Ticks and how to get rid of
Submitted: Friday, Apr 06, 2007 at 17:50
ThreadID: 44056 Views:9989 Replies:9 FollowUps:4
Just got back from a few of days at Shipwreck Creek near Mallacoota and while there managed to get a couple of ticks on me (wife got one too) while bushwalking. Just wondering what is the best way of getting rid of the freeloading little bludgers and if you can do anything to keep them off you ?
We pulled them out with tweezers and there is still a lump a couple of days later.
Also wondering if the are seasonal or if they are there all the time ?
Reply By: Notso - Friday, Apr 06, 2007 at 17:55
Best you go to your Dr now that they are out? or maybe have left behind moth parts.
check out this site for instructions in future.
www.tickalert.org.au/removal.htm
AnswerID: 232022
Reply By: brett - Friday, Apr 06, 2007 at 17:59
Last one I got was on my chest and after getting it out I had a lump the size of a 20c coin for weeks after. Last I read they suggested you spray it with an insect repelant that contains pyrethrin as it acts as a narcotic and stops the tick injecting more saliva, metho and stuff just gets them cranky and they inject more and bury deeper. There is a wide range of opinions on this though, some will say don't put anything on it
AnswerID: 232025
Reply By: obee - Friday, Apr 06, 2007 at 18:09
I copied this from the web.
If a tick is detected that is attached, never attempt to place any chemical such as methylated spirits onto the tick, nor should it be touched or disturbed, as the tick will inject saliva into the skin, which could make the situation worse. Rather the tick should be sprayed with an aerosol insect repellent preferably containing pyrethrin or a pyrethroid (if a repellent cannot be found which contains a pyrethroid, then Lyclear, a scabies cream containing permethrin will work fine). The combination of hydrocarbons and the pyrethrin acts as a narcotic and a toxicant, and prevents the tick from injecting its saliva. The tick should be sprayed again one minute later (or dabbed with the Lyclear) and left. After 24 hours it should drop off naturally or be gently removed with fine-tipped forceps. It is normal for a tick bite to remain slightly itchy for several weeks, however if other symptoms develop, then a doctor should be consulted immediately.
President Bush will probably send a hit man cos I breached the copyright laws we inherited from the free trade (for america only) agreement.
Owen
AnswerID: 232029
Reply By: Member - Dunworkin (WA) - Friday, Apr 06, 2007 at 18:12
For what it is worth, when I was much younger than I am now I and my sister used to do a lot of Sunday hill climbing on the Stirling Ranges and most times came home with at least one tick on one of us, our solution was to get a lighted match and burn it slightly on the end, (being sure not to burn yourself) by doing that they would reverse out themselves. There was always a small red lump for a few days later. I believe a hot needle would do the same trick.
The idea is to get them to come out of their own accord otherwise you leave their feelers etc. behind and that can create a problem.
Granny's method or not it use to work for us, but WA ticks may be different to the ESs ones. Lol
My experience.
D
Simba, our much missed baby.
AnswerID: 232030
Follow Up By: blue one - Sunday, Apr 08, 2007 at 15:22
Brilliant
FollowupID: 493171
Reply By: Member - Uncle (NSW) - Friday, Apr 06, 2007 at 19:27
All we ever do is smother the tick in kero, they cant breath, so they let go and you can then remove them with tweezers. :)
AnswerID: 232041
Reply By: Member - Doug T (W.A) - Friday, Apr 06, 2007 at 19:51
Alcohol will remove them , and I don't mean beer, something with POWER;
I was told by a Vet, For the wife we might .... suggest Frontline on the back of the neck so she can't lick it off ......lol ---ok I'm gone ..a runnin'
Doug
AnswerID: 232044
Follow Up By: Member - Brian H (QLD) - Saturday, Apr 07, 2007 at 08:36
LOL ...... I'm all for the alcohol, and simple use the burnt match and kero on the wife (not at once of course) lol. I got a flamin wife now no need to fire her up anymore than I do now :) :) also making quick animated steps for the exit :)
Brian
FollowupID: 493013
Reply By: Member - Ed. C. (QLD) - Saturday, Apr 07, 2007 at 01:32
Aerogard..... (or any similar product containing DEET as the active ingredient)..
www.mortein.com.au/common_questions_4.html
Confucius say.....
AnswerID: 232097
Follow Up By: Member - Willie , Epping .Syd. - Saturday, Apr 07, 2007 at 18:24
I'll second the Aeroguard - it worked great on my dog when she had two ticks on head .
Willie .
FollowupID: 493081
Reply By: Member - Bentaxle - Saturday, Apr 07, 2007 at 09:22
Teetree oil will get rid of them and at same time stop the irritating itch, SWMBO swears by -from experience
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 232113
Follow Up By: Member - Des - Monday, Apr 09, 2007 at 11:19
We use this method too. Very effective, and the tea-tree oil is an excellent disinfectant. Need to use highly concentrated tea-tree oil. It is good stuff to carry in first aid kit anyway.
Also carry very fine pointed tweezers to get the head of the tick out.
The main thing with ticks is to get them early. Need to check often.
FollowupID: 493242
Reply By: garthyguts - Monday, Apr 09, 2007 at 09:22
buy a tick comb
AnswerID: 232336
