Waeco CF-80 surface Rust
Submitted: Tuesday, Mar 27, 2007 at 19:36
mca
Gday ALL
I have had my CF-80 replaced under warranty due to surface rust appearing in various
places six or so months ago. I have just noticed on the new fridge it seems to be happening again but at this stage not as bad. When I received the replacement I polished it & have looked after it. I live In
Cairns at the beaches & never leave it outside.
I am wondering if anyone else has had the same problem & what I can do to prevent it. The fridge is under warranty but I am concerned it is going to happen again if it is replaced.
Cheers Mark
Reply By: Member - Blue (VIC) - Tuesday, Mar 27, 2007 at 19:39
So far nothing of the sort with my CF 110... It's been rained on a couple of times, spent a bit but not lots of time at
the beach and after a couple of years, no rust...
230090
Reply By: Member - Stephen M (NSW) - Tuesday, Mar 27, 2007 at 19:54
Where about's is it rusting, would like to know so I can check
mine although I cant see any. Regards Steve M
230093
Follow Up By: mca - Tuesday, Mar 27, 2007 at 20:04
Hi Steve
The rust is`nt that bad yet but is located on back in a cpl of spots, center & bottom right.
The 1st fridge that was replaced was all over the front & worst around where the metal meets the plastic strip at the bottom of the fridge.
490885
Reply By: MEMBER - Darian (SA) - Wednesday, Mar 28, 2007 at 08:52
Isn't the air at beaches laden with a certain amount of salt
water ? If so, it would be in your house and shed as
well - can't stop it. A lot of stingy manufacturers will save a few cents in manufacturing by using metals with very poor corrosion resistance....... eg.....parts of my new pool filtering system at home are going rusty within 12 months.
230177
Reply By: Gronk - Wednesday, Mar 28, 2007 at 10:18
I have a Waeco 60 and although I haven't had a good lokk, I didn't think there was any metal to it .. all plastic I thought ????
230194
Follow Up By: mca - Thursday, Mar 29, 2007 at 07:19
I think the 60`s are but the 80`s are metal
491210
