Tyre Pressures Gibb River Road
Submitted: Tuesday, Mar 20, 2007 at 10:35
Birdy
Thanks to all of you who replied to my post about how many spares to take on the year long trip around Oz including the GRR and
Cape York. I guess this would be the second part to that post.
What tyre pressures would you recommend for :
A -
Gibb River Road
B -
Cape York
Will be in 80 series Landcruiser (petrol) with Coopers ATR tyres on 16 inch rims
The other queston I have is this :
C - On a year long trip would the Coopers ATR's be better replaced with tyres with more aggressive tread pattern ??
Thanks again
Birdy
Reply By: Voxson - Tuesday, Mar 20, 2007 at 10:50
26ish......
228529
Follow Up By: Member - Kiwi Kia - Tuesday, Mar 20, 2007 at 12:28
I agree
489267
Reply By: MEMBER - Darian (SA) - Tuesday, Mar 20, 2007 at 11:00
I'm with Voxy - we usually run 26F and 28 R, on the 245/70/16 BFG's.
228531
Reply By: Topcat (WA) - Tuesday, Mar 20, 2007 at 11:53
Hi Birdy,
I'm running the same rubber as you (on a Troopy) & (you will find tyre pressures on this
forum is a very contraversial subject) it all comes down to road conditions (bitumen,gravel,sand) & the load on your vehicle (light or heavy). My vehicle is loaded heavy (full tanks,
camping gear) & I run my tyres hard on bitumen (45PSI back/40PSI front) & drop the pressures 4-5 PSI on gravel. I also go by the 4PSI rule - the tyre pressure when cold should not increase more then 4PSI when running hot. Using this method I'm getting good milage out of my tyres. If you are travelling long distances mainly on bitumen (70% bitumen/30% off road) on your trip then IMHO you need not to go for an aggressive tread pattern. Hope this helps. Cheers.
228542
Follow Up By: Member -Signman - Tuesday, Mar 20, 2007 at 15:53
45/40 on the 'blacktop'?? Is that the cold or hot pressure??
I find 36 cold F&R comes up nicely to 40 when hot..Not fully loaded !!
489307
Follow Up By: Topcat (WA) - Tuesday, Mar 20, 2007 at 16:46
That is hot pressures. Fully loaded I'm 3.3 tonne.
489320
Reply By: Member - Steve T (NT) - Tuesday, Mar 20, 2007 at 12:01
Hi Birdy
This was debated a few days ago on thread 43368.
Cheers Steve.
228544
Reply By: Blaze - Tuesday, Mar 20, 2007 at 19:41
Hi Birdy,
In a Ute, Traytop which is usually heavier in the rear than a wagon, I run 24F and 28R. In a wagon I would change that to about 26 all round, GRR and CY the same, and yes I wouldn't use ATR's on either the GRR or CY
228648
Reply By: Member - Robert A (QLD) - Wednesday, Mar 21, 2007 at 04:28
Looking over old threads Tires and tire pressure get lots of different replies.
In my experience, part of being a ringer on cattle properties when I was younger.
Driving Toyotas that hardly ever seen a black road.
Adjust tire pressure to the road you are driving on at the time, wet / dry or corrugated.
Everyone can say this pressure worked for me at this time, but it could be totally different when you are there on the same road.
Defiantly softer tires are more comfortable, but are more prone to side spiking as
If I plain a big trip I like to have new tires. One big trip was when we done was from
Airlie beach out to
Longreach then up through to
Cape York, down to
lawn hill, over hells
gate road house road all the way to
Darwin. Not one flat tire.
3 1/2 Months of driving.
Couple of the biggest killers of tires is speed and tree roots.
I even seen allot beads blow on cattle grids.
So my advise is take a good compressor and adjust as you need.
Rob
228733
Reply By: Patrol_Driver - Wednesday, Mar 21, 2007 at 07:08
Are your ATRs LT construction or Passenger?
I made the mistake of being sold Passenger construction and the sidewall bulge is appalling when you drop the pressure. The tread blocks also rip off like cheese on rocky surfaces.
I destroyed 2 ATRs on a recent Simpson/Flinders trip and after much complaining to the Coopers distributors they agreed to refund me the balance of the tyre warranty on the two tyres.
228736
Follow Up By: Birdy - Wednesday, Mar 21, 2007 at 14:29
Not sure - How would I know ? Will look at tires tonight and see
489551
Follow Up By: Birdy - Thursday, Mar 22, 2007 at 13:57
Checked em' last night and they are "LT"s so hopefully they are ok ??!!
489785
Follow Up By: Patrol_Driver - Thursday, Mar 22, 2007 at 14:05
Hopefully you will be ok with the LT version.
489787
Reply By: BUGGER ME - Wednesday, Mar 21, 2007 at 11:25
hi birdy
always measure the foot prints of your tyres, make sure they are the same.
depends on what wieght you are carrying ( heavier in the rear the more air required ) to give same foot print as the front (with less air) you will get a lot more out of your tyres and a lot better ride, enjoy your trip
BUGGER ME
228773
Reply By: crocket - Thursday, Mar 22, 2007 at 16:44
I did the
Gibb river rd 2yrs. ago I found adjusting pressures for ride and traction was the go.All so, stay in the middle of rd.where the rocks are worn round from traffic. It might be rougher but no pointy ones in your walls.CROCKET.
229024
