simplicity suspension
Submitted: Tuesday, Apr 03, 2007 at 21:46
ThreadID: 43972 Views:4590 Replies:5 FollowUps:3
I have had a look at the suspension on my mates lotus van(duel wheel) and it has simplicity stamped on it, i have the same set up on my Windsor rapid off road and was wondering if this is also a simplicity set up?(single axle)
Reply By: macka2 - Wednesday, Apr 04, 2007 at 02:40
It's likley as simplicity is regarded as the _Affordable_Storage_Drawers.aspx but it weighs a lot.
macka2
AnswerID: 231571
Reply By: Member - Cruiser (NSW) - Wednesday, Apr 04, 2007 at 07:55
What did you think of the Lotus.
Just about to hook mine up and bugger off for Easter.
AnswerID: 231584
Follow Up By: slush - Wednesday, Apr 04, 2007 at 17:28
i was very impressed, he was looking at the 20 ft one. the finish inside was neat and tidy and compered to my Windsor when i picked it up, its right in front. keeping in mind that this is the demo model. had a look under the rear and not so well finished, things like around the step need sealing, the pipes going into the floor for washing machine etc weren't sealed off and they all persist in using clear hose for the water tanks. but overall from what i could see a top van.
FollowupID: 492622
Reply By: Member - Mick M (QLD) - Wednesday, Apr 04, 2007 at 17:25
hi member , simplicity suspension is duel wheel only ,its the bees knees in load sharing suspensions regards mick
AnswerID: 231659
Follow Up By: slush - Wednesday, Apr 04, 2007 at 17:30
its exactly the same setup but single axle.
FollowupID: 492623
Reply By: Go-N-Grey (WA) - Thursday, Apr 05, 2007 at 08:54
The Simplicity dual wheel suspension is fitted to my Supreme Territory van (21'). It managed rough ground easily, and sure gives the van great clearance
It is stamped as rated for 3,500 kgs, and the van is sitting on a truck like F.P chassis, placarded at 3,500kgs and weight of 800kgs, so is very heavy.
The ATM of the van is still limited to 2790kg, that is exactly 400kgs + 120kgs towbar weight over the Tare weight.
I wonder what happens to the 710kgs weight the chassis and suspension can take?
Could take a lot more water when bush camping.
AnswerID: 231752
Follow Up By: Clipper 811 - Thursday, Apr 05, 2007 at 12:31
We have 2006 Supreme 21' Territory, same chassis maker and rated 3500kgs. Simplicity suspension rated to 3500kgs. 16inch Landcruiser wheels. At purchase of van we requested a payload of 600kgs instead of 400kgs. Maybe go back to your dealer or Supreme direct to see if weights can be amended? They will know all the inclusions of your van and can advise whether ATM can be increased
Clipper811
Bob & Lorraine
On the road
FollowupID: 492766
Reply By: Go-N-Grey (WA) - Monday, Apr 09, 2007 at 21:11
Were you able to actually get the ATM increased? I rang Supreme on Thursday mentioning the issue, and I suggested I wanted to add extra water tanks etc.
They said add them, and then get you van Tared up again, +400kg payload, and that could be your new GTM. Still no increase in payload.
AnswerID: 232461
