Inverter and Laptop
Submitted: Wednesday, Apr 04, 2007 at 21:39
ThreadID: 44001 Views:3789 Replies:6 FollowUps:12
Hi Guys,
We've bought a second hand van, part of the 12 volt set up includes a 600W Genius Power inverter, model G-12-060
It has
: Overload protection
: Battery low shut down
: High grade thermal protection.
I've read the section here on inverters but am still unsure if it's OK to use this for charging our lap top computers.
As there are no pamplets, instructions with it....can anyone advise?
Gerard and Anne
Reply By: Willem - Wednesday, Apr 04, 2007 at 21:47
Laptop computers can be charged safely with an inverter ranging from 150watt.
For running the laptop I would use anything from 300watt.
So your 600watt inverter should do the trick
AnswerID: 231705
Reply By: Member - outback2 (WA) - Wednesday, Apr 04, 2007 at 22:19
Inverters are either sine wave (same as 240v at home) or square wave...sometimes called Modfied square wave... laptops are ok on either type of inverter and actually draw very little power...your inverter will safely and comfortably run your laptop...I believe it is a square wave type..... I have a table somewhere that I could dig up if anyone is interested in seeing what equipment requires pure sine wave and those that are ok with square wave
VKS 1341
AnswerID: 231712
Follow Up By: Joondalupgerry - Wednesday, Apr 04, 2007 at 22:55
OK...thanks for the replies...I guess we'll be both running and charging our laptops of it....as we have solar panels and a caravan battery.
Gerard
FollowupID: 492692
Reply By: Sarg - Wednesday, Apr 04, 2007 at 22:51
Don't really matter what "wave" it is going into your AC adaptor, as it comes out the other end as DC-12,15,18, 22 V - whatever your laptop runs on. I've been running an IBM on a 300W inverter for a couple years now without any problems.
AnswerID: 231718
Follow Up By: Joondalupgerry - Wednesday, Apr 04, 2007 at 22:58
Thanks SARG...I was worried the puters power supply/charging unit might get indigestion and burn out or what ever they do.
Gerard
FollowupID: 492696
Reply By: Member - John and Val W (ACT) - Thursday, Apr 05, 2007 at 07:28
G&A - another option is to use a 12 volt power supply to charge the laptop. They are readily available from Jaycar, Dick Smith etc, ebay , for about $50. Check on your existing 240V supply to find its output voltage and current rating (probably about 19V at 3.5A). This is a more energy efficient way of charging the laptop than using the inverter.
HTH
J and V
- Albert Einstein
AnswerID: 231741
Follow Up By: Joondalupgerry - Thursday, Apr 05, 2007 at 08:54
Thanks...will wander into DS and check them out,
Gerry
FollowupID: 492740
Reply By: Mainey (WA) - Thursday, Apr 05, 2007 at 11:11
It DOES matter what type of "wave" the inverter is putting out !!!
The reason being:
on some laptops the 240v inverter current is ALSO going direct into and running the laptop, as well as also recharging the laptop battery.
On some laptops it ONLY recharges the laptop battery, and as has been stated it is ok to use even 'square' sine wave to do this.
However ONLY pure sine wave wave should be used where the current is actually used to directly run the laptop.
I use Toshiba and Dell laptops and both do require pure sine wave inverters, according to their respective manufacturers.
AnswerID: 231790
Follow Up By: Mike Harding - Thursday, Apr 05, 2007 at 11:34
I am unaware of _any_ notebook computer with an external power supply which accepts the 240V AC supply in addition to the DC supply. If you mean that the switch mode power supply provides current to both charge the battery and run the notebook then this would usually be the case otherwise one could only do one or the other.
Why? The external switch mode power supply will convert the 240V input into a DC current at a suitable voltage for the notebook. A well designed switch mode power supply will operate from a very wide range of input frequencies, voltages, AC and DC and wave shapes – I’ve designed a few of them over the years.
If the switch mode supply is doing it’s job properly then the notebook computer will have no idea if the 240V supply has a sine wave input or a waveshape similar to the second harmonics of the 1812 Overture.
Now: having said that there have been a (very) few reports of people having problems using modified sine wave (actually they are usually triangular wave) inverters with some notebook computers and I have certainly experienced two brands of low energy lamps which burned up when powered from my 300W MSW inverter. I don’t know why.
My Dell ran for about three years from my MSW inverter, my IBM is just coming up to the end of it’s first year. Manufacturers don’t like to expose their products to _any_ more risk than they _absolutely_ have to. That’s why they tell you not to use aftermarket parts on your vehicle.
Mike Harding
mike_harding@fastmail.fm
FollowupID: 492758
Follow Up By: Mainey (WA) - Friday, Apr 06, 2007 at 17:52
Mike Harding posted this followup-> "Now: having said that there have been a (very) few reports of people HAVING PROBLEMS using MODIFIED sine wave inverters with some notebook computers and I have certainly experienced two brands of low energy lamps which burned up when powered from my 300W MSW inverter. I don’t know why"
Mike, maybe my post above relevant to the benefits of "pure sinewave" inverters goes somewhere towards explaining the problems you have mentioned ???
FollowupID: 492942
Follow Up By: Mike Harding - Friday, Apr 06, 2007 at 18:09
You think so?
Give me technical rationalisation - not supposition or clutching at straws to make your pseudo technical opinions appear competent.
Mike Harding
FollowupID: 492945
Follow Up By: Mainey (WA) - Monday, Apr 09, 2007 at 12:05
Mike you posted;
"Now: having said that there HAVE BEEN a (very) FEW REPORTS of people having problems using modified sine wave inverters with some notebook computers and I HAVE certainly experienced two brands of low energy lamps which burned up when powered from my 300W MSW inverter. I DON'T KNOW WHY"
Mike, obviously if you don't know why, no-one else will either... L0L
FollowupID: 493245
Reply By: Member - Willie , Epping .Syd. - Friday, Apr 06, 2007 at 15:34
Hi Mike ,
I have a Fujitsu that needs 16 volts . Can I buy a gadget that I plug into the cig. lighter that will upgrade the 12 volt to 16 volt ?
That would be easier than using an inverter if it's possible .
Thanks ,
Willie .
AnswerID: 232005
Follow Up By: Mike Harding - Friday, Apr 06, 2007 at 15:42
Take a look at this Willie:
Site Link
Jaycar part number MP3467 if the link doesn't work.
Let us know how you go, please?
Mike Harding
FollowupID: 492924
Follow Up By: Member - Willie , Epping .Syd. - Friday, Apr 06, 2007 at 15:59
Hi Mike ,
I went to the site and that converter sounds perfect . My computer power supply states it puts out 16 v at 2.5 . The Jaycar unit does 16 v at 6 amps . I s this amp difference a problem ?
There is a Jaycar place only five minutes from me .
Thanks Willie .
How's the fossicking going ?
FollowupID: 492926
Follow Up By: Mike Harding - Friday, Apr 06, 2007 at 16:12
Nope, the amperage thing is fine: it just means it can provide more power than your computer needs.
Haven't done a lot over the past few moths, Willie, what with the bush fires and the summer heat I've taken a bit of a break but I shall be starting again as soon as I can find some time - doing some work at the moment! Not on, is it! :)
Mike Harding
FollowupID: 492927
Follow Up By: Member - Willie , Epping .Syd. - Friday, Apr 06, 2007 at 17:11
Thanks for that info Mike .
Did I tell you that I have booked myself in to a 14 day fossicking tagalong leaving from Marble Bar at the start of June . I am looking forward to it .
On Tuesday I am going down to parramatta where there is a fossicking type shop . I have to get a pick and ask what else I need . Any tips on gear I should have ?
( I am hiring a detector from the tagalong crowd )
Willie .
FollowupID: 492936
Follow Up By: Mike Harding - Friday, Apr 06, 2007 at 17:50
I think you said you were thinking of it. Good on yer Willie - I'm sure you'll have a great time and learn lots - you may even find some gold too :) - my offer for Vic still stands, of course.
Noooo... not really, a decent pick and the usual safety gear (less important in a group) - a magnet is useful for deciding what is NOT gold, a knife for scratching things to see if they gleam.... Don't need much else really except good humour :)
Have a good time Willie and let us know how you do :)
Mike Harding
FollowupID: 492941
