Christies Battery Charger
Submitted: Tuesday, Mar 27, 2007 at 21:40
Member - lyndon K (SA)
Just wanted to post my experience using a christies charger. I have a 78 series, with 1 starting battery and 3x50 amp excide orbital deep cycle batteries. The deep cycles are wired to a 175 amp anderson plug which is located under the back of the vehicle. I have the 3 hp 80 amp model charger, the 55amp model was just to noisey.I have changed the connection on the charger so it just plugs straight in to the female anderson plug.
The charger is louder than say a 10i honda, but still reasonably quite. I run two fridges + a few other gadgets. The charger provides enough power for our needs each day with a run time of aprox 1.5 hours.
This is great, not just for us but if we have
camping neighbours. No endless noise of a generator running all day!.
We are really happy with it!.
If anyone would like any info give me a bell.
Reply By: Robin - Tuesday, Mar 27, 2007 at 21:46
Sounds great Lynon.
We are quite lacking generators optimized for 12v charging , and heres a real marketing opportunity there.
Had any issues with overcharging - mind you I use same battery are they are the most tolerant of any sort.
Do you monitor them at all volts/amps etc
Robin Miller
230117
Follow Up By: Member - Phil G (SA) - Wednesday, Mar 28, 2007 at 08:25
Robin,
The Christies is simply a 55W or 80W Bosch alternator mounted on a Honda motor. The internal regulator regulates voltage, same as in your car, but I think Christies also gives you the option of boosting the regulated voltage to 14.7. So it can recharge a bank of 12volt batteries in quick time.
490967
Reply By: Member - lyndon K (SA) - Tuesday, Mar 27, 2007 at 21:56
Hi Robin
No need to monitor amp/voltage, it does it all, there is a led display which gives you this info. The machine adjusts the charging rate automaticly, so you can just leave it to run until it runs out of fuel if you want. It won't over charge. Not much good for wet cell batteries as they won't take a quick charge, it will still work but will take forever. Best suited to AGM's or Gell cells. It cost 1350
Regards Lyndon
230120
Follow Up By: Mike Harding - Wednesday, Mar 28, 2007 at 09:35
>It cost 1350
That's one expensive battery charger!
Mike Harding
490987
Follow Up By: Member - Phil G (SA) - Wednesday, Mar 28, 2007 at 10:14
Mike,
Its not just the charger (80amp alternator) - there's a Honda motor attached!
Christie Engineering Link
490997
Follow Up By: Mike Harding - Wednesday, Mar 28, 2007 at 10:17
I appreciate that. But this thing's only purpose in life is to charge a battery.
490999
Follow Up By: Member - Phil G (SA) - Wednesday, Mar 28, 2007 at 10:38
Same price as 120W of solar panels, and recharges 10 times faster.
Depends on how you're setup. I'd like one - everything I use runs off 12 volts. It uses the same fuel as my stove, so it would suit me. And you'd only be making noise for 1 hour a day.
491003
Reply By: Richard Kovac - Wednesday, Mar 28, 2007 at 21:32
Hi lyndon
We run a 55 amp unit and like it
have a smaller size set up then yours
I have fitted one of the hour meters / tacho units to it to monitor it usage
Richard
230349
Follow Up By: Member - lyndon K (SA) - Friday, Mar 30, 2007 at 09:56
Hi Richard
Can you give me some info re where to get that tacho/hr meter and how you set it up & the cost?.
Thanks Lyndon
491432
Follow Up By: Richard Kovac - Friday, Mar 30, 2007 at 20:58
See link Site Link thay are around $60.00 i think
Richard
491559
