hand winches
Submitted: Sunday, Apr 13, 2003 at 17:36
ThreadID: 4378 Views:2100 Replies:5 FollowUps:1
would any one be able to tell if a 800kg hand winch be able to pull a 1600kg 4wd i keep getting conflicting answers, thanks
Reply By: Truckster (Vic) - Sunday, Apr 13, 2003 at 18:37
1) what brand and model is the winch.
2) search www.google.com for this brand and model specs.
3) try Here for specs on the Turfor Brand of hand winch.
AnswerID: 17521
Follow Up By: CHRIS - Monday, Apr 14, 2003 at 14:37
As a ex army recovery mechanic the formula from memory is weight/2 for mud ---weight/7 for sand --- weight/25 for level ground plus degrees of slope up to 45% then full weight of vehicle, plus 25% of load for frictional losses and safety factor. You can pull anything with your winch providing you know how to do tackle layouts and you have the cable and snatch blocks to enable this.
FollowupID: 11037
Reply By: Voxson (Adelaide) - Sunday, Apr 13, 2003 at 19:25
I have a 3000kg hand winch which is hard to use when bogged..._____________________________________________
Countin the days till July 5th. *Cape York Trip*
AnswerID: 17524
Reply By: Member - Cocka - Sunday, Apr 13, 2003 at 21:59
Where do you want it to pull the 4WD from & to ??
Pulling it along a flat road then no prob. but pulling 1600 K up a steepembankment then you've got a prob.
The winch had a capacity of 800K, full stop. It'll be great for some jobs but RS for others. You can't expect it to pull a dead weight of more than 800K. Be careful, be wise.Carpe Diem
AnswerID: 17540
Reply By: Member - Rohan K - Monday, Apr 14, 2003 at 09:58
David, winches have have two ratings, a lift rating and a pull rating. Which have you quoted?
Usually the pull rating is around double the lift rating. So, if you've the lift rating, then the winch can probably pull 1,600 kgs. But that would be the "maximum safe limit" and whilst you'r truck may weigh 1,600 Kgs, if it is stuck, that friction will increase its effective "weight" (same if you are recovering up-hill).Be good, or be quick.
Rohan
AnswerID: 17563
Reply By: Eric - Monday, Apr 14, 2003 at 23:55
David.
You can pull 1600 kg up a 45deg slope in theory, but allowing for friction and other effects 30 deg may be your limit, still very useful, I have pulled a 5 ton tractor back onto its wheels after it rolled with a 800kg terfor. Eric,
AnswerID: 17628
