SPOTTIES
Submitted: Tuesday, Apr 10, 2007 at 20:29
ThreadID: 44181 Views:2628 Replies:15 FollowUps:14
I have narrowed my selection to 2 but i thought i'd see what other have and get their thoughts, i won't name my 2 selections so i can get an unbiased view on what yo think are good.
My only querey is, is distance important (ie) 500mtrs V 700mtrs.
Baz.
Reply By: hiab - Tuesday, Apr 10, 2007 at 20:38
i hope hella rallye 4000s are on your list. i have also had lightforce and while they worked well, they jumped about a lot and put me off, first roo i hit, goodbye lightforce. everyone will tell you something different, so it is up to your own gut feeling.
AnswerID: 232646
Follow Up By: Redback - Tuesday, Apr 10, 2007 at 20:41
Thanks mate good unbiased comment,.
Is hiab your job as well, i used to drive a hiab truck myself.
Baz.
FollowupID: 493529
Follow Up By: Blaze - Wednesday, Apr 11, 2007 at 00:25
Hiab, You should have contacted lightforce and they would have replaced it from my experience, and I guess you can guess Redback which lights I favour :-)
FollowupID: 493534
Follow Up By: hiab - Wednesday, Apr 11, 2007 at 00:31
the lights were fine... but the big ones, on most bullbars, poke out the front , and when you hit something, heaps of smashed plastic. rallye 4000s are not as deep and sit behind the line of the bar, and are steel bodied, and in my mind the output is equal if not better. and if you haggle can come in cheaper.
FollowupID: 493535
Follow Up By: Member - Matt Mu (Perth-WA) - Wednesday, Apr 11, 2007 at 11:10
With you HIAB...my 4000's were second hand when I was given them (owner went 2wd??) that was over 7 years ago and now they are on my third vehicle and over 300 000km!
Not a thing wrong and only ONE globe replacement....I put it down to the best and most stable mount on the market!
I used to work for Cummins and every truck that came into the workshop had either Hella 4000 or Hella predators HID (one had 4 predators in a row....add that up!!)
Now as professional drivers in the worst possible conditions and not one truck ever had lightforce ???
I have previously had Cibie Oscars, Hella 100's, IPF 9000 (now on Dads 4by) but wouldnt trade the 4000s for any of them. They even make the smaller 4000s FF for smaller vehicles now!
Yes I AM biased these lights are fantastic!
My 2c!!
Goodluck with the purchase Red
Matt.
FollowupID: 493581
Follow Up By: Blaze - Wednesday, Apr 11, 2007 at 15:56
"I used to work for Cummins and every truck that came into the workshop had either Hella 4000 or Hella predators HID (one had 4 predators in a row....add that up!!) "
Seems a bit odd if there that good why would he need 4???
I think some people are missing the point here, Lightforce are lighter (pardon the pun) with the very reason that heavy metal lights on 4X4's travelling at faster speeds than heavy machinery on corrugations have more failures at the mounting point. Its not hard to work out if you have a 700gram light mounted on a bullbar vibrating against a 350gram light the heavy one is more likely to fail.
So I guess as others have said, the choice is up to the individual.
FollowupID: 493635
Follow Up By: Member - Matt Mu (Perth-WA) - Thursday, Apr 12, 2007 at 10:35
Blaze
"Seems a bit odd if there that good why would he need 4??? "......for more light?
Was this a serious question or tongue-in-cheek?
If you were a truckdriver on the road 24/7 with the appalling standard lights they have...wouldnt you fit the best you could when it all makes your job easier and safer (considering how detrimental eye-strain would be!!) Enough said hey!
As with the mounts...have you seen the base of a 4000...its not just a 2cm square lug with a bolt through it. Its about 15cm by 6cm rectangular base with no extentions or projections to increase the leverage on the light when exposed to vibrations.
Why dont you do the math...I believe force= mass x perpendicular distance from the fulcrum.. so your 350g light sitting on a 10-20cm mounting arm compared to the 700g light whose COG is only maybe 2cm from the fulcrum works out to be about ..... 0.6Nm for the 240 lightforce and about 0.14NM for the 700g light So much less rotational force at the fulcrum and ultimately less vibration of the beam of light!
The lights become a solid part of the vehicle rather than an addition. Hence why I believe they last so long and do not vibrate like others on the market!
But to each thier own...
FollowupID: 493766
Reply By: Member - Oldplodder (QLD) - Tuesday, Apr 10, 2007 at 20:43
Have had the same pair of cibie super oscars for over 30 years now.
May be some better lights around now, but am happy enough not to change.
But they need a repaint and a going over with fish oil every 10 years.
PS - wondering why people mount their lights (particularly the large lightforce) out the front of the bullbar? I have my cibies mounted back behind the front bars of the bullbar and they have survived a few roo strikes without any damage. But then I selected the bar to suit the car and the lights.
AnswerID: 232649
Reply By: Member - Michael J (SA) - Tuesday, Apr 10, 2007 at 20:44
G'day Redback,
It really is a matter of personal choice v money in the bank.....
I had IPF for a while but son hankered for 'em.
I have just put Lightforce XGT on and truly do not find a great deal of difference.
Both are good, but when you get old and can't see too well anything helps..lol
I have had a variety of lights on a variety of vehicles over the years and bottom line is.. get the best you can afford and then do not compare them with anything else........;)))
Michael
AnswerID: 232651
Reply By: Gramps (NSW) - Wednesday, Apr 11, 2007 at 00:31
Glad you posted this Redback. Tossing up between Lightforce and Hella at the moment.
AnswerID: 232655
Reply By: hiab - Wednesday, Apr 11, 2007 at 00:33
no, hiab is the nickname i have at work. at 6'3 and 125 kgs they reckon i can lift anything.
AnswerID: 232656
Reply By: disco driver - Wednesday, Apr 11, 2007 at 00:40
Hi Redback.
If you can get hold of a pair of the old Lucas "Flamethrowers" and convert them to QI as I did, they are as good as if not better than most of the plastic stuff currently available.
Disco
PS They are fairly flat(shallow) and sat well behind the bullbar on my disco.
AnswerID: 232657
Reply By: Member - Ed. C. (QLD) - Wednesday, Apr 11, 2007 at 02:09
IMHO, good even spread is far more important than distance "for distance sake"...
I've found that with pencil beams (even when combined with a broad beam) the eye tends to focus on that spot waaay down the middle of the road, when one really needs to be concentrating on what's on the _side_ of the road, and closer to the vehicle..
I (like many others) do have 1 spot & 1 spread,, mine are switched individually so that I can have one or the other, or both (or neither) on as the conditions warrant..
I can't think of any occasion when I use the distance beam on it's own, but plenty of occasions when only the spread beam is on..
On any kind of winding road, I find the concentrated spot to be nothing but an annoyance, so it stays switched off.. Indeed, if this one ever gets damaged, I'll be replacing it with another spread beam;-)
FWIW, Hella does it for me, and IMO, the Rallye4000 spread beam is as good as it gets in an "affordable" light, and the distance throw from these is more than adequate anyway for any kind of sensible night driving:)...
Yeah, yeah, I know they're not "submersible", but silicone's cheap;-)))
Catch ya later:)
Ed. C
Confucius say.....
AnswerID: 232667
Follow Up By: Member - bushfix - Wednesday, Apr 11, 2007 at 07:24
agreed. i use a pair of narva spread beam spotties. the point you make about focussing on the spot down the road is quite valid. the new design make them a much tougher light than the previous narva.
FollowupID: 493550
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Apr 11, 2007 at 08:20
Good point about the spread and spot beams.
I run 2 spread beams, no spots.
Find the spread useful on twisty roads and spotting roos in the grass at the sides.
Only occasionally miss a spot beam to see more than 200 to 300 metres away.
Find most roads either turn or go up and down and a spot spends a lot of time pointing some where not so useful.
I don't drive at the speeds I used to at night either. Max about 120 km/hr (33m/sec) at night now. Takes about 120 to 140m to stop at that speed, so if I can see 200m down the road, thats all I need. About 80m to 100m to stop at 100km/hr.
www.sdt.com.au/STOPPINGDISTANCE.htm
Used to find a spot useful picking up the reflectors for the next kilometre or two, to get an idea which way the road goes when travelling at higher speeds.
FollowupID: 493560
Reply By: Member - Nick (TAS) - Wednesday, Apr 11, 2007 at 07:42
Rallye 4000"s, one spot and a spread beam.
AnswerID: 232679
Reply By: Rosco - Qld - Wednesday, Apr 11, 2007 at 08:05
Redback
I've had a pair of Hella Rallye 2000 for about 20 years and reckon they're pretty good. Tho one of them's a bit like Grandpa's axe ... new lens one time ... new body another LOL. I've spoken to blokes with Lightforce and while they throw a good light they generally were of the opinion vibration was an issue.
I also have a spot/spread combo, but make the observation it's as much about outdriving the light and braking distance, so from that point of view I suppose a few hundred metres should be adequate, particularly in a 4WD.
AnswerID: 232683
Reply By: Redback - Wednesday, Apr 11, 2007 at 08:48
Thanks for all your comments fellas, good to see that the 2 lights i'm deciding on are mentioned.
I have Cibie Super Oscers on at the moment, and although they are good lights they are a bit big for the bullbar i have on and also i've repaired and painted them a few times and the mounting swivel is a pain when trying to adjust them and it's on it's way out and not to mention a broken lense, so i feel it's time to upgrade.
I've chosen the Hella 4000s for a couple of reasons, one being price and the other it has a reasonable distance compared to others that shine for miles and they fit in the bullbar well and don't poke out like the others do.
Thanks again, Baz.
AnswerID: 232693
Follow Up By: Old Gold - Wednesday, Apr 11, 2007 at 10:20
Hi Baz i would go the 4000s i have had them for a few years now no probs at all.Also there is a small version of the 4000s work just as good as the bigger ones
Cheer's Tim
FollowupID: 493575
Reply By: Member No 1- Wednesday, Apr 11, 2007 at 10:48
dont want to hijack this thread redback
Guys...are the rallye 4000 upgradable to xenon?...if so where does one go to speak to in SA who knows all the answers?
AnswerID: 232706
Follow Up By: Member - Matt Mu (Perth-WA) - Wednesday, Apr 11, 2007 at 11:18
Nudie the Predators are the HID version of the 4000's...I havent had the opportunity to pull them apart but from the outside they look VERY similar in shape. I would contact a Hella Distributor and ask if you can purchase the internals for the predator...Dont hold your breath about them being resonable with cost...think the predators retail in the vecinity of 1500 each??/
They are starting to sell at reasonble cost Zenon filled globes...so maybe just an upgrade from the old QH ones for an improvement in light quality if the predators are out of range?
Goodluck
Matt.
FollowupID: 493585
Follow Up By: Steve63 - Wednesday, Apr 11, 2007 at 15:08
May not be, Predators have an external ballast set up and deliver 25,000v to the light. SWMBO bought me a set about 6 years ago when they retailed for $1900 each. She must have been feeling a bit light headed that day. I had the car in to have the roo bar put on and came back to find the lights on as well. You could have knocked me over with a feather. They have done 250,000km no issues. I did break one mount on the Kalumburu road. Got back and Hella replaced it no charge even though it was years out of warranty. They are the best lights I've ever had. Bright, no eye strain, solid mount, fit behind most roo bars.
Steve
FollowupID: 493630
Follow Up By: SA_Patrol - Wednesday, Apr 11, 2007 at 18:08
Member No 1, Tim at Belair Rd Auto Electrical has done the conversion on his Hella 4000's Ph 8271 7617
FollowupID: 493663
Follow Up By: Truckster (Vic) - Thursday, Apr 12, 2007 at 11:33
#1..
goto outerlimits, look for threads by bushy555 - hes the guru on these conversions.
if it can be done, he will know.
FollowupID: 493783
Follow Up By: Member No 1- Thursday, Apr 12, 2007 at 13:33
ta guys
FollowupID: 493803
Reply By: Markymark - Wednesday, Apr 11, 2007 at 17:12
I have had the Lightforce Blitz 240's for 5+years, one spot and one combo cover. I found with the 2 spots, when I went around corners in the bush I was suddenly blind! The spot/combo covers work well, even 2 combos as you still get a beam down the centre.
I've had a range of smaller Hella lights but after a great run with my Lightforce hand held spotty, thought I would try their driving lights. Awesome light. I even bought a bike light off them (don't make them anymore) and I had cars flashing their lights at me when I rode to work!
I haven't tried the bigger Hella's or IPF's so can't say if they're any better/worse.
Mark.
AnswerID: 232773
Reply By: Member - Willie , Epping .Syd. - Wednesday, Apr 11, 2007 at 17:34
I have two Hella HID Predator spread beams on my cruiser .
As my eye sight slowly fades , I found I was having a lot of trouble spotting roos on the side of the road . So I went out and bought the most powerful lights I could find to replace my Cibie Oscars .
The Predator spread beam reaches out further than the pencil beam on my old Cibie Oscars , so they are incredible lights .
Downside is they fill up with water IMMEDIATELY they are immersed past where the wiring comes out on the back . This is not covered by warranty .
Hella states that neither the 4000 nor the Predator should be immersed in a creek crossing . They say the only Hella Light you can do this with is the special waterproof model .
I guess you can do what I do and put a plastic bag over each one before you go swimming .
REDBACK NOTE - I will not be doing any of the local aboriginal art sites until August when I get back from the Kimberley . I will post then if they are any good .
Cheers ,
Willie .
AnswerID: 232781
Reply By: Member - extfilm (NSW) - Wednesday, Apr 11, 2007 at 17:43
I have 2 standard Nissan issue IPF's that came with the bullbar included in the deal with the purchase of the ute. They are 2 spread beams now. By the first 1000k service I noticed the spot beam had cracked. Of course Nissan would not replace it under warrany. (Only the start of my Warranty issues). Replaced it with a spread beam. Put 130 watt globes in straight away.
2 Hella 1000 spread beams. Problem with these are the globes can be a little difficult to get.
2 Hella 4000 spot. They are the new small ones.
They all shine various distances and with this configuration I don't seem to have a problem seeing at night.
See rig pic
AnswerID: 232790
Reply By: Redback - Wednesday, Apr 11, 2007 at 18:00
Well i went out looking today and after getting some bad financial news i couldn't get the Hella 4000s like i wanted too.
After searching all day i settled on some 130watt IPF 800s, not what i oringinally wanted but they will do untill i pay a few bills and have some extra cash for some lights.
$280 and some clear covers so not too bad, these can be submerged and are considered waterproof for short periods, the Hellas on the other hand are not waterproof at all.
Baz.
AnswerID: 232794
