Friday, Mar 23, 2007 at 01:18
As you say booring!!!!
peak to peak voltage is 2.8 x RMS No wonder PMG had trouble with phones!!!
Ohms law on .06 v and 10megohm input impedance chr!!st my calculator cant even work out how low that is. 0 Fn volts!!!!!!!!!!
Maybe you should do a Google. There are many electronic rust inhibiting systems out there
Spent a bit of time researching on line last night. Most of the systems that I found use electrostatic voltage on the steel to provide protection, NOT cathodic protection ( I seem to remember suggesting something like this B4).
"So the system operates by applying one of the principles of electrochemistry - that an oxidation reaction can be slowed or retarded by creating a surplus of electrons to the metal from a supplementary source.
That means that every possible seam, spot-weld, bolt, screw or panel that's earthed to the vehicle is protected from corrosion by this surplus of electrons. Parts that would be impossible to coat - like the inside of your exhaust pipe, the roof gutters, multi-folded panel seams - all come under the influence of this electronic field"
"The Rust Evader® module attaches to your regular car battery and draws about as much current as your cars clock. Over every 8 second cycle it emits a surge of "free" electrons throughout your vehicle to the very
places your car has lost its protective paint and coatings (through stone chips, scratches, and abrasions) and "shields" these exposed areas from harm. The charge is too small to be noticed, however the free electrons interfere with the rusting process and retard rust and corrosion significantly."
Another one says they use a combination of cathodic and sacrificial anode process i.e they have a small aluminium strip that is sacrificial and needs to be replaced.
"An adapted version of CP has been developed enabling protection in atmospheric conditions without a constant electrolyte. This technology, Directed Cathodic Protection (DCP) makes use of a clever combination of both sacrificial anode and impressed current technologies. Instead of relying on the electrolyte (
water) to provide a path for electrons to flow towards the anodes, a current is impressed onto the vehicle forcing the electrons to flow though the metal and towards positively charge anodes. The anodes corrode (sacrifice) and the corrosion process is interfered with."
From 4WD Monthly.
"Obviously, there's only one way to fully evaluate the CounterAct system, and that's to fit it to a vehicle and monitor any future corrosion. We're doing that right now but the fact is, that the longer you look at this technology, the deeper you dig both scientifically and from folks who are already using it, the better CounterAct looks. They don't promise to rid your life of rust forever, but if it can be retarded to the degree we believe is possible, then there isn't a four wheel drive in the country that wouldn't benefit from a CounterAct fitment."
CounterAct's electronic rustproofing systems have undergone extensive testing under rigorous conditions in both the lab and field. All Lab testing of CounterAct electronic rust prevention systems is done to recognized standards in prominent facilities that offer subjective conclusions that leave no room for doubt.
Independent Testing by: LACOR Corrosion Laboratory(UFRGS)
Porto Alegre, Brazil, 12-9-1987
Stds: ASTM D 1654
American Analytical Laboratories
Kent State University
Kent, OH 44242, 6-28-1990
Queensland University of Technology
Brisbane, QLD, Australia 4001
5-5-1995
Laboratory Report # HC1213
ETL Testing Laboratories
Div. of Inchcape Testing
Cortland, New
York 13045,
4-9-1995
Certified Test Report No. 561472
Stds: ASTM D1654
New Zealand Standards:-
AS/NZS 4251.1
Electromagnetic Compatibility
Certified Test Report No. 91051
2nd November 1999
Tested at: EMC
Services Pty Ltd
Quality Control : ISO 9002
"If the paint of a motor vehicle is damaged then the metal can become exposed to a number of elements that combine to damage or rust the metal.
The CAT rust prevention system protects your car by forming a "field" of electrons around your car as an invisible barrier.
Should the metal of your car become exposed to the elements (paint weakness or scratch.) the "field" provides the electrons sought by the
water and salts that are "attacking" your vehicle, thereby leaving your car intact and rust free.
The CAT Rust Protection System has been thoroughly tested in laboratories internationally
Stringent tests were carried out between 1989 and February 1991 in England in all weather conditions.
These tests were undertaken by Mr Donald Harrison C.B.E., D.F.H., M.I.E.E., C.E. who is an eminent Physicist, a member of the Institution of Electrical Engineers and a Chartered Engineer.
He has carried out physics and nuclear research at the Atomic Energy Establishments at Harwell in England and Wintrith in England on behalf of the British Government
Mr Harrison was subsequently Deputy Chief Scientist at the Department of Industry concerned with scientific research programs in Industrial and Government Research Laboratories and is very highly regarded by his peers in his field of physics.
Successful tests were also carried out in Australia by nationwide E.T.R.S. Metallurgists in 1991 and Material Insights Pty Ltd, Metallurgists, in 1997. C.R.I.Q. Laboratories in Québec, Canada in conjunction with expert scientists in this field. These scientists also carried out significant successful testing in 2000.
I guess these experts mean nothing to you but unlike Fitch and Hiclones they are happy to publish their independent testing results..
And I guess their qualifications are better than ours!!
Anyway cheers --- no more!!! finished --- done alldone.
good verbal joust!
Have another soon
Ian
489937
