Grand Vitara driving lights
Submitted: Friday, Mar 23, 2007 at 23:42
ThreadID: 43578 Views:4895 Replies:2 FollowUps:1
Would someone be able to tell me where to attach the Relay activation wire when fitting driving lights to a 2005 Suzuki Grand Vitara. When I put a test light on the high beam side of the headlights it is live all the time. It appears to be an earth wastage system. When I test the plug behind the dip switch it makes the lights come on when the switch is not activated.
Reply By: Member - Doug T (W.A) - Saturday, Mar 24, 2007 at 00:07
I had a Daihatsu Van a few years ago, The switch actually connected the currant to earth , so yes the wiring was live on the way to earth , tricky situation,
AnswerID: 229393
Reply By: gav99x - Monday, Mar 26, 2007 at 12:11
Is this method of wiring otherwise referred to as 'Negatively Switched'?
If so there is a wiring diagram posted up by I think it was Drivesafe of what you require. Post ID 24339 I think should help.
Apologies if it's not Negatively switched you're after.
AnswerID: 229798
Follow Up By: waterrat - Monday, Mar 26, 2007 at 16:48
Thanks for that. It works out that it is what I need. Thanks again.
FollowupID: 490595
