Shellite
Submitted: Monday, Mar 19, 2007 at 12:47
ThreadID: 43400 Views:5026 Replies:9 FollowUps:3
G'Day all,
been progressing with the new coleman, its great with my bbq plate on it, weekend was very windy no flame probs as on old jackeroo.
Using coleman shellite, decided against ULP as we are all diesel, and read of generator probs with it over time, and every 4th tank to be shellite so decided to just stick with it.
Question is, do you have to buy coleman or does anyone else use a good generic brand readily available?
Quite happy with the coleman and will continue to buy if need be, but always interested in saving a bit, if not at expense of quality. (noticeably of course)
Rgds
Ron
Reply By: Member - Phil G (SA) - Monday, Mar 19, 2007 at 13:08
I've gone back to ULP, but the Coleman fuel at $15 for 4 litres (US) is about the same price as Diggers Shellite for 4 normal litres.
The hardware stores rip you off for shellite, so I used to buy it from the local camping shop. But I've heard you can buy it in 20 litre drums thru Shell servos. You'd have to be using the stove heaps to justify this though.
AnswerID: 228308
Reply By: Groove - Monday, Mar 19, 2007 at 13:56
I have never used the coleman brand only the diggers. Usually get it from supermarkets or hardware stores and have never had any trouble with it, have been using the same coleman now for about 9 years and its going strong.
Yes its more expensive than ULP but I like you run diesel and much prefer to cary shellite than petrol. A little bit goes a long way so the cost isnt a big issue, it doesnt stink as much as petrol and spills seem to evaporate cleanly without leaving any smell behind.
AnswerID: 228314
Reply By: Robin - Monday, Mar 19, 2007 at 14:09
Hi Ron
Used mostly brands from supermarket here as only time I tried unleaded it seemed to clog up.
Price seems to vary a lot from $2.85 generic, up to $7.95 / liter for Coleman at some camping shops.
Robin MIller
AnswerID: 228315
Reply By: Member - bushfix - Monday, Mar 19, 2007 at 14:38
if you can find a petroleum distributor willing to accomodate a customer such as yourself, I believe their name for this stuff is Solvent 143 and you may be able to score a 20L drum to save some dosh.
AnswerID: 228326
Reply By: Camper - Monday, Mar 19, 2007 at 17:24
A good option would be to refill the Shellite container with unleaded every second time to bring the cost down and is more convenient. I have only used Shellite a couple of times and on the rare occasion when I have had problems it came down to tipping the tank out and putting fresh fuel in ...problem gone.
Note: If you leave the generator tank in the rain, next time you pump it up to pressure you can get water in the tank from the pressure plunger and this will give you a dirty yellow erratic flame.
If you do eventually use unleaded just make sure it is from a reputable servo and if any is left over after a trip, use it to top up the lawn mower that way you have to get fresh stuff for the next trip (can be done while the oiler is being topped up).
hope this helps.
AnswerID: 228371
Follow Up By: Camper - Monday, Mar 19, 2007 at 17:41
By the way a new Generator tube for the powerhouse model is only about $14.00 so if you only use unleaded and do have a problem with your Generator tube well into the future, the 14 bucks has already paid for itself as I also found with my coleman dual fuel lantern generator tube after regular use of only unleaded for the last ten years. (lantern generator tube $12.00)
I just can't get over the mark up price on shellite, it doesn't even have road tax on it and look at how much it costs per litre.
FollowupID: 489137
Reply By: Ron173 - Monday, Mar 19, 2007 at 18:42
Thanks to all again for a good set of replies,
I know the ulp is a good option and generator cheap, but I dont want to carry petrol, plus in an application like the coleman, there are soooo many additives and c@#p they put in ulp now you just dont know.
I also agree the shellite is exy but still very acceptable, and like said above if spilled seems to evaporate without any smells or stains, its a great option to gas and I'm just loving not having a milk crate in back of ute with gas cyl in it!!
So seems the supermarkets are the go, I will check em out n see whats avail locally.
Bought colemans originally so will use the good can to top up.
Any pref for supermarkets that stock .... coles??
Rgds
Ron
AnswerID: 228393
Follow Up By: Member - Au-2 - Monday, Mar 19, 2007 at 19:03
Hi Ron, I use Shellite a lot around the house for things like dry cleaning greasy spots on clothes b4 washing, wiping the stove after oil cooking, getting glue/labels off things, under house for grease/oil spills under car when filters changed, wiping hands after same and started to run out. After searching Woolies--Coles found it not stocked, but was lucky last week to find it in an I G A supermarket. I bought the 3 bottles that were left on the shelf. I don't know where you are but this was in Qld.
OzeSheila.
FollowupID: 489157
Reply By: Brew69(SA) - Monday, Mar 19, 2007 at 19:50
Every 4th tank shellite???? Bollocks
If you fill the coleman tin with shellite, then why not fill it with ulp?
AnswerID: 228411
Reply By: chips59 - Monday, Mar 19, 2007 at 21:57
i buy my shelite from diggers direct in 20 lts with no problem. this is the Adelaide store at wingfield.
AnswerID: 228445
Reply By: pixiemops - Tuesday, Mar 20, 2007 at 10:32
Use ULP I do with no problems for years in both the stove and lantern. And as mentioned above if any problems the generators are so cheap and even a sinch for a non mechanically minded person like me to replace.
AnswerID: 228519
Follow Up By: Member - Andy Q (VIC) - Tuesday, Mar 20, 2007 at 11:54
Yeah! I'm with you pixiemops, never had any problem with using ULP, I ought two new Colemans about 5 years ago, not once a problem with ULP, have a 70 year old Coleman as well, no probs with that either
andy
FollowupID: 489262
