GU Strange Proplems
Submitted: Monday, Apr 09, 2007 at 09:17
Member - Battlecat (WA)
Hi all,
Hope that you had a great
Easter.
I have a GU IV 3ltr TD Nissan Patrol ST - did a salt
water river crossing and when I got to the other side the Troll lost power. It was still running and you could rev the engine (like normal) but as soon as you selected a gear the power (revs) went and the engine went back to idle - in all gears.
Pulled out the Lanotec and gave everything a going over in the engine bay and unplugged the battery to re-set the computer and then everything was peachy. Haven't had this happen before and she loves
water (normally) - would hate for that to happen half way over the crossing!
Any thoughts?
Reply By: GUdeano - Monday, Apr 09, 2007 at 09:30
Fit a Chev diesel V8 and then you can stop stressing.
232337
Follow Up By: Member - Battlecat (WA) - Monday, Apr 09, 2007 at 12:20
It is on the cards for later
493248
Reply By: Member - Troopytrek - Monday, Apr 09, 2007 at 09:32
G,Day Battlecat Your problem could be a badge problem i.e. a nissan not a toyota. Just joking, probably has got
water in one of your sensor plugs which can either send your computer into whats called a safe mode or even your sensor into something similar. best way to combat is remove every plug spray some electroclean into it the place some silicone grease in and re-plug this stops the moisture getting in. Cheers Troopytrek
232338
Follow Up By: Member - Battlecat (WA) - Monday, Apr 09, 2007 at 12:21
Will do for sure - just not sure which one as I normally keep all the visible plugs coated in Lanotec. Cheers
493249
Reply By: Member - Sam (NSW) - Monday, Apr 09, 2007 at 11:47
If the only difference between this crossing and all the others you have done is that this one was salt and the others were fresh
water, then it could have been a short caused by the salt as salt is a conductor and the salt
water may have given better conductivity compared to fresh
water, hence causing the short.
232365
Follow Up By: Member - Battlecat (WA) - Monday, Apr 09, 2007 at 12:19
Hi Sam,
Have hit the salt before but I am unsure which connector would be shorting / so I know which one to Lonotec the shut out of and then seal it. Cheers mate
493247
Reply By: Member - Oldplodder (QLD) - Monday, Apr 09, 2007 at 12:58
Could it be the Lanotec?
Lanotec is non conductive. It is a good isolator.
Look at the lanotec web site.
" target="EOF" class="lbg">www.lanotec.com.au/lanotec.php?link=12
Friend did the same thing sparying Lanotec around, and he found it isolated the contacts. Great for freeing parts, and preventing rust, but not good for electrical contacts.
Lanotec have tested it to 70kVa, and recommend cleaning contacts after use.
You need to use a good citric acid cleaner too, it is very hard to get off.
This stuff is definitely not WD40 or similar products.
I use it, and highly recommend it, for the right job :o)
232375
Follow Up By: Member - Battlecat (WA) - Monday, Apr 09, 2007 at 14:25
Could be - but it happened before the Lanotec. Love the stuff as
493259
Reply By: Dingo77 - Tuesday, Apr 10, 2007 at 09:15
Hi Guys,
Does Lanotec remain wet (tacky) or does it dry after a while?
232510
Follow Up By: Member - Battlecat (WA) - Thursday, Apr 12, 2007 at 06:10
it drys - stays slippery though. Great stuff
493721
Reply By: Leroy - Tuesday, Apr 10, 2007 at 10:03
'but as soon as you selected a gear the power (revs) went and the engine went back to idle - in all gears. '
Is it an auto or manwell?
232518
Follow Up By: Member - Battlecat (WA) - Thursday, Apr 12, 2007 at 06:11
Manual
493722
