new water tank
Submitted: Saturday, Mar 31, 2007 at 16:34
skipp
g'day, have just installed a 60lt
water tank on my camper trailer.It has the filler hole ,one for the tap/pump and another one i was told is the breather????? i have connected the filler hose and the tap/pump but what do i do with the breather?? it has a screw in device but it is sealed where as the tap/pump has the same device but is hollow.
q2.my filler hose is connected to the middle of the
tank up the side, so what happens when i fill the
tank past this point, with the air inside the top of
tank will it still fill up???cheers skipp
Reply By: Peter 2 - Saturday, Mar 31, 2007 at 16:59
Most campers and caravans don't have a breather on the
tank as such but just drill an 2-3mm hole in the blanked off bit.
If I was you I'd drill the hole, screw a fitting into it and then run a hose up as high as you can and fit a small fuel filter on the end to keep the bugs and dust out.
230863
Reply By: Keith_A (Qld) - Saturday, Mar 31, 2007 at 22:20
Hi Skipp - As you know, the breather lets air out as you fill the
tank, and lets air in as you empty the
water.
There are 3 things you can do with the breather outlet.
1. Do nothing - It still works, unless mud wasps may fill it up, and dust etc can get into your
tank. You also need to keep looking underneath the
tank as you fill it, to watch for
water running out the breather so you know the
tank is full.
2. Attach a length of plastic hose, and put a small filter on the end. Foam rubber can act as a filter, but is not porous enough to let the air out quickly when filling the
tank. You can buy a small plastic filter head from garden irrigation shops.
3. Attach a plastic hose and run it up to the filler cap. The newer model filler caps include a hole and tube that you attach the breather to.
The advantage of this method, is you know when the
tank is completely full as
water will squirt out the breather hole of the filler cap.
.............................Keith
230907
Reply By: disco1942 - Sunday, Apr 01, 2007 at 00:26
The later model lockable
water fillers have a connector for a piece of tubing that connects to that breather on your
tank. When you remove the cap from the filler you expose the large filler pipe and the smaller breather. Before connecting the breather tube you drill as large a hole in it as you can.
To see a picture or the filler go to www.camec.com.au/. Then click on catalogue (near the top of the page,) then select the RV button. On the LHS of the ensuing page you will see a list of sections of the catalogue you can download in PDF form. Download section 35 and on the top LHS of page 102 a couple of pictures of the Camec Lockable
Water Fillers. These are designed to operate in conjunction with the
tank breather. No doubt there are other models that will do the same job but this is the model I am familiar with.
230918
Reply By: skipp - Sunday, Apr 01, 2007 at 19:24
thanks for the help.
went back to where i got the
tank,different person told me i was given the run around.the two outlets on the bottom....one is to join to another
tank if i wish and the other is outlet to tap,,,,one of these i was told is the breather. the breather is on top of my
tank.so now have to pull
tank of and start agian
thanks agian
231063
