marine gps chartplotters
Submitted: Monday, Mar 19, 2007 at 18:11
Member - Phillip S (WA)
Has anyone considered using garmin or lowrance large screen gps chartplotters in 4WD's..........I would like to hear from you.....what model....what mapping...etc....and how you found them....any good or not...thankyou
Reply By: Member - Oldplodder (QLD) - Monday, Mar 19, 2007 at 18:20
Did look at it.
Didn't go through with it.
Not sure what mapping software available.
228384
Reply By: Member - Doug T (W.A) - Monday, Mar 19, 2007 at 18:29
Try this site mate
www.ja-gps.com.au/garmin_3006_3010.html
The GPSMAP 3006 ($3450) or 3010 ($4310)
I suppose if you had one of these
228386
Reply By: Member - Doug T (W.A) - Monday, Mar 19, 2007 at 18:41
This one also takes street mapping and is much cheaper
www.ja-gps.com.au/garmin_map298.htm
228391
Follow Up By: Member - Doug T (W.A) - Monday, Mar 19, 2007 at 18:48
Remember they don't do voice guidence navigation but would be really great with Tracks4Australia installed
489153
Follow Up By: The Explorer - Monday, Mar 19, 2007 at 19:12
Plus it has depth sounder - good for
creek crossings:)
The now discontinued Magellan FX324C Chartplotters were popular - you could run DiscoverAus from them. Main issue of using a plotter is of course they are bolted to car. If you have any plans of moving more than 10 metres away from the car to do some real exploring you will need a handheld as
well...so a more universal set up (eg PDA or Large screen handheld GPS) is the better value for money.
489158
Follow Up By: Member No 1- Tuesday, Mar 20, 2007 at 07:37
i think i'll get one with a sounder
489216
Follow Up By: Member No 1- Tuesday, Mar 20, 2007 at 07:41
the 296 does voice
489218
Follow Up By: Member - Doug T (W.A) - Tuesday, Mar 20, 2007 at 09:02
Member No 1
Rap on knuckles for you .......the 296 is an Aviation gps, it's size is the same as the GPS Map 276C ,
Phillip wanted large screen Marine unit'
Anyhow this unit would be no good for you Member No 1 the warnings would be going off constantly.... ...so sorry , ya can'y have one
[ Garmin delivers terrain awareness in an intuitive Terrain mode on the GPSMAP 296. The unit combines GPS position, GPS altitude and topographical mapping to give pilots a vivid depiction of potential terrain hazards. ] [Terrain proximity cautions and alerts pop up as digital thumbnail images in the lower left-hand corner of any page whenever a potential
hazard conflict looms ahead. ]
www.ja-gps.com.au/gpsav-map296.html
489235
Follow Up By: Member No 1- Tuesday, Mar 20, 2007 at 09:07
it also says...."Now with voice guided mapping for vehicles, etc etc"
and it is large screen...its defintiely larger than my hand held
489237
Follow Up By: Member - Doug T (W.A) - Tuesday, Mar 20, 2007 at 09:15
Your gonna end up in that fish pond ....... without a GPS if ya , if ta gonna be Cantankerous,
489240
Reply By: Robin - Monday, Mar 19, 2007 at 19:09
Hi Phillip
Friends of
mine use the Navmans , which come in a large variety of screens and work pretty
well - but with generally less options as regards mapping than Garmins. 5-7 inch VGA screens seem to be most popular , usually $1000 up.
From work I've done I've decided that Garmin 3.8 inch screen model 276c and its cousins are the best around.
Site Link
Robin Miller
228397
Follow Up By: Member - Doug T (W.A) - Tuesday, Mar 20, 2007 at 09:06
Robin
You have done your work
well
489236
Follow Up By: Member - Doug T (W.A) - Tuesday, Mar 20, 2007 at 09:11
The Navman would on,y be suitable for Marine use , Knowing the quality of Navman's you probably can't install any other mapping software except marine.
489238
Reply By: Member No 1- Tuesday, Mar 20, 2007 at 07:55
looking at robins link above you can get a 25w radio with gps?...but who would you talk to...unless you all had same frequency :))))
228488
Reply By: Rod W - Tuesday, Mar 20, 2007 at 09:59
I'm not up with the gobbledegock on chart plotters etc, but for the last 3yrs or so I've had and use a Furuno GP32, for what I want it works a treat.
228511
