HERCULES tyre report
Submitted: Tuesday, Apr 10, 2007 at 10:54
Member -Signman
Hercules TerraTrac A/W- 265/75R16 fitted to HZJ75 Troopy.
Been on for 5250km- new tread depth 10mm, now about 9.5mm front, and just a 'mickey hair' under 10mm on the rear. On road tyre noise minimal, just enough to let you know they're not a highway tread.
Initial over-steer on the winding hills around here (compared to Bridgestones). I put this down to the softer (not necessarily weaker) sidewalls on the Bridgestone. A bit of playing with tyre pressures dialled this out, and handling now almost neutral.
OK- spent Saturday 'playing' in the Yengo N/P and the Howes Valley area. Conditions- WET.
Sandstone outcrops, shaley, wet slippery clay and black mud. In all conditions I was very impressed with the tyres. No need for lockers in any situation, and in the mud- cleared easily, although did built up a bit in the red clay. Good traction on steep descents and ascents in very loose, wet shale. 4 other vehicles and all had different tyre brands and the Hercs. equalled or outperformed the other brands/types (including the high profile brands).
Sunday and it was
Stockton Beach. Aired down to 20psi. Again no probs. in the sand. Judicious use of the throttle and attacking the sandhills (with a diesel engine) and no signs of digging in. The sand was reasonably firm in
places, having had a fair bit of rain over the previous days.
Overall (in my opinion) a very good, value for money tyre.
Reply By: rolande- Tuesday, Apr 10, 2007 at 19:45
G'Day Signman,
Got a set of 10 ply Terra's on the Patrol in the same size.
Judging by current wear, will get 60 - 70K out of them.
For $180 per tyre they are hard to beat.
If you need a more aggressive tyre, just go for the Mud Terrains.
The A/W suit me fine though.
Just a question, I measured
mine at 12mm tread when new, interesting to hear about some only having 10mm
Rolande
232625
Follow Up By: Redback - Tuesday, Apr 10, 2007 at 19:58
Where did you get them from, i tried from tyrepower at blacktown but had none in stock.
Baz.
493510
Follow Up By: rolande- Tuesday, Apr 10, 2007 at 20:11
G'Day Baz,
They are imported by these guys
chapel corner tyres
Should be able to help you out with a supplier in
Sydney
Rolande
493517
Follow Up By: Redback - Tuesday, Apr 10, 2007 at 20:18
Thanks mate, i'll call them tomorrow.
Baz.
493521
Follow Up By: 120scruiser (NSW) - Wednesday, Apr 11, 2007 at 17:42
cc tyres in Penrith stock them.
Batt Street (02) 4731 4822
493655
Follow Up By: Redback - Wednesday, Apr 11, 2007 at 18:04
Thanks for that i'll try them tomorrow and hopefuly they'll have them in stock, i really need to get some before we go away.
I'm after the Terra Trac M/Ts
Baz.
493661
