HF radio aerial mounting
Submitted: Saturday, Apr 07, 2007 at 08:35
REV'S
Good morning all.
I have mounted my HF aerial on the back of my 80 series in past years . We are in the process of setting up a 70 series cab chassie with a slide on camper . I cannot mount the aerial on the back . Is it legal to mount the HF aerial on the bull bar?
Have a good
Easter
Allan & Maryanne
Reply By: Member - Phil G (SA) - Saturday, Apr 07, 2007 at 09:41
Depends on the Aerial. If its a tapped whip aerial, then you are fine. If its an autotune, it will be greater than allowable width, and in most states it will be not allowed. Lots of people still fit them on the bullbar.
Options I've seen:
#1 I saw a really neat swing up bracket for a Barret autotune that allowed it to swing down behind the top of the bullbar for around town and simply pull a lever and it could swing upright for out of town.
#2 You can fit them adjacent to the rear cab pillar using a swing out bracket that is mounted on the "front" of the tray. Its a bit exposed to overhanging trees for my liking and it can obstruct your rearward vision down the side. Maintaining clearances around the aerial is difficult, which is why it would need to swing.
#3 Maybe still use a swing-a-way on the rear.
phil
232116
Follow Up By: REV'S - Saturday, Apr 07, 2007 at 13:18
Thanks Phil for your reply,
We have the auto tune aerial, so it is fairly thick. Had in mind a swing arm style, I reckon that's our only option at this stage, unless someone can come up with a better idea.
Regards Allan
493050
Reply By: John R (SA) - Saturday, Apr 07, 2007 at 13:43
Although I haven't yet got a HF as yet, I've often wondered where I'd put the aerial (on a dual cab with tray & slip-on).
I hate aerials and so on in my field of vision, so would avoid the bull bar, but plenty of other people seem happy with them there. At least if it's mounted on the channeling rather than topbar there ought to be reasonable strength.
I'd be most inclined to mount it at the back, either on a mount on the camper or tray, and remove the aerial when not required. However you don't sound too keen on that option.
Other option as mentioned above is on the front of the tray, with the top of the tuning mechanism level with the top of the roll bar.
232135
Follow Up By: REV'S - Saturday, Apr 07, 2007 at 14:27
Thanks for your reply
493051
Reply By: MEMBER - Darian (SA) - Saturday, Apr 07, 2007 at 16:36
I have seen them mounted just behind the cab and at the rear too, on vehicles with your setup...... now where to find a pic........
232146
Reply By: lindsay - Saturday, Apr 07, 2007 at 17:38
If you are in Victoria, there is a ruling from Vicroads in the vehicle standards information No 29. It deals with drivers field of view requirements, it is quite clear.
Go to www.vicroads.vic.gov.au and follow the links to the vehicle standards information. I have
mine in front (Codan auto tune late model) mounted on the bumper bar,behind the bull bar on one side of the vehicle. When I get in the bush i pace it in the middle , on top of the bar where i can keep an eye on it for obstructions ect.
232153
Reply By: jdpatrol - Saturday, Apr 07, 2007 at 22:26
On a different tack, one website refers to front mounted bullbars as 'emu attractors'. Reckon you need to think about that message. Might not be an emu but what about a kangaroo etc..... Fair bet that reference came about through bad experiences too. You buy a HF to get help - if at all possible you want to mount it where it will work after an incident or something. JD
232199
Follow Up By: Member - Phil G (SA) - Sunday, Apr 08, 2007 at 10:07
JD, A wire aerial is a very cheap backup if the autotune gets trashed. I carry one for that reason.
phil
493150
Follow Up By: jdpatrol - Sunday, Apr 08, 2007 at 12:19
Bugger, yet another thing I have to get/make! I got a 'how to' somewhere though.
493163
Follow Up By: Member - Phil G (SA) - Sunday, Apr 08, 2007 at 19:03
Hi JD,
I have a length of 10amp wire thats 8.88metres long (this is the tuned length for 8.022 MHz which is the main VKS Channel). I have a length of coax that goes from the back of the set to somewhere outside the vehicle - the centre wire of the coax plugs into the wire aerial, while the coax braid needs to go to a good earth on the body of the vehicle.
If you've been down to Electric Bug on Torrens Rd, they sell a 9 metre aerial called a "Superrod" - what I've described above is what is fed up the middle of the Superrod.
493185
