Bushman Fridge / Freezer - comments?
Submitted: Tuesday, Apr 03, 2007 at 18:29
ThreadID: 43958 Views:4924 Replies:2 FollowUps:9
I'm specifically looking for comments from people who have the new Bushman with the GD30 FDC ACC 12V Compressor, not the Danfoss compressor. The good, bad and ugly.
Thanks,
Han.
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Apr 03, 2007 at 21:03
Hi G,
The ACC compressor is a very high quality compressor and is still made in Italy or Spain depending on labour cost at the time.
Our new Sidewinder fridge uses the same unit.
Have a look at this test.
Fridge Test
Derek
AnswerID: 231518
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Apr 03, 2007 at 21:29
Here are a few pictures, I am packing the container as we speak. Containers will start arriving from the 1st of May. I have 4 mixed containers due in the next 2 months.
Derek.
FollowupID: 492472
Follow Up By: Mainey (WA) - Friday, Apr 06, 2007 at 23:55
Derek,
what are the hystereses numbers used in the fridge test ??
Are they adjustable ??
Mainey
FollowupID: 492999
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Apr 07, 2007 at 13:08
Hi Mainey
The fridge has an electronic thermostat and is fully adjustable.
Our hysteresis figures are basic fluctuation in room temperature of our shed as stated in the test. We did not run twin 'live' tests to see actual hysteresis influence on our fridge, it was a 3 day test and covered all temperature variations of a typical day.
Derek.
FollowupID: 493048
Follow Up By: Mainey (WA) - Sunday, Apr 08, 2007 at 00:20
Derek,
What's the number of degree's variation (hystereses) between the 'degree' that the fridge turns 'on' and then 'off' again, as used in the fridge test ??
Eg:
Temp variation number when fridge turns 'on' @ +6 degree and then 'off' again @ +1 degree, = hystereses of 5 degree.
Is this hystereses number adjustable, eg; from 5 down to 4, or from 5 up to 6 degree ???
As the temperatures were taken at "uneven time intervals", it's therefore not possible to know if the minimum and maximum temperature numbers are represented in the chart.
This is not a fault or "bad" comment, it's only a question that I'm not sure I can ask any other way, it's simply to ascertain the highest and lowest temperatures with-in the fridge cabinet, as the highest and lowest temps are not actually specified with-in the test data.
FollowupID: 493125
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Apr 08, 2007 at 09:24
Hi Mainey
4wd monthly will be testing the fridge soon and we will have more comparative tests.
The average time for temp pull down is 8 to 10 mins after opening the fridge. The compressor on to off temp is around 4 deg C.
Derek.
FollowupID: 493145
Follow Up By: Mainey (WA) - Sunday, Apr 08, 2007 at 14:12
Derek,
with those specs it should outperform the other 'two' - wayko & enjel L0L
FollowupID: 493169
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Apr 08, 2007 at 15:08
Hi Mainey
I know and I hope to do very well with this unit and the new 70L one I am designing that will have the option of user adjustable chest or upright configuration. We hope to have 3 models by the end of next year.
Here is a picture of the digital control panel. The 'S' button is for service options like forced override when needed.
Derek.
FollowupID: 493170
Reply By: fishaholic - Wednesday, Apr 04, 2007 at 07:34
Just buy an Eva Kool they are awsome!!!
AnswerID: 231582
Follow Up By: Red Frog - Vic - Saturday, Apr 07, 2007 at 18:13
yes they are
FollowupID: 493080
Follow Up By: warfer69 - Monday, Apr 16, 2007 at 01:11
Hi Guys
have you looked into covers for your evakool (i know their not neede but for protection when travelling etc),not the ones they sell, apparently they are crap,not like the fridges !
FollowupID: 494560
