4theweekends - Thursday, Mar 15, 2007 at 21:44
Hi disco driver,
We use a product sold at caravan shops called "
tank clean". Basically it must be a bleach based product (smells like it anyway). We fill the
tank with
water and the
tank clean leave it for the advised amount of time and then drain the
tank. We pump the solution up through the taps to flush the lines as
well. We then rinse several times before using. We do this after every winter when the van hasnt been used for 6 months or so.
Hope this helps!
227741
Reply By: disco driver - Thursday, Mar 15, 2007 at 22:01
Thanks for all the information.
I knew that someone out there would be willing and able to assist.
Disco
227743
Reply By: madcow - Friday, Mar 16, 2007 at 07:44
You could also put in a bottle of "Miltons" baby bottle cleaner,refill and let it sit. You will have to flush it a couple of times to get rid of the aftertaste but it works fine. I use it on my camelbak occasionally to keep the bugs at bay.
227785
Reply By: Member - Robert A (QLD) - Friday, Mar 16, 2007 at 11:38
Hi Disco.
Any
water tank even hoses used to fill fresh
water tanks up should be super-chlorinated at a concentration of 50 ppm for a period of not less than 4 hours and then completely flushed out every 12 months.
Rob
227823
