Simple camping tips & ideas.
Submitted: Sunday, Mar 18, 2007 at 09:49
ThreadID: 43364 Views:7645 Replies:10 FollowUps:9
Camping has always been a passion of mine for years. Give me a little dome tent over a 5 star hotel any day. I've always travelled light and kept the equipment simple. [ the kitchen sink stays at home ].
Sometimes I come across other campers that have or do things that, to me, are so obviously clever I kick myself for not thinking of it myself. eg:
A bloke had the bottom of a plastic milk crate cut out and a domestic toilet seat attached. Just found a private little place dug his hole and contemplated his navel for a while. [ simple and comfortable ].
Another bloke I saw had a 20ltr metal drum of water sitting next to the fire. Me figured a good precaution in case the fire gets away. Nope! hot water on hand for washing up etc. [ simple ]. Just thinking of the times I've boiled a billy with gas while theres a fire right next to me, [ dipstick ]!!!!!!
Just wondering if others have or have come across clever little ideas that are so uncomplicated and seem to sit below the radar.
Lionel.
Reply By: Mike Harding - Sunday, Mar 18, 2007 at 10:21
My shower consists of two pieces of wood screwed together at about 45 deg, one piece slots into the hollow roof rack cross bar which give me a shower arm about 3' out from the vehicle at 6.5' high. Onto the end of this fits a $20 shower head (simple bent ally bracket) and the pump goes into a bucket of warm water. A 6' x 4' tarp provides a clean floor. Cost = about $5 plus shower, takes about 2 minutes to set up and take down, works very well. In mixed company you can use the car as a bit of a screen - don't remind the women you can see through both windows if the tint is not too high :)
Mike Harding
AnswerID: 228099
Follow Up By: Mike Harding - Sunday, Mar 18, 2007 at 10:48
Two others:
my light stand consists of a carpenters 200mm clamp (Supercheap $3) into the bar of which I drilled 3 x 4mm holes and used small nuts and bolts (M3) to attach a piece of light wood about 5' long and 25mm x 10mm. The top of the wood (the end opposite to the clamp) has a small hook screwed into it.
The clamp attaches this assembly to my camp table and from the hook I hang my 12V fluro light thus providing light without shadows exactly where I need it when cooking. The clamp assembly is not strong enough for my Coleman dual fuel lamp but works perfectly with low weight electrical ones.
Gas fridges need to be LEVEL to work properly so I keep a 150mm $2 shop spirit level inside mine for that purpose. To level the fridge I have two wedges which I cut from a piece of soft timber about 75mm long x 50mm high x 20mm wide. I saw through the block on a diagonal line and, hey presto! two wedges :) Trouble is I keep forgetting to pick them up when I put the fridge back in the vehicle (up to about my sixth set by now) - so if you find a softwood wedge in the bush you'll know Harding was there :)
Mike Harding
FollowupID: 488890
Follow Up By: Mike Harding - Sunday, Mar 18, 2007 at 12:59
While I’m at it:
Liquid soap for hand washing – easier than bar soap
If I’m in one spot for a week or more and it’s summer I’ll usually take a screen house to cook and eat in to keep the flies off. These normally have zipped doors and it’s a pain zipping and unzipping every time I go in/out so I use one of those fly “curtains” instead: a plastic bar at the top and loads of plastic strips hanging to the ground – fixed to the screen house frame with a couple of bits of wire.
My queen size self inflating mattress is a devil to roll up to a small size so I use a Coleman high speed airbed inflating pump in reverse to suck air out of the mattress as I roll it. To ensure a seal between the pump and the mattress value I found a sink plug which nicely fitted into the valve then bored a hole through it which was slightly smaller than the pump nozzle – forced the pump into the sink plug and the plug into the mattress valve and it seals well.
Two or three small 7Ah batteries (Jaycar cat #SB2486 $20) are much more convenient for shower, lights etc than taking lots of wiring back to the vehicle. They can be easily charged with a simple lead to connect them to the cig. lighter socket. Just do a direct connection.
My camp “coffee table” is a piece of marine plywood about 3’ x 2’ which sits on top of a plastic box I pack my “dirty” stuff into. Takes up almost no room in the vehicle and is a very useful flat surface in camp.
Persuading damp wood to burn can be a problem. I use a mixture of old sump oil (old works better than new!?) and kerosene 50/50, about half a cup per fire. Ensure you put some paper (a tissue is good) in the middle of the fire and pour some of the mixture onto it but most onto the wood. Light the paper and enjoy a great fire :)
Mike Harding
mike_harding@fastmail.fm
FollowupID: 488903
Follow Up By: Member - Duncan W (WA) - Sunday, Mar 18, 2007 at 19:50
Mike I have a bottle of liquid soap taped to my spare wheel carrier. Easy to access. Also have some liquid soap and water in an old dishwashing liquid bottle which is great for washing hands and also the dishes. Don't need any extra water to rinse either.
Also those of you who carry water fire extinguishers, add a couple of table spoons of dishwashing liquid to the extinguisher next time you fill it, and you will be amazed in the increased efficiency of your water and it's ability to extinguish a fire.
Dunc
FollowupID: 488967
Reply By: Member - Uncle (NSW) - Sunday, Mar 18, 2007 at 10:38
Hi Lionel, we have a simple, slightly more comfortable, dunny for swmbo, no 1's only though so there's no rummaging around in the bush at night for her.! 20 litre bucket with a split garden hose round the top, pics on our profile page, thinking of upgrading to a 25 to 30 litre though to get the knees off the floor a bit!
cheers Unc.
AnswerID: 228100
Reply By: Sparkie C - Sunday, Mar 18, 2007 at 12:48
The milk crate toilet is great and we have used it for years ,we line the inside of the crate with newspaper folded carefully under the seat this makes cleaning up simple ( especially with people who have trouble with aim) and the degradable paper is put in the hole when backfilling at the end of camp. Like everyone says KISS
Cheers Sparkie
AnswerID: 228114
Follow Up By: greggu - Sunday, Mar 18, 2007 at 13:45
mate
its best to burn the paper - wild animals pigs dingos foxes etc did up human waste and the paper blows everywhere - which is why toilet paper litters so many wilderness camp spots
seee you greg
FollowupID: 488906
Reply By: Member - Mick O (VIC) - Sunday, Mar 18, 2007 at 13:19
Hey is there a page on exploroz dedicated to collating all these tips? I've done a cursory search but you have to search upwards of several hundred posts in each catagory. What about a simple page where each tip can be added into a list rather than have to search posts. What do you reckon? It'd be a great and easyway to tap into members expertise. Cheers. Mick
AnswerID: 228118
Follow Up By: ExplorOz Team - Kerry W (QLD) - Sunday, Mar 18, 2007 at 14:04
Hi Guys
There is a way to post feedback and ideas into every article and topic posted on the site.
eg http://www.exploroz.com/OntheRoad/Etiquette/TravelEtiquette.aspx#Send_Feedback
As you notice we do listen to your ideas and it is quite possible to create a readers tips Index page (Its just the time to do it) but It would have to be tagged onto the end of a long list of ideas we are already implementing and David would need to Ok it.
If you look around the site is very interactive, you can post feedback on Road Conditions Trek Notes.
Another great feature - you can add Points Of Interest (POI) free camps, mountains, roadhouses, crossings, etc etc and Post Photos of all the POI's in the Places Search Index.
Good ideas everybody
Kerry W
Kerry W (Qld)
-Helen Keller
FollowupID: 488908
Reply By: JimDi - Sunday, Mar 18, 2007 at 14:28
Lionel,
A mate of mine uses a similar idea to the metal drum. He managed to get hold of an oldish aluminium beer keg cut out the top and last time up north towards the cape it kept 3 campsites with a constant supply of hot water for washing showering etc and then served as a storage bin on the way home.
Jim
AnswerID: 228125
Reply By: Member - Stephen M (NSW) - Sunday, Mar 18, 2007 at 17:44
Hi there Lionel, the only problem with keeping the drum on the fire is you waste alot of water with evaporation. This is fine if you have a river, stream, etc where water is always available but if relying on the water you take with you then you will run out quick. My wife and I just use the billy full of water boil it up then pour into a 15L bucket and fill the rest with cold water works out just the right temp for both of us and this will also be enough water for the two of us. We use to use the milkcrate set up but in the end wife decided on the porta loo which I must admit is great if she needs to tinkle through the night as she doesnt wake me up to go with her while she finds a spot, she just wips out the camper door into the toilet tent while I'm still snoring brillant. I had a little bracket made up just inside the rear door on the hilux with a soap on tap set up, no mess. We use the little batterys for the shower instead of having to move the car to the right spot etc I just clip the pos/neg on to the battery inside the shower tent then wack on the invertor if need to recharge but normally these battery will last me over a week running the shower (primus). All the little tips help here and there and can some times save us with extra luggage. Now that we have the prado will have to work out what goes where Was ok with the lux and canopy fill her up of we went. Have to invest in a fridge slide and stuff now as just use to whack fridge on back seat of hilux whack the seatbelt around it as the lux was too ohigh to have in rear tray had to climb up all the time was a killer on the knees, at least with the prado open rear door slide out the fridge nice height. Regards Steve M
AnswerID: 228155
Reply By: Jimbo - Sunday, Mar 18, 2007 at 20:30
A few of my simple tips to make camping comfortable.
A caravan with aircon
Breadmaker
80 L fridge/freezer and the fridge in the van of course
Generator to run the aircon, bread maker, charge the aux battery, hairdryer etc.
Porta Dunny
Coleman hot water service
Coleman camp chairs (they're like armchairs)
Chivas Regal or The Glenlivet, depends what is on special
Solar Panel
Two aux batteries, one in the van and one in the car
A good quality fluoro light
And, and, and lots more.
The whole lot takes less time to set up than a tent.
I once read somewhere, "any mug can be uncomfortable in the bush".
I'm no mug LOL.
AnswerID: 228184
Follow Up By: Pajman Pete (SA) - Monday, Mar 19, 2007 at 10:25
"I once read somewhere, "any mug can be uncomfortable in the bush". "
That would be my signature line - and it is a genuine quote from a old fencing contractor I met the Miles campground in Queensland at 4:00am. It was a freezing night and I had been driven out of my tent by the cold and was walking around to warm up. He was down in the creek bed next a blazing fire and invited me down for a cuppa. We spent the next 2 hours yarning (well him talking and me listening!)
It was all time well spent.
Pete
FollowupID: 489082
Follow Up By: Jimbo - Monday, Mar 19, 2007 at 21:25
Very good Pete, now I know where I saw it.
If camping is uncomfortable, well, why would you do it?
The concept of suffering whilst on holiday is not appealing to me, or more importantly 'er indoors.
ATB,
Jim.
FollowupID: 489184
Follow Up By: Glenn (VIC) - Wednesday, Mar 21, 2007 at 12:12
You forgot to add Aldi beer mate....hahahaha
FollowupID: 489512
Reply By: Scrubcat - Sunday, Mar 18, 2007 at 21:51
I have used mike`s method, but now find it easier to take some pieces of rubber car tyre inner tube about 100 mm x 100mm ( any size you like) for lighting the fire when the wood etc. is wet, it will burn hot and will light even after being dipped in water.
I also take a small bucket (4 gal paint tin with lid ) of lime , just spread a small amount in the toilet hole after use and it stops all smell ,flies, etc. and the hole lasts much longer.
Scrubcat.
AnswerID: 228212
Reply By: Member - Phil G (SA) - Monday, Mar 19, 2007 at 09:50
If you're heading into desert country, can I offer some water saving tips:
#1 Have a 500ml spray bottle handy - use it for cleaning cups, morning tea and lunch stuff, and giving the face a spray. Cleans up with almost no water.
#2 Handwashing - we use "Aqium" antibacterial handcleaner - its 66% Alcohol, so don't drink it :-)) Its simply a gel that cleans your hands and then evaporates away so you don't need water. Its used in all the hospitals these days, and you can buy it from the chemist. Lasts a long time.
#3 Showers - Buy a 4litre Hills garden sprayer from Bunnings ($17) and cut the metal wand to a shorter length. Fill it up with warm water (usually one billy of hot and two of cold), pump up the pressure and we usually need 1.5 to 2 litres of water for a normal shower. The wand has a nice trigger so you only use minimum water.
AnswerID: 228270
Reply By: Member - Julie P (VIC) - Monday, Mar 19, 2007 at 16:38
Not on the subject of loos or washing - but I have found that there is nothing better than drinking a glass of red from a real glass - plastic just doesn't taste the same does it - to protect your glasses - carry them in stubby holders - we find that two stemmed glasses in stubby holders fit nicely into the smaller square drawer in our crockery etc cupboard.
jules
AnswerID: 228359
Follow Up By: Mike Harding - Monday, Mar 19, 2007 at 17:09
Thanks for that one Julie. I always use to take a wine glass but I broke so many over the years on the rough stuff that I gave up and resorted to plastic wine glasses - just not the same, I agree. I'll try the stubby holder.
Mike Harding
FollowupID: 489130
