Patrol 4.2 D
Submitted: Thursday, Mar 22, 2007 at 13:53
ThreadID: 43514 Views:3059 Replies:7 FollowUps:4
Just a quick one, my father inlaws GU patrols sub fuel light stays on and he cant pump fuel from the sub to the main tank.
he has checked the fuse and thats fine, does anyone think it could be the pump or could it be something else.
Cheer's
Kev
Reply By: pepper2 - Thursday, Mar 22, 2007 at 14:02
Check the earth wire from the pump,it has been reported before as causing this.extra earth wires on the patrol can help.
AnswerID: 228997
Reply By: dan26aus - Thursday, Mar 22, 2007 at 14:35
try disconnecting the battery, wait a minute or two, then reconnect....
AnswerID: 229002
Follow Up By: Member - andrew B (Kununurra) - Thursday, Mar 22, 2007 at 15:08
Yep, this worked on the brother in laws, although I have heard yo may need an hour or so for the computer to reset. Aparently when the fault is not caused by the earthing, it can be caused by leaving the tank empty for extended periods. The computer shuts down the system rather than run the pump dry for a few seconds every time you start up. Will gladly stand corrected on this one though.
The brother in law didn't fill the sub tank often, only on big trips. To me it would be better to have fuel in the tank all the time, generally, if I've gone to the trouble of stopping at the servo, I may as well fill the thing up so I don't have to come back for a while...
Cheers Andrew
FollowupID: 489793
Follow Up By: GU-Nissan - Friday, Mar 23, 2007 at 16:45
As the owner of a '99 4500 petrol GU, I also suffered this problem on one occasion, when the car was only a few months old. Took it to the stealership (no, not a typo) and the solution was to disconnect the battery for I think about 15 minutes.
I have not had it happen again.
Much later I was advised to always keep at least some fuel in the sub-tank as the computer runs the pump for approx 5 secs every time the car is started, and the pump can be damaged by dry running.
FollowupID: 490068
Reply By: Member - Dunworkin (WA) - Thursday, Mar 22, 2007 at 15:52
Hi Kevin H, that happened to ours after coming off of the CSR thought that we had enough fuel to get to Fitzroy, pressed the sub tank and light came on but fuel in subtank stayed right where it was. We tried other things (such as above posts) but to no avail, had to drain sub tank manually and poor into main tank with bucket and funnel. Result Pump had gone, quoted new one from Nissan. around $700 dollars, checked wreckers, surprisingly got one for nearly $200, has been in for about 18months now and is going well.
Hope that helps
D
Simba, our much missed baby.
AnswerID: 229018
Reply By: Member - Kevin H (WA) - Thursday, Mar 22, 2007 at 16:55
Thanks to all the problem has been fixed, he disconnected the battery and it all works again.
Thanks once again
AnswerID: 229025
Reply By: donks1 - Thursday, Mar 22, 2007 at 17:41
sorryy to dissapoint you but 9 times out of 10 it will be the pump....
did heaps of them under warranty
donks
AnswerID: 229042
Follow Up By: Grungle - Friday, Mar 23, 2007 at 08:13
I've done 2 pumps. Pulled one apart to see why they were failing and they are not constructed like a normal pump. These pumps have a circular solenoid with a metal tube that runs through its centre. In the metal tube is a sliding metal tube with a one way valve on it and a spring. The whole operation is controlled by a circuit card which pulses the solenoid when the sub tank is activated. This draws the valve tube towards the inlet where it picks up fuel when the solenoid is energised. When the solenoid relaxes the valve tube springs back bringing a small amount of fuel with it. The cycle is repeated and you end up with a trickle of fuel going into the main tanks filler hose.
The pump was very difficult to dismantle and is filled with spacefill foam. I haven't tested the solenoid or circuit board yet to find out what is failing but probably wouldn't bother due to the hassel it took to get it apart.
Mine has failed again so I will now use either an aftermarket rotary pump or pressurise the tank with a couple of PSI from the compressor and valve arrangement which will be the easiest and cheapest solution. Will also be the most reliable as well.
David
FollowupID: 489964
Reply By: Member - beachbum - Thursday, Mar 22, 2007 at 18:43
More times than not this supposed faulty pump problem was missdiagnosed and pumps replaced when in reality it was indeed a confused computer chip. As previously stated, disconnect the battery, sit down and have a cooling beverage, reconnect battery and problem is solved and it is invariably caused by the reserve tank being totally empty.
Travel safely
AnswerID: 229057
Follow Up By: Grungle - Friday, Mar 23, 2007 at 08:42
I agree.
To diagnose a faulty pump, the best way to check is turn the sub tank pump on when the car is running and open the fuel filler to the main tank. If you can see fuel coming in then all OK. If not put your hand on the sub tank fuel pump. You will feel it vibrating when energised in which case it is OK and you have a priming/airlock issue. If no vibration then disconnect the plug to the pump and use a multimeter to measure the voltage from the Sub Tank ECU. Should be 12V accross the 2 pins when switched on. If there is voltage then pump is dead. I also connect 12v to the pump iteslf from a power supply to further check.
Be careful with petrol cars when doing the latter as sparks may result.
Only do the above checks when you have cleared the light and reset the Sub tank ECU by disconncting the negative lead to the battery and then reconnecting. The ECU will not show a light for a dead pump - only a problem with the ECU itself or power issues (as is the case when connecting certain turbo timers which cause the ECU to go into sulk mode).
David
FollowupID: 489980
Reply By: Sam from Weipa Auto Electrics - Friday, Mar 23, 2007 at 08:17
I have had a fair bit to do with this problem and everything said can be a solution but the main ones are reset the battery terminal first but you only need to disconnect and reconnect again you shouldn't need to wait also the earth problem can be a very big drama but very few and far between.
AnswerID: 229160
