brackets to mount pvc pipe on roofrack-buy where
Submitted: Wednesday, Apr 11, 2007 at 20:09
fozzy
hi all
looking to finally mount a pvc pipe on my roofrack(arb steel to suit 100 series) to be able to put poles for a tarp inside and have seen brackets that could potentially bolt to rack where the pipe fits in.
i think it will most likely be 90mm piping.
does anyone know where to purchase such a bracket?
i have used big hose clamps on a earlier model but was looking for possible alternatives.
any suggestions greatly appreciated.
i live in
melbourne
cheers fozzy
Reply By: macca172 - Wednesday, Apr 11, 2007 at 20:12
Fzzy,
ARB sell them as a stock item. I have 100mm ARB Polly brackets fitted to my rack!
Macca
232829
Follow Up By: fozzy - Wednesday, Apr 11, 2007 at 20:18
thanks Macca
493701
Reply By: CLC50 - Wednesday, Apr 11, 2007 at 20:13
Any 4WD parts
Shop
Rino Racks make a good one for there heavy duty racks I have 4 fitted or Tradelink Plumber suppliers you can make to fit
232830
Follow Up By: fozzy - Wednesday, Apr 11, 2007 at 20:19
thanks clc50
493702
Reply By: On Patrol (Aust.) - Wednesday, Apr 11, 2007 at 20:37
fozzy
Hard to beat the hose clamp mate, cost effective, light, strong & reliable.
Having said that,
I have a flat steel rod inside the length of the tube and the same size rod along the inside of my basket with bolts between so as to "sandwich the tube wall" to the basket and spreading the load over a greater length of the tube plus stopping the tube from bowing. It still has two hose clamps for added security, to be sure to be sure. No Cape corrigation is getting my fishing rod and poles.
Colin.
232844
Reply By: Member - Sam (NSW) - Thursday, Apr 12, 2007 at 07:47
I got
mine from
http://www.roofrackcity.com.au/. made up some clamping plates so i didn't have to drill into the rack and then bolted the PVC brackets to them. Works a treat.
232859
Follow Up By: Member - Sam (NSW) - Thursday, Apr 12, 2007 at 10:54
I should also add that RRC had the choice between the steel strap style ones and also the aluminium ones (i went for these as they seemed more sturdy).
So far so good. Can email photos if you like.
493771
Reply By: Johnny boy - Thursday, Apr 12, 2007 at 08:35
Gday mate try an exhaust fitting
shop like Middus the ones for small trucks are almost unbreakable!!!
232875
Reply By: Spango - Thursday, Apr 12, 2007 at 09:24
fozzy i have a set of brackets that I recently brought but are not compatiable with my roof rack, if you want them I will post them to you.
Spango
232892
Reply By: Steve63 - Thursday, Apr 12, 2007 at 09:33
You can get brackets like this from any hardware store. You just need to look at fittings to put them on the rack. A lot of racks have custom mounts for doing this for some extra $'s
Steve
232895
Reply By: AdlelaideGeorge - Thursday, Apr 12, 2007 at 15:13
Hi - I used the standard brackets that are produced to secure the pipes to walls and such. They are as cheap as chips but you will have to 'modify' them a little with a couple of pairs of multigrips in order to get them to fit round your roofrack bars. I have a 'basket' fitted to two Rhino bars and I bent and shaped the brackets so that they are able to be be bolted up round the bars of the basket.
This may not be an adequate description - if you give me your email address I'll send you a couple of pics - alternatively I'll get the proper name of the brackets.
You will see them for sale in the same area as the pvc piping in your hardware store.
Happy days
Geo
232962
Reply By: arewelost - Saturday, Apr 14, 2007 at 01:23
hi
regarding you pvc pipe clamps any plumbing supplier will carry then they are called abby clips or the other name is a nut clip in
perth we have tradelink,reece and galvins i don't know if they have branchs in other states
hoope this helps cheers steve
233261
