Nissan Patrol or Toyota Landcruiser
Submitted: Wednesday, Apr 04, 2007 at 17:01
lux
Looking at upgrading the old Ute to either a Nissan Patrol or Toyota Land cruiser, around 2002-2006 models in turbo diesel form cab chassis. Any advice on what to look for on thes second hand 4wd's would be appreciated. Not concerned on brand loyalty best Ute that I find for will get the money.
Is the Toyota worth the extra money over the Nissan, Ute will be used off-road weekly in winter, tows a boat around and carries building materials and
tools around during the week.
Thanks for any replies
Reply By: furph - Wednesday, Apr 04, 2007 at 17:04
Drive them both with factory turbo' and your dilemna is over. The Toyota simply does it whilst the Nissan overheats.
furph
231652
Follow Up By: Member - Craig D (SA) - Thursday, Apr 05, 2007 at 12:51
furph, the later model Patrol's have the 4.8's radiator. My ute is close to GVM and has been used in all conditions and never had the temp gauge out of normal range.
492768
Reply By: Kev M (NSW) - Wednesday, Apr 04, 2007 at 17:19
Try these
www.pickles.com.au/index.html
www.governmentauctions.com.au/default.aspx
Ex Government located in all major centres around Aust, both nissans and Toyotas
Cheers Kev
| Russell Coight:
231657
Reply By: Alcoz - Wednesday, Apr 04, 2007 at 18:52
g'day
Just went threw the same thing myself and being a Patrol owner from way back was pretty disappointed in what's being offered at the moment.
Now have a Toyota in the driveway!
Reg Al
231673
Reply By: Member - lyndon K (SA) - Wednesday, Apr 04, 2007 at 19:15
Go the government actions if you are going 2nd hand, most are 40k and still under warranty, I did this twice and was very happy, but you have to be prepaired to wait for a good one to come up.As for brand, the Toyota is dearer but there are twice as many of them around.As yourself why and you have your answer.
Go the TD Cruiser.
Cheers Lyndon
231679
Reply By: warthog - Wednesday, Apr 04, 2007 at 19:48
the nissan has a much stronger driveline but is let down by its motor. You can spend a few grand and get the td42 to go as
well as tojo motor but it will always use more fuel.
231682
Follow Up By: Granpa Joe - Wednesday, Apr 04, 2007 at 21:54
The Cab Chassis Nissan IS only available in the 4.2m litre Turbo Deisel From 2002 to 2006. Are you saying the 4.2 is inferior to the cruiser's a Donk?
492681
Follow Up By: warthog - Wednesday, Apr 04, 2007 at 23:20
I've got a gu that prabaly goes as
well as a std toyota turbo but it is thirsty. The toyota puts out good power and economy. The nissan won't do both in my experience.
492703
Reply By: lambo - Wednesday, Apr 04, 2007 at 20:09
what size boat are u towing ? i have a leeder 710, 265 hp mercruiser, on a bogey trailer, all up just over 3000 kg. the nissan 4.2 tdi manual does it easy, including the delivery trip from
perth to
sydney - av 16 l per 100 km.
231685
Follow Up By: Crackles - Wednesday, Apr 04, 2007 at 20:40
"does it easy" with 3 tonne?......you must have one that goes especialy
well lambo. Certainly wouldn't say the 4.2tdi I've towed 1.5 tonne with was doing it easy. Doesn't the Patrol cab chassis only have a 2.5 tonne max towing capacity anyway compared to the Toyota 3.5 tonne? Although in the 2nd hand market I believe the Nissan to be a better all round 4 wheel drive for touring I certainly wouldn't be overloading one too much after seeing 2 cracked through the chassis.
Cheers Craig............
492656
Follow Up By: warthog - Wednesday, Apr 04, 2007 at 21:43
Wouldn't be loading the tojo up either havig noted the pile of cracked 78 series diff housings at the A'Springs toyota dealer. The nissan has thin chassis walls and the toyota thin diff housings.
492677
Follow Up By: lambo - Thursday, Apr 05, 2007 at 07:52
mine's actually a wagon. true - it goes very
492732
Reply By: Member - Chris D (Newcastle) - Wednesday, Apr 04, 2007 at 20:15
Lux,
We bought our 79 series about 18 months ago second hand. There are always some little bits that need to be sorted, we have spent some time doing these for our truck.
I wounder if we have not been better off buying new as the second hand price seems too steep to me. If you decide on a Toyota remember that there has been a recent recall to exchange the rotor component in the from hubs. Just hope that you don't have to get the strarter motor out it is a wretch, believe me. The stupid oil filter is upside down also, so when you take it off about half a litre of oil goes on the garage floor....... After so many years of selling the same truck you'd think they'd get this right.
Chris
231686
Reply By: Member - Phil G (SA) - Wednesday, Apr 04, 2007 at 20:41
I made the same comparison 2 years ago:
Nissan was $5-10k cheaper second hand.
Toyota had better motor - more power, torque and better fuel consumption. Both motors are very reliable.
Nissan has stronger diffs
Toyota has stronger gearbox (H150F) - TD models. Most Nissan boxes are good, but 5th gear failures did occur during that period.
Toyota has longer wheelbase - poorer rampover angle
Toyota has stronger chassis
Toyota has higher payload
Nissan has coil spring option, but chassis cracks
Toyota has better cooling system
Toyota has better forward visibility
Nissan is 100mm wider (and takes wider tray)
Toyota has old fashioned dash, Nissan has more modern plastic dash.
Toyota are more common out in the donga, as are their spares.
Toyota has twin fuel filters. Not sure what Nissan has.
Both good vehicles, but I went Toyota because of the 1HD-FTE and Gearbox.
231692
Follow Up By: Kumunara (NT) - Wednesday, Apr 04, 2007 at 21:19
Phil G
Your information is not all correct. The Nissan gearbox is actually stronger. The only problem with the Nissan gearbox was in older models (1999-2000) and that was caused by a manufacturing fault on behalf of a supplier. The 5th gear spline was too short. That was rectified and there have been no further problems with the gearbox.
There are other points I also disagree with you about.
Tjilpi
492671
Follow Up By: warthog - Wednesday, Apr 04, 2007 at 21:39
2nd that about the gearbox. Have a look underneath and note the size of the nissan gearbox, not the smoothest box around though.
492675
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 04, 2007 at 22:01
Tjilpi,
Toyota had 2 gearboxes in the 79series - one that was weak (R151F behind the 1Hz) and one that was not (H150F behind the TD and 1FZ-FE). The original post refers only to the factory TD, which all had the stronger box. I was referring to the 5th gear problem with the GU box on the years you mentioned, and which may be considered by the
I don't mind you disagreeing - after all thats what forums are about!
And Warthog, I think you'll find the H150F and the Nissan box have a lot in common - even their unsmoothness :-)))
492683
Reply By: Willem - Wednesday, Apr 04, 2007 at 20:41
Both vehicles are good; each with their own idiosyncrasies
My concern would be with cabin comfort, as at 190cm tall I find the Nissan easier to drive and easier in cabin space. But if you are short at one end, then it doesn't matter and you have to decide which way to go on reliability and functionality
231693
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 04, 2007 at 20:46
Gday Willem,
Just wondering whether you're referring to the 75series rather than 79series.
In 1999, Toyota made the cab 5 inches longer.
My son is 198cm tall and sits fine in the 79series. I'm a shortie at only 185cm :-))
492657
Follow Up By: Willem - Wednesday, Apr 04, 2007 at 20:54
Hello Phil
The 75 series was PITA as far as comfort goes. You had nowhere to go with your left leg if you were over 150cm tall...lol. The 78/79 series is a lot better.
Having driven both the Nissan and the Toyota I feel more comfortable in the Nissan. But thats just me. Yes I know you are tall. lol....I looked at a photo of the two of us recently standing next to one another at the TBP in
Adelaide a couple of years ago......
492662
Reply By: kookaburra - Wednesday, Apr 04, 2007 at 22:34
hi lux. where in oz are you, iknow of a 06 nissan in se queensland, steel tray, under 30000 km, asking $46000, no its not
mine,regards.
231715
Reply By: Member - Big Al. Gold Coast - Thursday, Apr 05, 2007 at 11:38
2006 turbo diesel cruiser .
Look for sand under body and check roof gutter for any rust spots.
We have only done 12000km but cannot fault it.
I would fit air bags If any load near the GVM.
231792
