Electric Trailer Brakes/Controllers
Submitted: Thursday, Mar 29, 2007 at 23:28
hosea
Hi Guys,
I have read a few posts regarding Electric Trailer Brakes here. The question I am going to ask is proberly silly, however I have had nothing to do with Electric brakes in the past.
Can you set up a brake controller with your standard round 7 pin outlet, or do you need to move to a Flat 7 pin?
We have just purchased a new horse float which has Electric braking, We are yet to pick it up, however I had a quick glance at it and it appears to only have a standard round 7 pin plug.
I have a 100 series TD Landcruiser, It is having the brake controller installed tomorrow, will the install a Flat outlet? And will both drive the brakes?
Any info appreciated
Reply By: Shaker - Thursday, Mar 29, 2007 at 23:33
Doesn't amtter what outlet you use, as long it matches the trailer.
Just get the installer to fit correct socket to match your new float.
230559
Reply By: Derek from Affordable Batteries & Radiators - Thursday, Mar 29, 2007 at 23:44
Hi hosea
Yes any trailer plug will do.
Prodigy or Voyager are great controllers.
There is also a Redarc unit that is quite good.
Derek.
230561
Follow Up By: Member - Peter R (QLD) - Friday, Mar 30, 2007 at 09:49
Derek,
Are you back from China?
I have sent an email and tried to phone you without success.
Does your footprint for battery under bonnet take a Fullriver 120 AGM 3312 long 175 wide.
Sorry for hijacking thread, but urgent need of this info .
Pedro
491431
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Mar 30, 2007 at 09:57
Still inspection the fridges, chargers,
inverters and power packs.
I will be back on the 10th.
Send me text messages. to 0404 097 627 they seem to come through ok.
Derek.
491434
Reply By: Member - Phillip S (WA) - Thursday, Mar 29, 2007 at 23:45
Hi....... I had
mine connected through a 7 pin round plug and tow a 20ft caravan with no problems whatsoever.....regards Phil
230562
Reply By: PeteS - Friday, Mar 30, 2007 at 06:03
Hi hosea
1) You can you set up a brake controller with your either a 7 pin round OR a 7 pin flat.
2) You can buy convertors from 7pin round to 7 pin flat (and vica versa) however I would NOT recommend these as the brakes draw a fair bit of current and the more termination points or plugs you have the greater the risk of electrical failure.
3) I'm sure if you talk to the horse float supplier they will change the plug for you suit your Cruiser. I not an auto electrician can easily change the plug over on the horse float. This would be the best method in my opinion.
If you want to change over the plug yourself I can email you the pin arrangements for both the 7pin flat and round if you wish.
230570
Reply By: hosea - Friday, Mar 30, 2007 at 11:15
Thanks for that guys,
I am thinking I will change the float plug over at the moment.
230609
Reply By: HGMonaro - Friday, Mar 30, 2007 at 11:32
having had both, the flat ones are much nicer. Easier to connect and less likely to get bashed against something due to skinnier profile. Look better too!
230617
Reply By: Dunedigger - Saturday, Mar 31, 2007 at 14:06
The flat plugs are more reliable. Less problems with a 'poor' connection. Even so sometimes I have to take to the pins to make them wider for a snug fit
Dunedigger
230853
