Pop Top Vinyl Cleaner
Submitted: Tuesday, Mar 20, 2007 at 14:11
meercat
Can anyone recommend how to clean the interior/exterior of a vinyl pop top. I have heard that you shouldn't use anything other than
water otherwise it removes the waterproofing but using just
water isn't good enough to get the caked on dirt and grime/mould from it. I was thinking of using diluted white king or dish detergent but before I did, wanted to know if anyone else has other suggestions. Thanks
Reply By: Member -Signman - Tuesday, Mar 20, 2007 at 15:26
Diluted 'Shower Power'.
228584
Follow Up By: meercat - Tuesday, Mar 20, 2007 at 22:52
Will this affect the vinyl waterproof coating (if it even has one)?
489431
Reply By: oldpop - Tuesday, Mar 20, 2007 at 16:53
There is a product made by Applied Chemicals called Curtain Clean made for for doing tautliner curtains Very good available at most good truck shops
228605
Thanks for your tip - will investigate
489432
Reply By: swagman - Tuesday, Mar 20, 2007 at 18:03
i have recently tried these products and i am happy with the results they have a leather and vinyl treatment and i have used it on my tonnoue cover and my vinyl cover on my camper and it has cleaned it up and put a shine on it again.it also has a conditioner in it and uv protection.thought you might like info on it
link below
https:// www.driwash.com.au/index.php
228625
Follow Up By: meercat - Tuesday, Mar 20, 2007 at 22:53
Thankyou
489433
Reply By: Member - Doug R (QLD) - Wednesday, Mar 21, 2007 at 06:57
I've just discovered that tyre foam brings up the vinyl in my '80 Landcruiser a treat.
228734
