flat battery Nissan D40 petrol
Submitted: Saturday, Mar 31, 2007 at 10:13
Member - Robin T (VIC)
has anyone had battery problem Nissan D40 leave standing 14days plus battery flat had all accessories checked out Nissan say its the module that runs all little security dash lights etc they fitted a bigger battery than the original under warranty still the same problem just takes a few more days goes from about 12.8 volts to 10.5 in 15 days or so Squizzy
Reply By: Peter 2 - Saturday, Mar 31, 2007 at 11:54
Sounds like bullpoo to me, might have a crook security module?
Sometimes cars sit for months in dealers yards before being sold, can imagine what they would be doing if they went flat after a fortnight.
You haven't added any accessories that might be causing the problem?
230834
Reply By: Member - Robin T (VIC) - Saturday, Mar 31, 2007 at 12:40
Thanks Peter me thinks its BS too had private auto elec check it out before I went back to dealer all my accessories were ok he said this module was drawing the power Nissan claim they tested new D40 sitting in Melb and the power loss was similar to
mine
230840
Follow Up By: Member QLD Steve & Lorraine Mc - Saturday, Mar 31, 2007 at 15:54
Hi Robin
Lately some brands of electric brake controllers have been known to draw power down & flatten batteries, had this recently happen on a friends new 100 series T/D took bloody ages to find & the dealers were next to useless???
Just a thought it, could be something to consider if you have one fitted.
Cheers Steve
491711
Reply By: Member - Davoe (Nullagine) - Saturday, Mar 31, 2007 at 15:41
2 weeks out of 3 my 4by sits there doing nothing and the immobaliser never looks like flattening the batteries. and being a cruiser she always starts first crank
230859
Reply By: Member - andrew G (VIC) - Sunday, Apr 01, 2007 at 17:04
gda think navara d40 is same as pathfinder.. if is my pathy battert did the same dead after a few days in drive. 5 months old. Nissan replaced battery so mayby there is a problem with the batteries being fitted?? good luck.
231023
Reply By: Chris & Debbie - Tuesday, Apr 03, 2007 at 22:48
Had the same problem with the battery in my D40, nissan must have got a bad batch of batteries, I replaced
mine with a bigger battery but took the original into nissan which was replaced under warranty, this battery is now just sitting in the garage as a spare.
As a warning , do not leave the D40 or Pathy in 4x4 and end up with a flat battery, which happened to me while
camping on
the beach for a week as the computer gets confused and does not know what position the transfer case is in and will not allow you to select 2wd. In the end the only way I could fix it was to remove the electric actuator motor on the tfer case and manually put it back into 2wd refit the actuator. So now I never leave it parked in anything but 2wd.
Chris
231554
Follow Up By: Member - Robin T (VIC) - Thursday, Apr 12, 2007 at 14:14
Thanks Cris and Debbie are you sure that leaving the D40 in 4 wheel drive was the problem could you test your battery and leave the D40 stand for a week and see how far down your battery has gone I have a bigger battery but stills goes flat if I leave it for more than about 10 days NOT in 4wheel drive Robin T
493815
Follow Up By: Chris & Debbie - Friday, Apr 13, 2007 at 20:12
Sorry Robin you may have mis-understood what was written.
The Battery used to go flat after a few days (nothing to do with 4WD) but I have not had a problem since the new battery was fitted.
The part about 4WD was just a warning about not leaving the vehicle in 4WD and letting the battery go flat as you will end up with the problem stated.
Chris
494068
