"Bush-wind-up-camping" in Benalla-Mansfield-Whitfield region?
Submitted: Tuesday, Apr 03, 2007 at 16:40
HGMonaro
Looking for any recommendations or 1st hand knowledge of suitable spots for a couple of days over
Easter in this region. Would like a running stream nearby for kids to play (boat races) and maybe ability to have a campfire. Will be in our wind-up camper but otherwise self sufficient (assuming I get gas regulator fixed/replaced) otherwise... will need a powered site somewhere!!!
Regards, Nige
Reply By: HGMonaro - Tuesday, Apr 03, 2007 at 16:40
oops, forgot to add, will be coming from Wang.
231455
Reply By: Robin - Tuesday, Apr 03, 2007 at 17:00
Hi Hg
Check out the James
camping area , south of Benalla on
Mansfield road before Lake Nilacoote.
(swanpool -> Lima east -> about 4 more kms )
You should really get Benalla
Mansfield rooftop map, as its
easter and there are many
places around there in the northern strathbogies , but many will get occupied early.
Robin Miller
231459
Follow Up By: Jimbo - Tuesday, Apr 03, 2007 at 18:58
Great liitle spot. heading south from Benalla, a few K's after Swanpool turn right into Gandini Lane. Go until you hit an
intersection, turn left ang go about 7 K's.
James Reserve is on the right and
well signed.
Be warned it is avery small
camping area, not much bigger than a footy ground and will only cater for 3 to 5 groups. Get there early or have a contingency plan.
ATB,
Jim.
492417
Reply By: Crackles - Tuesday, Apr 03, 2007 at 17:25
Powered site on a River..........Gentle Annie caravan
park at Whitfield.
Bush camp...........Jones
Camping area on the Holland
creek (just off the Tatong/Tolmie rd). Buttercup
Creek (East of Merrijig). Edi cutting on the
King river. (May be busy). Lima East rd
camp. (small
creek)
Most other spots with running
water are probably still a little black at the moment.
As suggested get a copy of the Rooftops "
Bright-
Mansfield Adventure map". Has all the camps marked on it. Being
Easter & with so many campsites burnt out it would pay to get in early & expect a bit of crowding. Cheers Craig............
Benalla.
231462
Reply By: HGMonaro - Tuesday, Apr 03, 2007 at 19:30
Thanks! I do have the "
Bright-Mansfield" Rooftop map, looks like I need the "Benalla-Mansfield" one too.
Since we will only be getting there mid-afternoon Friday (Melb->Wang to pick kids up from grandparents ->
campsite) we'll probably be last in so might have a problem finding something.
Any idea what the Mt Samaria campsites are like? Also Blue Range, too busy?
Cheers, Nige
231482
Follow Up By: Crackles - Tuesday, Apr 03, 2007 at 21:42
The Samaria
Park camps are pretty dry at the moment with most creeks stopped. Blue Range crk rarely gets alot of campers & is probably still just flowing. Worth a try.
492476
Reply By: Member - Arkay (SA) - Wednesday, Apr 04, 2007 at 09:24
Bit further, consider Walnuts
camping area approx 15 km SE of
Mitta Mitta on
Omeo Highway, 3 km dirt rest bitumen, bitumen strip on road past the
camp area so no dust,
lookout for logging trucks, approach from North as
Omeo Road can be very corrugated, caravan friendly, no power, drop
toilet, running stream on 2 sides, marked on Hema maps just below
Granite Flat.
231594
Reply By: madcow - Wednesday, Apr 04, 2007 at 13:14
Great little spot at EDI just before Whitfield on the
King River. Heaps of room with long drops being the only facilities. Close to Brown Bros winery :)).
231626
Reply By: HGMonaro - Sunday, Apr 08, 2007 at 22:03
Just a little follow up to ths thread.
We went to James
camping ground and got a spot on the edge of the
camp ground with some shade and next to the
creek. Was several other groups positioned around. Chatted to a couple of people from the main group and it seems if a quiet relax is desired,
Easter is not the time to go there, as they are regulars and played LOUD music most of the day and into the night. 1st night they turned it down about 9:30 and a bit later the 2nd night. Thankfully it was similar to our own tastes, and our boys, and us, fell asleep dispite it. They also had numerous motorbikes and groups would take off or arrive back from a ride. Not a big issue as they mostly just parked them strait-away (to get at the beers I guess!)
The
camp ground itself was quite good, running stream, room to kick the footy and just up the road, an abundance of firewood. We actually bought some (raided the in-laws woodheap) but gathered some more just for the fun of it. Long drop dunnies like usual.. smelly which was an experience for my boys. They did offer a good view of the campgrounds by peering thru the boards on the walls :) Went for a drive around a few of the other campsites around, including Mt Samaria and it was the pick of them.
Our camper had a problem in the 1st 5mins after setting up when the 12v pump decided to go on the fritz. Couldn't find any fuses or reset switches so I used the drain plug on the
water tank to get a bucket of
water. Whilst walking behind camper it dawned on me it would have been easier to use the two 20L 'jerry' cans I'd also brought along! Ended up using both over the two nights was stayed but could have been a bit more frugel washing dishes. Tried it again when we got home today and it did the exact same thing... ran for 5 secs spitting
water and air then cutout. Maybe has an airlock or leak, but does mean it's still getting power which is what I thought might have been the problem.
Overall though, we had a good couple of days and proved to ourselves we can 'bush'
camp successfully!
Cheers, Nige
232304
