Moving alternator.to higher ground
Submitted: Monday, Mar 26, 2007 at 07:51
Member - BUNDY BOY (WA)
Good morning to all the
well knowledgeably ....formities.....
well as we know ...my gq has a 3lt rb30 motor (petrol)...my question is...the alternator.is placed as on a car.....at the bottom.of the motor ....
now i want to move it to higher ground so as not to have drowning problems .when in
water......i know someone will have a simple answer for this as its got to have been a problem in the past...so there will be a adaptor plate around to refit it ....but were ????
also with steering....have 3.5 inch lift ....new springs and tuff dawg shocks all round .....castor correction bushes ...but it seems still to walk or wander around ...at speed over 80km .....a real pain on non highway roads ....any suggestiveness on fixing this ...and a good place in
perth to go to get front end set up ...as most don't know much apart from what's in a book....
cheers Darren
Reply By: Robin - Monday, Mar 26, 2007 at 09:57
One Comment Bundy , that model didn't have a front sway bar , with your mods I would think you need it.
Robin Miller
229766
Follow Up By: Member - BUNDY BOY (WA) - Monday, Mar 26, 2007 at 22:39
hay there Robin.....has sway bar.....its got me beat /was thinking ajustable panhards
490701
Reply By: Wayne (NSW) - Monday, Mar 26, 2007 at 10:34
Darren,
The wandering Patrol could be a number of things. Tyre pressure, wheel bearings, steering linkages, worn steering box or even worn tyres. Try swapping the tyre from front to back and see if the problem is still there.
As for the low alternator, if you don't stop in the middle of the
river crossing and maintain a good walking pace with a bow wave, then
water should not get any where near the alternator or into the engine bay.
When turbos first come out on 4wd diesel there was a concern that the turbo would crack if a
water crossing was attempted. That myth has been busted.
If you are still concerned about
water in the engine bay when going across a river, a simple blind on the front of the vehicle will also help with the bow wave.
Wayne
229773
Follow Up By: Member - BUNDY BOY (WA) - Monday, Mar 26, 2007 at 22:45
hay there Wayne...its bugging me all for mentioned are checked and seem fine...was thinking adjustable panhards.....have sway bar..its only at hi speed so to speak...and on uneven road .....was think in tyres myself ...but there 4 months old .and had prob before them .....its a weird 1 but is bugging me as im doing alot of distance.drives now
cheers Darren
490705
Reply By: Member - Jerry C (WA) - Monday, Mar 26, 2007 at 22:44
Hi Bundy Boy,
Have you tried Wilkinson
Suspension Centre in Bayswater?
Jerry
229930
