TROOPY gearbox problems??
Submitted: Thursday, Apr 05, 2007 at 09:05
ThreadID: 44014 Views:7002 Replies:10 FollowUps:15
As a follow up to previous posts on here- with various people having various problems with Troopy gearboxes !!
Just what are the weak links with the 'box?? What year or models are affected??
There also was a mention of running a pipe from the box to the transfer case?? What are the details on this fix?? and why??
Any other 'transmission' probs. that might arise??
BTW ours is a '94 HZJ75 Diesel (230000km)
Thanks (and have a safe Easter)..
DC
Reply By: longJohn - Thursday, Apr 05, 2007 at 09:32
I have a 95 HZJ75 and mine has the hose between the transfer case and gearbox also. It usually means the seal between the gearbox and the transfer case is leaking, and the hose is there to balance the pressure between the two to stop the pressure pushing the oil between the two. If too much oil goes from the gearbox to the transfer case, some will run back into the gearbox.
I dont know what the weak link is, it might be the countershaft is weak or soft or something apperantly they need replacing after a while, but mine suffers from having 5th gear fall out all the time. really annoying.
When driving down a hill at 90km/hr if you genlty lift your foot off the throttle 5th will pop out. Ive just learned to live with it. I figure when the gearbox gets worse then its time to take it out and fix it. While it is still going (and doesnt seem to be getting any worse) i can just leave it.
AnswerID: 231761
Reply By: Time - Thursday, Apr 05, 2007 at 10:14
This is what you want as a cheap fix for the seal issue Site Link
AnswerID: 231770
Reply By: Member - Doug T (W.A) - Thursday, Apr 05, 2007 at 10:18
Signman
the answer from longJohn just about sums it mate, and what he said about jumping out of 5th is 100% spot on , about the seal , also 100% spot on, about the hose also 100% spot on except that when I had mine repaired in Mt Isa the buggers didn't put it back so I had to buy a new hose ,
Longjohn as you said you learn to live the 5th gear , as you take your foot of the go pedal the left hand hits the gear lever to keep it in, it was a bugger though when a roo shoots out in from , right foot reacts to fast for the left arm and you find your car is in Nuetral , "angel gear" Mine was like that for months until it stripped the main shaft and then I had no motion at all in any gear, $3500 parted with and away we went and that was about 520,000 Ks
AnswerID: 231772
Follow Up By: Member -Signman - Thursday, Apr 05, 2007 at 11:15
G'day Doug
Do you know a bloke named Tex- does your sort of work over your side of the paddock. I think he drives a Ford F series.??
With the bypass hose- is it a preventive maintanance job- that is- just do it because...or is there symptoms that require the hose to be fitted. And where does the hose go from-to ???
DC
FollowupID: 492751
Follow Up By: Member - Doug T (W.A) - Thursday, Apr 05, 2007 at 11:21
No I don't know him mate ,
The hose ... take out the 2 filler plugs and fit hose in place, Someone posted a photo of the hose only about 2 weeks ago .
See the photo's Steve posted below.
FollowupID: 492753
Follow Up By: Member -Signman - Thursday, Apr 05, 2007 at 13:25
Doug
Done a search and can't find pic of mentioned hose?? Can you recall the post topic ??
FollowupID: 492769
Follow Up By: Member - Doug T (W.A) - Thursday, Apr 05, 2007 at 13:32
Signman
I'll have a look too
FollowupID: 492771
Follow Up By: furph - Thursday, Apr 05, 2007 at 13:42
Jumping out of fifth on over run/ lifting foot off can be as simple as the breaking up of the nylon bush at the bottom of the gear lever.
Mine did it at about 95000km., a motor mechanic mate suggested what the problem could be, Toyota suggested a $2000 + gearbox rebuild, we took the gearlever out (bit tricky with the sping loaded cap) and hey presto: nylon bush totally disintegrated.
Replaced and no more problem, vehicle sold at 300000km. without any more slipping out of gear.
Just have a look there first.
furph
FollowupID: 492776
Follow Up By: Member - Doug T (W.A) - Thursday, Apr 05, 2007 at 13:43
Bugger, must be old age , it was in one of my posts
PostID: 43605
Go and get one of these
FollowupID: 492777
Follow Up By: Member -Signman - Thursday, Apr 05, 2007 at 14:10
mate
Yup- found that same one on ebay- $25..
I gather no probs. fitting it if the seal is NOT suspect...
FollowupID: 492781
Follow Up By: Member - Doug T (W.A) - Thursday, Apr 05, 2007 at 14:15
Nope....just stick it on
FollowupID: 492782
Follow Up By: Member - Doug T (W.A) - Thursday, Apr 05, 2007 at 14:20
Add some Wynnes or Slick 50 too
FollowupID: 492785
Reply By: wilko65 - Thursday, Apr 05, 2007 at 10:45
Second and third synchro's seem to be another problem, in our work vehicles anyway. they are traybacks not troopies, but I believe they are the same box. Some have gone as early as 30,000klm and some as late as 80,000klm while some have done them 3 times by the time the vehicle has 100,000klm on it. But they do all seem to do it. The fact that we are on a mine site and the vehicles are fleet vehicles means that Toyota don't cover warranty. Probably a particularly harsh environment, but thats what they are built for? It has been such a concern that the company,(the big Australian), has changed to Nissan. We'll see how they go. No matter what vehicle we have there is going to be a weak link.Our mine site does not have an airbag requiement yet. Not sure what they will do when the last of the 4.2 ltr's run out.
AnswerID: 231781
Reply By: Member - Steve T (NT) - Thursday, Apr 05, 2007 at 10:50
Hi Signman
The problem with the 75 series is this the main shaft looses it hardening between the gearbox and the transfer case, generaly this is caused because of towing in 5th gear under 100kph.
The seal is a common problem in the 75/78/79 series, and the hose does work.
The problem with the 78/79 series, is they changed the main shaft and split it in 2, so the transfer shaft is the 2nd piece.
this was joined by a sleeve that would strip under torque.
!MPG:25
This is Toyota has fixed the problem.
!MPG:24!
This is the transfer shaft.
!MPG:23
Cheers Steve.
AnswerID: 231783
Reply By: Member - Steve T (NT) - Thursday, Apr 05, 2007 at 10:59
Hi Signman.
I will try again.
The problem with the 75 series is this, the hardening of the main shaft is worn off between the gearbox and transfer case.
This is caused mainly because of towing in 5th gear under 100 kph.
The seal problem is common in the 75/78/79 series and the hose does work.
The problem with the 78/79 series is the main shaft is now 2 piece and joined by a sleeve that was to small and kept stripping
AnswerID: 231785
Follow Up By: Member - Steve T (NT) - Thursday, Apr 05, 2007 at 11:03
Try again
!MPG:25!
This is the Toyota fix it.
!MPG:24!
This is the shaft I talk of.
!MPG:23!
Hope this answers your question.
Cheers Steve .
FollowupID: 492748
Bloody ripper Steve. well done
FollowupID: 492754
Follow Up By: Member - Steve T (NT) - Thursday, Apr 05, 2007 at 11:56
This is what happens when the seal fails , the oil ends up in the transfer case and spews out the breather, leaving no oil in the gearbox.
!MPG:27! !MPG:26!
BUGGER.
FollowupID: 492761
Reply By: Member - Stephen M (NSW) - Thursday, Apr 05, 2007 at 12:15
Common problem with the early hilux's as well involving the seal. Easy fix and permanant is the hose between the two. Sh#t load cheaper then spliting box/transfer apart and replacing seal and chances are it will happen again. Regards Steve M
AnswerID: 231800
Reply By: Member - Doug T (W.A) - Thursday, Apr 05, 2007 at 14:00
Signman
Just found this site , might be of interest to you
www.toyotagearboxes.com/products.html
AnswerID: 231818
Follow Up By: Member -Signman - Thursday, Apr 05, 2007 at 14:17
Thanks Doug (and all the others with their input to the post)...
At this stage I have no issues with gearbox problems (touch wood)..just a bit stiff thru the 'box first thing when cold..(wrong grade oil I think).
I'm a firm believer in 'preventative maintenance' ..as opposed to 'drive it til it breaks'.
FollowupID: 492784
Reply By: hiab - Thursday, Apr 05, 2007 at 22:25
the hose is not needed in late model toyotas as the transfer and box are seperate and sealed so oil cant go from one to another as in the early models, 5th gear has always been a weak link in toyotas, it is not in the box as such but behind it .i work at a 4x4 specialist workshop and we have rebuilt 3 in the last two weeks from older troopys and a 60 series, always get firm quotes, the parts only cost about 780 bucks, if the mainshaft is ok, the rest they soak up in labour, our tranny,no not that sort, expert can have the box out and rebuilt and back in going in less than 6 hours so be careful you dont get touched.
AnswerID: 231918
Follow Up By: Member - Steve T (NT) - Thursday, Apr 05, 2007 at 22:36
Hi Hiab
When you say late model you are talking about the 78 series as well?
Because if you are, the gearbox pics above this post is out of a 78 series, the seal failed and filled the transfer with oil until it spewed out the breather on top of the transfer, leaving the gearbox empty and the said car in no go mode.
Cheers Steve.
FollowupID: 492858
Reply By: hiab - Thursday, Apr 05, 2007 at 22:45
79 series, by the way 60 series box i mentioned was mine, 504,000 ks. handy having a mate at work, only paid for parts at trade labour was covered by copius amounts of xxxx gold, while i was at it i got excited and pulled the motor and gave the old girl a rebuild as well, liners pistons, all bearings crank was ok, machined the head,{in house}, injectors, gave the cam a lumpier grind , opened the ports a bit, changed fuel to suit and am now running her in, it will outlive me i reckon. just wish they made there boxes as strong as nissan, ouch that hurt to say that, but it is true, cant remember the last nissan box in for rebuild.
AnswerID: 231920
Follow Up By: Member - Steve T (NT) - Thursday, Apr 05, 2007 at 22:51
The 78 and 79 are identical gearbox and transfer.
Steve.
FollowupID: 492860
Reply By: hiab - Thursday, Apr 05, 2007 at 22:58
same but different, we could sell heaps of transfer hoses, but the boss is an honest man, hard to find in this trade i can tell you, and as katherine is a small place you look after the customers and they keep coming back. i will check with the box man tomorrow and clarify , boxes are not my department, so i will find out and get back.paul.
AnswerID: 231925
