defender 110 tacho wiring
Submitted: Sunday, Mar 25, 2007 at 20:03
mlbm
I was just wondering if any one knows how to get the engine rpm signal to run a aftermarket tacho.
Reply By: bob - Sunday, Mar 25, 2007 at 22:10
Try Site Link or post this question on www.aulro.com
229702
Reply By: Mark Taylor - Monday, Mar 26, 2007 at 08:28
I take it your Defender is a diesel.
VDO make an alternator powered tacho.
I actually measures the speed of the alternator, but is calibrated to allow for the "gearing effect" of the pulley ratios.
I fitted a few back years ago when I was involved with VDO in a big way.
Mark T
229746
Reply By: Rod - Monday, Mar 26, 2007 at 10:27
Is yours a TDI or TD5 ?
The TDI pickup comes from the 'W' output on your alternator. See
forums.lr4x4.com/index.php?showtopic=9408
on how to modify your alternator if it doesn't have a "W" terminal.
TD5's pick up their signal from the ECU. Not sure how but google is your friend.
229772
Reply By: lindsay - Monday, Mar 26, 2007 at 13:31
I have a wire coming from the e.c.u. that goes straight to the tacho, that is a 2 inch one that is fitted in the hole of the clock mounting. I will check the colour of the wire if you wish.
229814
Follow Up By: mlbm - Monday, Mar 26, 2007 at 20:44
Hi thanks for your help. I'm trying to find out the info for a friend and would you mind checking what the colour of the wire. thanks for your time greatly appreciated.
mlbm
490651
Reply By: lindsay - Tuesday, Mar 27, 2007 at 17:56
Sorry about the delay it went to my spam box. Under the drivers
seat there are two yellow wires out of a black box that has wabco written on it. (the one nearest to the door)They come out of a connector about in the middle of the box. The front one has a pale purple trace through it and the rear one has a
grey trace. The wire I have used is the one with the purple trace ,the front one.
I have just placed a cable joiner, the type that you squeeze with pliers to join the wires and it goes to the tacho.
The purple trace is hard to see on my wiring, but you should be ok.
Lindsay. 0428488387 iof problems.
230070
