Back home from GCR Warrakurna Trip
Submitted: Thursday, Apr 05, 2007 at 20:48
ThreadID: 44033 Views:3849 Replies:2 FollowUps:2
Hi All,
Arrived home last night from a trip out to the Warrakurna community, my Daughter is working out there as a teacher so I took the opportunity to go and visit and bring her back home for the holidays.
left Perth last Wednesday afternoon unsure of the chances of getting through as the road was closed, but managed to get through ok, couple of bad spots but no major issues.
Had an unreal time at the community, spent some time with the Kids in school and Dave and Margaret from the Giles weather station showed me around the area.
There are some amazing places in the Rawlinson ranges, in particular Gills Pinnacle, which is about 60k towards Docker river from the Warrakurna roadhouse, a series of water falls and pools descend from the ranges at this place, well worth sacrificing a new tyre driving up the creek to get there. (wet rocks love tyres)
The return trip to Perth was rather eventful as well, the GCR was still closed between Warburton and Tjiukayirla although when i came up they were letting people through but apparently the shire had tried to lay some culverts across the road and this made things worse and the road was impassable.
We decided to take a detour around the road works, this involved heading up the Tjirrkarii/Wiluna road, then cutting back on the Kanpa road, this hit the GCR just below the doomed roadwork's.
We left Warrakurna at 3:30pm Tuesday after school finished, stopped at Warburton for some fuel, should have listened to advice at Warburton that our planned route was not to flash but we had other advice that it was ok, anyway about 40k up the Tjirrkarii road we hit a large stretch of water across the road, one abandoned ute bogged in the middle with numerous sticks poking up presumably identifying obstacles, the entry was not to bad but the exit was nasty and to far away from the entry to attempt a recovery by the second vehicle even with all our recovery gear joined.
It was just getting dark but we had noticed a fresh track off to the left that skirted the boggy hole, it appeared to head into the scrub about a 100m then ran parralel with the road and rejoined the road about 200m down, it was a fresh track and had been used by a couple of vehicles, so going against my better judgement (I do know you should always stay on the road and go through the centre of the water) we took the bypass.
I went first and got through ok, although it was a bit soft and my Nissan being auto probably saved me as I had plenty of speed at first and was able to drop back to low to continue when it started to bog down, my companion was not so lucky, he went down to the diffs with about a 100m of soft stuff between him and my me, oh dear.
It was now dark, we spent a hour trying to dig the bogged Nissan out with no luck, I had a Bull air bag jack, it was not easy to get this to work as it continualy slipped out in the mud, but eventualy we did get it to lift it up but then it slipped on the chassis rail in met a sad end agains a body support bracket,still we had managed to get a few peices of wood under the rear wheel and had dug the front free, with some severe pushing we got it to drive about 2 x feet before it sunk again back onto both diffs.
Fed up by now and again against my better judgement I decided to bring my Nissan back accross the damp ground to get behind the bogged Nissan and snatch him out, as you would have guessed that did not work, with both Nissans now down on both Diffs in the Mud, it was about 9:30 at night and we were along way from any assistance, many lessons learn't here.
It took another 2hrs, a lot of digging by hand, jacking using trees and spare wheels as jacking plates, near flat tyres but we eventualy retrieved both cars, the "swamp was a 100 meters or so wide and even when we managed to get them up we would drive 10m and they would go down again, but persistance saw us on the right side of the swamp to continue.
We had another 100 odd k's to go before we hit the GCR, this included quite a few more long water crossings in the dark as well as a couple of decision on which was the correct track, one water crossing was paticularly nasty with some deep holes, speed and hanging on tight was the only way through, eventualy we hit the GCR and made our way to Tjiukayirla roadhouse arriving at 2:00am Wednesday morning (yesterday).
I learnt a few lessons on this ordeal, I have done quite a few remote trips and are normaly much better prepared, this trip was never intended as an offroad adventure, and I was not carring any camping gear or supplies apart from water of coarse and some drinks in the Engel, I had thrown in some recovery gear as I new there was a chance of some difficulty on the GCR, but I don't consider the GCR remote so I did not carry to much else, next time I won't venture into the remote wilderness without enough supplies for when things go wrong.
Reply By: kimprado - Thursday, Apr 05, 2007 at 21:12
Mick
Don't be too hard on yourself. Many of us get into situations irrespective of experience.
Kim
AnswerID: 231894
Reply By: Bilbo - Thursday, Apr 05, 2007 at 22:15
Hmmm,
Several "bush lessons" here.
1. Don't travel on bush roads at night unless you REALLY have to. Spend enough time in the bush and you'll notice that the locals don't.
2. Rule number one applies even more so if it's been raining. Spend enough time in the bush and you'll notice that the locals never do. They just sit tight 'n wait for another day.
3. If there's any doubt, and I mean any doubt at all, don't go. Wait a day or two and keep in touch with local police and shire councils. The locals aren't stupid, they travel these roads day iin and day out.
4. If a road is closed, then it's CLOSED, even if someone says it's OK it's usually not.
5. Prevention is better than cure. Discretion is the better part of valour. It's better to have a quiet, early night, a few beers and a hot meal AND be 2 days late getting home than it is to be digging one's way out of a dangerous situation where one could lose one's car - FOR GOOD!
You did well to get out of it. But did you REALLY need to get into it to begin with? I've fallen for the same trick myself - 5 hours to do 75 metres. Never again.
Let that be a lesson to you,,,,,,,,
Take care,
Bilbo - "The hobbit that HATES being bogged!"
AnswerID: 231915
Follow Up By: MickWA - Thursday, Apr 05, 2007 at 23:45
Cheers Bilbo,
I tend agree with most of what you say, although I have lived in the Bush most of my life and driving at night or on wet roads would not be unusual locals or not, my mistake realy was driving unfamiliar roads in both those conditions.
The road we were on was not closed, it's not a gazzeted road as such, but all roads in the area are open except for the small section of the GCR, but I can say after trying to get the condition of the GCR over the last week from both shires and the police is not a straight forward thing, different stories from all, sure it was closed but where, for how long and why varied. The problem with the GCR at the moment is the shire let low loader trucks go through last weekend, these became bogged and destroyed the road, when i went through on Tuesday the word was coming from both road houses it was ok to go (road was still closed), I cam across another float truck with a large loader on the back he had stopped and unloaded the loader to fill in a paticularly bad water crossing, talking to them the main roads had given them the ok to come along the road on the proviso they assited in filling in some of the major wash outs, i passed that truck last night bogged on a jump up in some fresh roadworks about 80ks before TJiukayirla he had the loader there trying to pull himself out, what ever happened to opening roads to light vehicles first ?.
FollowupID: 492865
Follow Up By: Bilbo - Friday, Apr 06, 2007 at 09:43
Mick,
It sounds like you've been the victim of right stuff up here. Nobody in authority seems to know whats' what.
If a road is "Closed" then it's closed. It can't be "half closed". Yes - yer right, "light vehicles only at first". But it looks like The Main Roads tried to coerce some help and it backfired on 'em.
Amazing.
Bilbo
FollowupID: 492892
