Tow ball weight
Submitted: Tuesday, Apr 03, 2007 at 13:23
ThreadID: 43949 Views:2952 Replies:4 FollowUps:3
G'day,
Could someone tell me how to measure the weight on my towball while my caravan is hooked up please.
shelz351
Reply By: Member Boroma 604 - Tuesday, Apr 03, 2007 at 14:11
Gooday,
can tell you 2 methods. First ring nearest Dealer & see if they have a set of Ball Weight Scales & if they will do it, & how much $. You unhitch & place ball on scales.
2 Go to a Registerd Weighbridge with Caravan in tow, drive on so towing vehicle is off bridge but caravan wheels aren't, they note the weight. Then reverse enough so the caravan wheels are still on, unhitch caravan, insert Jockey wheel making sure that is also on the bridge & get them to note that. Difference between the two readings will give you the Ball weight on your tow vehicle.
Hitch up & drive home with the Certicficate they will give you. Will possibly be a fee too.
Cheers Boroma604.
AnswerID: 231431
Reply By: DIO - Tuesday, Apr 03, 2007 at 14:14
Here's a few sites that might help you figure it out:
Caravan & Camping SA
Harding Caravans Services
The following should also give you some idea of the aspects of weight and distribution on the towball/towbar system:
The only way you could get these figures would be to take the van to a weighbridge. You need to weigh the van on the bridge without the car. In other words with the van wheels and jockey wheel on the bridge and then weigh it again with just the van wheels on the bridge. Doesn't matter if the van is on the car or jockey at that stage as long as only the van wheels are on the bridge.
If you subtract the weight on just the wheels of the van from the total weight including that on the jockey wheel you will then have the ball load.
AnswerID: 231433
Follow Up By: Member - Duncs - Tuesday, Apr 03, 2007 at 15:33
Shouldn't you also ensure that the jockey wheel is set at the same height as the coupling on the towing vehcle. I have noticed that the higher you lift the coupling the easier it is to lift.
Perhaps you could park the van with the wheels just off the weighbridge and the jockey wheel on. Might save a step.
Duncs
FollowupID: 492367
Follow Up By: Member - Bucky (VIC) - Tuesday, Apr 03, 2007 at 16:21
10% of the total weight on the ball..
I use my bathroom scales,,,My next door neighblou has a jack with a scale on it ,, they cost a little more, but you can measure all wheels too. They are brilliant
But you need to know the weight of the van / camper that is loaded ,, hence the weigh bridge.
Rough rule of thumb,, if you can lift the jockey wheel, with a bit of an effort, then you are close.
Cheers Mate
Bucky
FollowupID: 492381
Reply By: Member - Doug T (W.A) - Tuesday, Apr 03, 2007 at 14:32
Should say what state your in , if in NT ie Tennant Creek or Katherine you could zip down the W/B and do it yourself if the Inspectors are not there,
AnswerID: 231435
Reply By: Gob & Denny - Tuesday, Apr 03, 2007 at 17:53
if you go to the haymen reese site they have a load of info there including setting up your household scales without stuffing them while doing the weighing
steve
AnswerID: 231465
Follow Up By: Wizard1 - Wednesday, Apr 04, 2007 at 11:33
Went to the HR and couldn't find a thing about using using household scales.
It tells you how to find out what your Tow Ball weight is.
Perhaps you could enlighten us to where that info is on the website.
FollowupID: 492568
