re-set or buy new leaf springs???????????
Submitted: Tuesday, Apr 10, 2007 at 13:58
Bluey221
The springs in my troopy are sagging, about 60mm below what they should be in the front and sagging in the rear also but not quite as bad. I m wondering whether I should just get them re-set or get new ones. I would prefer to have the extra money in my back pocket for our trip up north, but I would also like to not be paying for a tow truck half way between
Cairns and
Cape York. I have heard some good things about "Allset springs'' up here in Qld. Any info would be greatly appreciated.
Joe
Reply By: Member -Signman - Tuesday, Apr 10, 2007 at 14:01
G'day Joe
Hasn't this topic been covered before?? A few weeks ago ??
232539
Reply By: Tony - Tuesday, Apr 10, 2007 at 14:28
Do it right, replace
the springs with new ones. Re-setting does not last all that long, when you are carring touring weights.
232543
Reply By: Member - Stephen M (NSW) - Tuesday, Apr 10, 2007 at 14:58
As Tony has said do it the write way. They arnt that expensive and at least there is a lot less chance of snapping one. I had OME in the old lux and they did about 270k before I replaced the front one's only, the back were still fine. The place where I got
mine replaced wont reset them. Its either buy new or go some where else as they said to me I would be back within 6 months due to them saggin again. Good enough answer for me and took there advice. Approx $300 for the two front ones. Regards Steve M
232551
Reply By: Member - Steve T (NT) - Tuesday, Apr 10, 2007 at 15:17
Hey Bluey221.
I have owned 3 troopies over the last 10 years, I always took them to L&S springs to have them reset as soon as I bought them.
These trucks worked 6 days a week, carrying 9 pax and a full
camping trailer, I never had a problem with the reset springs.
Put the extra money in your pocket.
Cheers Steve.
232553
Reply By: Member - Phil G (SA) - Tuesday, Apr 10, 2007 at 16:12
The local springmaker, Industrial Springs in
Adelaide would normally reset and add an extra leaf. We have a 60series in the family that had this done about 15 years ago, and
the springs are still fine, so if they are done properly, its OK.
232561
Reply By: Mikee5 (QLD) - Tuesday, Apr 10, 2007 at 16:58
Hi Joe,
I had an old (1979) Troopy. The original springs sagged so I replaced them with aftermarket (Opposite Lock from memory) These were longer in the leaf, giving a bit of lift and longer travel. These springs did not sag nearly as much but in the 20 years I owned the truck they were reset once.
In Queensland there is a guy in Kippa Ring - Paul Jarman of
Redcliffe Springs and
Suspension who knows his stuff and is not tied to a particular product.
If he is local to you give him a call. He does resets as
well as selling new springs.
Mike.
232570
Reply By: Member - lyndon K (SA) - Tuesday, Apr 10, 2007 at 17:49
Hi Joe
Are
the springs original? How old is the Troopy? Reason for asking, is if it's not to old(current
suspension type), ARB etc throw brand new springs in their
bins. Thats where
mine went, tried to sell them but not one call.
Regards Lyndon
232579
Reply By: Member - Leigh (Vic) - Tuesday, Apr 10, 2007 at 19:17
May I suggest you consider the option of a couple of air bags, double convoluted type. Kits available and easy to fit. I find it also reduces ride harshness. Cheers
232605
Reply By: Kumunara (NT) - Wednesday, Apr 11, 2007 at 19:35
Buy new aftermarket springs.
Toyota springs are notorious for sagging. Ir you reset them they will sag again and you will have wasted money.
232811
Reply By: Middle Jeff - Wednesday, Apr 11, 2007 at 19:52
Hi Joe
If you have standard springs then replace them with a good after market set then when they sag have them reset. I had a set of lovel springs years ago and they recomended to have them reset as they made better springs in the long run.
Have fun
Craig
232819
