Re: Warning Hilux 2nd battery installation PostID: 43282
Submitted: Monday, Mar 19, 2007 at 19:14
Member - qld_bushpig
I have had the modification done today on the battery tray. It has 2 extra brackets attached to each side of the tray. One is bolted in three
places under the top of where the mudguard meets the wheel arch where all the electical cables are located. The other side has a new bracket with two bolts onto the side of the wheel arch (as opposed to the top of the wheel arch) and a third bracket at the other end of the tray. So now the weight is directed downwards onto the sides. There is no weight on the top of wheel arch its self. Hope this makes sense. !MPG:12!!MPG:13!!!MPG:14!
Most important thing is remove the weight from directly on top of the wheel arch.
Contact me if you need further info
Jack
