EGT for D4D Prado/Hilux T/D Engine
Submitted: Saturday, Mar 24, 2007 at 16:59
ThreadID: 43593 Views:3225 Replies:2 FollowUps:0
Hi there,
Can anyone with a D4D Prado or Hilux T/D engine tell me if an EGT can be fitted easily, please? If so, can you please advise exactly where the temperature sensor is installed in the manifold or pipe to turbo? Is there an existing plug which can be removed for it?
Thanks and regards
Glenn
Reply By: G.T. - Tuesday, Mar 27, 2007 at 11:57
Contact Ian from Thermoguard Instruments. He is a site advertiser. He will have all the answers for you. regards G.T.
AnswerID: 230002
Reply By: Truckster (Vic) - Tuesday, Mar 27, 2007 at 12:00
Gauges can be fitted to any car. they all come with a "Bung" you weld on the exhaust, and fit the sender to. but you need the bung welded on and hole drilled in zaust thats the hard part. you can fit after turbo on the exhaust for easiest fitment but not really the best reading.
AnswerID: 230005
