Airbags on GQ's
Submitted: Saturday, Mar 17, 2007 at 15:15
ThreadID: 43344 Views:2703 Replies:4 FollowUps:13
Recently upgraded the MQ for a GQ and found airbag suspension under the back end. Having no owner's manual and couldn't find any info in the gregory's workshop manual - can anyone here give me any info especially p.s.i. into this set up?
Reply By: Andrew from Vivid Adventures - Saturday, Mar 17, 2007 at 15:35
even if you had Gregory's or Owner's Manual it wouldna mention airbag suspension.
Can you tell the brand? eg. Polyairs or whatever.
Anyways, they are to maintain the vehicle level, so the first point is, is the vehicle level?
www.redlands4wd.com.au/air_bags.htm
and
Site Link for Polyairs
Andrew.
AnswerID: 227992
Reply By: Alloy c/t - Saturday, Mar 17, 2007 at 15:53
Red bags = polyairs ,min 5psi at all times ,increase upto 30 psi max , inflate BEFORE hitching up load then lower pressure until vehicle level ,,,,,, Blue bags = Firestone ,bit more heavy duty ,10psi min upto max of 35 psi ,same deal as poly air re: allways have min psi to stop pinching bag and excessive rubbing.
AnswerID: 227994
Reply By: growler - Saturday, Mar 17, 2007 at 17:14
Thanks guys being a truckie and well aware of air bag suspension - the colour of the airbags are orange but i'd guess they were red at one stage.
Have 2 air lines set up one each side of the hitch (obviously for l/r) Then there is the handbrake style lever in the cab under the dash with instructions to pull to release stabilizer - does that mean that it dumps the air and u have to reinflate them again after?
AnswerID: 228006
Follow Up By: Kumunara (NT) - Saturday, Mar 17, 2007 at 17:34
Growler
The stabilizer release has nothing to do with the air bags. GQs have a stabilizer bar that can be released if needed depending on the terrain when 4WDing. Read your owners manual and all will be revealed.
Tjilpi
FollowupID: 488787
Reply By: growler - Saturday, Mar 17, 2007 at 17:42
As I said originally, I didn't get an owners manual and hence my post here in exploroz - now we've sorted the airbag issue out can anyone pls tell me what the stabilizer is how/what/when etc used etc?
Thanks to all who responded
AnswerID: 228008
Follow Up By: GQ_TUFF - Saturday, Mar 17, 2007 at 19:38
Hi mate having had a GQ....the stabilizer release does just that....it releases the rear stabilizer bar. Use it only in slow speed low range off road conditions, As it does affect the cars stability at road speeds. It lets the rear axle move with out stressing the stabilizer bar and in my opinion makes the car more comfortable over rough terrain. Some people have mentioned they have had trouble getting theirs to go back in after letting it out, but I can't comment on that as mine always went straight back in when the lever was put back in......but since it is a simple cable system which operates it it would just be a case off making sure the linkages, cable and springs are working right.
Cheers Stefan
FollowupID: 488798
Follow Up By: growler - Saturday, Mar 17, 2007 at 20:22
Thanks Stefan,only picked her up yestsrday and didnt want to push or pull to much till i can get hold of an owners manual to check it all out
FollowupID: 488806
Follow Up By: Truckster (Vic) - Saturday, Mar 17, 2007 at 20:32
if you didnt get a glovebox manual with it, I have one, and a gregorys manual.. dont need either anymore.
FollowupID: 488811
Follow Up By: Willem - Saturday, Mar 17, 2007 at 22:38
I wonder which models had the stabiliser bar release as mine does not have it. Mine is 1994 RX 4.2 Diesel.
FollowupID: 488836
Follow Up By: GQ_TUFF - Saturday, Mar 17, 2007 at 22:53
Mine was a 89 ST 4.2 petrol...and had the bar relese
FollowupID: 488841
Follow Up By: Member - Duncs - Saturday, Mar 17, 2007 at 23:33
I was told it was the ST and TI models that got the bar release.
Mine broke and Nissan wanted over $500 to buy a new ball joint so I ran around with the stabiliser bar disconnected for about 2 years. With the Polyairs I hardly noticed the difference. I ran the Polyairs at about 7psi 24/7.
Duncs
FollowupID: 488849
Follow Up By: Member - Barnesy (SA) - Sunday, Mar 18, 2007 at 01:11
My Brother's 89 GQ base model has the stabiliser release. My series II 1991 mid model range doesn't have it. Maybe it was only on series I or earlier years? Or maybe it was an option?
FollowupID: 488858
Follow Up By: SA_Patrol - Sunday, Mar 18, 2007 at 08:13
I think they only came out in the 88 to 90 models. Also they won't work well if 4by lifted more than 2inches. there is a light that comes on when engaged and turns off when disengaged, I know a few guy that disconnected theirs when cars lifted over 4 inches.
FollowupID: 488865
Follow Up By: growler - Sunday, Mar 18, 2007 at 15:30
Truckster, I'll buy both of you. Send me an email at fbasejag@msn.com if you could when ready.
BTW fellas it's an '89 ST Wagon Again thanks for the replies
FollowupID: 488914
Follow Up By: Truckster (Vic) - Tuesday, Mar 20, 2007 at 21:13
92 models also had the release.
I threw mine, waste of effort, you dont need swaybars, remember, your not drivign an F40 Ferrari...
manuals are here if ya keen..
FollowupID: 489403
Follow Up By: growler - Saturday, Mar 31, 2007 at 20:34
Trukster how can i get in touch ?
FollowupID: 491760
Follow Up By: Truckster (Vic) - Sunday, Apr 01, 2007 at 01:51
fu_kew
hotmail
com
throw it all together to email me....
FollowupID: 491800
