Water Tank Taste
Submitted: Tuesday, Apr 10, 2007 at 19:27
ThreadID: 44176 Views:3925 Replies:14 FollowUps:8
Can anybody tell me what I can do to remove the taste of the fresh water tank fitted to my camper trailer. Unit is new as it makes the water very hard to drink due to the taste. Old wives tales can be included.
Reply By: Gronk - Tuesday, Apr 10, 2007 at 19:30
If you don't like the taste of fresh water, just put some old stuff in !!!!!!!!!!!!!!
AnswerID: 232614
Follow Up By: dan-the-man - Tuesday, Apr 10, 2007 at 19:31
ha, thats pretty funny!!! i laughed
FollowupID: 493501
Reply By: Member. Rob M (QLD) - Tuesday, Apr 10, 2007 at 19:32
Stoker,
Try using Milton in the tank. It is used for sterilising babies bottles and has always worked for our new tanks.
Regards.
Rob M.
Rob M
AnswerID: 232615
Reply By: holland - Tuesday, Apr 10, 2007 at 19:35
Most Marine shops around sell water tank "conditioners" that you flush through your system. You will have to do this from time to time. Cheers
AnswerID: 232617
Reply By: walks - Tuesday, Apr 10, 2007 at 19:37
bi carbe soda, will do the trick, had the same prob myself
AnswerID: 232618
Reply By: Member - Crazy Dog (QLD) - Tuesday, Apr 10, 2007 at 19:42
Bi Carb is the go!! Just did mine 'fore heading off for Easter...
Grrr!!!
AnswerID: 232623
Reply By: Redback - Tuesday, Apr 10, 2007 at 19:54
Stop wasting your time with all these so called additive that clean and make your water taste good, they don't work, install a twin filter (for germs and taste) water filter in between the pump and tank, then you only need to flush your tank every 3 to 6 mths to keep crud from building up in the tank.
Baz.
AnswerID: 232627
Follow Up By: dan-the-man - Tuesday, Apr 10, 2007 at 20:02
or drink beer instead
FollowupID: 493512
Follow Up By: Redback - Tuesday, Apr 10, 2007 at 20:08
Yep that too, in fact maybe a better option, lol.
FollowupID: 493514
Follow Up By: Member - Andrew (QLD) - Wednesday, Apr 11, 2007 at 07:01
::they don't work::
really? You must be the only person drinking clean water then if that don't work....
FollowupID: 493549
Follow Up By: Redback - Wednesday, Apr 11, 2007 at 18:15
They may clean the water, but it still taste funny, but each to their own, if you want to add cleaning crap to your water that's fine with me, i like good tasting filtered water when camping as you can't get tap water in the bush.
I don't go to Van Parks and on ocassionS i fill the camper tank with river water, some of the rivers we have filed from weren't the clearest or cleanest, but the filters took care of that, making the water clear and and it taste good too from the campers kitchen tap.
Baz.
FollowupID: 493666
Reply By: Granpa Joe - Tuesday, Apr 10, 2007 at 20:02
Hey Stoker,
Try this , it stopped the other half complaining about the taste so it must work!
Site Link
AnswerID: 232630
Follow Up By: Redback - Tuesday, Apr 10, 2007 at 20:09
Rubish didn't work for me, still had that plastic taste and the missus still winged
FollowupID: 493516
Follow Up By: Granpa Joe - Tuesday, Apr 10, 2007 at 20:28
Work if it is brought up through all of the supply pipes and left to sit as per the instructions.
Maybe the missus just likes to whinge eh? : )
FollowupID: 493526
Follow Up By: Redback - Tuesday, Apr 10, 2007 at 20:38
Yep followed the instructions to the letter, but yes you may be right about the missus ;-))
FollowupID: 493528
Reply By: lunchbuckett - Tuesday, Apr 10, 2007 at 20:31
remove all clear and white hoses from tank and pumps taps ect replace with black polly then wash tank with bottle wash from home brew shop
AnswerID: 232642
Reply By: japmel - Tuesday, Apr 10, 2007 at 20:44
Pour a litre of Vinegar in the Tank then fill up with water, Tow the Trailer around the block then leave it to stand for a couple of hours, Then drain and flush the tank with fresh Water.
It's the cheapest option to start with, And it worked for us.
AnswerID: 232652
Reply By: Member - Troopytrek - Wednesday, Apr 11, 2007 at 06:15
G,day Stoker571, we have found that garden hoses can leave a feral taste in your water as well. The hotter the hose the stronger the flavour [eg if the hose has been lying un the sun]. We had friends staying at our place a while ago that filled their tank with our hose that was lying in the sun you could smell the taint even in their coffee after being boiled in a kettle. Cheers
AnswerID: 232670
Reply By: Member - MUZBRY (VIC) - Wednesday, Apr 11, 2007 at 09:09
Gday Stoker 571
I only squeezed a lemon in my tank and that just works fine,,or lemon essence...mind the seeds.....................
AnswerID: 232696
Reply By: david j - Wednesday, Apr 11, 2007 at 19:06
we use milton in van tank and it works fine.------ add a bottle of milton to your tank, fill with water--- drain and fill three times and bobs your uncle------ happy tripping.
AnswerID: 232803
Reply By: Scrubcat - Wednesday, Apr 11, 2007 at 19:59
Where are you people getting all this water for flushing tanks ?? LoL
We have got level 4 water restrictions, no outside use of water.
Got into trouble with the little woman for taking the concrete mixer into the kitchen when I needed to mix concrete for a path. No chance of being able to flush anything but the loo. LoL
Scrubcat.
AnswerID: 232823
Reply By: Rod - Thursday, Apr 12, 2007 at 09:54
Cup of Vanilla Essence to 10l of water and let sit for a few days then drain
AnswerID: 232900
