plasma rope
Submitted: Wednesday, Mar 28, 2007 at 16:43
ThreadID: 43734 Views:2805 Replies:7 FollowUps:5
was ,and i repeat was thinking about putting plasma rope on my winch,
more length /50 m intead of 30 cable,rang TJM TOWNSVILLE,
YEP WE CAN GET IT "' how much said me??
$600 SAID HE!
i think i will buy an ext strap instead!!!
Reply By: Member - Roachie (SA) - Wednesday, Mar 28, 2007 at 17:48
got mine from the states....much cheaper, but I only got 30 meters I think. Mainly got it cos of the weight saving and the safety factor. Still carry an extension strap too.
AnswerID: 230281
Follow Up By: tvl - Wednesday, Mar 28, 2007 at 18:02
roachie,tjm bloke told me if u fray that rope /throw it.
at $600 a pop i wont even consider buying it ,IF that is true.
FollowupID: 491119
Follow Up By: Bonz (Vic) - Wednesday, Mar 28, 2007 at 18:45
The rope doesnt really fray it gets "fluffy" - NO Roachie not the Fluffy you let out of the bag! I have seen some VERY fluffy ropes pull comp cars almost vertical so dont believe everything you hear mate.
FollowupID: 491134
Reply By: Gerhardp1 - Wednesday, Mar 28, 2007 at 17:58
Here's a lead - an email should enable you to source a longer piece at a less than stupid price.
Site Link
AnswerID: 230284
Reply By: Member - Jiarna (NT) - Wednesday, Mar 28, 2007 at 18:07
Apart from cost and having to chuck it if damaged, keep in mind that most low-mount winches (ie: the winches most of us use) overheat the winch drum during braking and destroy plasma rope. Plasma rope is usually only used with high-mount winches where the braking mechanism is distant from the winch drum.
There are exceptions, but make sure you have one of the exceptions b4 coughing up for plasma rope.
AnswerID: 230286
Follow Up By: Member - Roachie (SA) - Wednesday, Mar 28, 2007 at 19:59
John, I'm probably wrong (as usual), but I believe the overheating drum due to braking effect, is only an issue if/when you are paying-out the cable under load (eg: lowering yourself down a hill etc).
In my opinion, most winching operations are done with the winch reeling-in the load and the brake drum should not get too hot. I will gladly stand corrected.
FollowupID: 491156
Follow Up By: Member - Jiarna (NT) - Thursday, Mar 29, 2007 at 06:47
Hi Roachie
You are quite correct, but it would be a hell of a time for an unexpected winch rope failure! I quess it's a matter of weighing up the advantages of reduced weight and safer manual handling against the disadvantages of cost and heat intolerance. For many people, I'd think the cost for a rarely used item would rule it out, but there's all kinds of people in the 4WD scene LOL.
FollowupID: 491209
Reply By: Member - Battlecat (WA) - Wednesday, Mar 28, 2007 at 18:41
Why not use both? 20m of wire and 30m of plasma rope.
AnswerID: 230295
Follow Up By: japmel - Wednesday, Mar 28, 2007 at 19:49
Um at a guess I would say there is probably no safe way of joining the two.
FollowupID: 491155
Reply By: Bonz (Vic) - Wednesday, Mar 28, 2007 at 18:46
Get in touch with Roger Smith of Dynamica rope fame and get him to quote you. I got mine there and I reckon its THE best safety applicance I have on the 4b.
AnswerID: 230301
Reply By: Robin - Wednesday, Mar 28, 2007 at 20:16
Only run 18m of plasma here - winch needs a rest after that away , and back it up with several extension straps , from 5m in length
Fantasic stuff that has many a 4wder a heart attack I'm sure.
Also have velcro nylon sheath about 1 m long that can go over partof rope if it has to go over rocks etc.
The flexiblity of this stuff is that I have thrown it under the patrol and out beteen the back wheels and pulled car backwards as rope slips axles etc.
Wouldn't try that with a steel rope.
Robin Miller
AnswerID: 230324
Reply By: Baldrick - Thursday, Mar 29, 2007 at 09:40
There are newer types of plasma that are far more heat resistant than the original sort. You can splice it if it gets cut or frays. Also you need to change to a hawse fairlead as the rollers can pinch and cut the plasma.
AnswerID: 230413
